2001 Wakeboard Config Suggestions |
Author | |||
86ER
Groupie Joined: November-10-2015 Location: Florida Status: Offline Points: 63 |
Posted: December-21-2015 at 11:02pm |
I recently purchased a 1986 2001 that I'll use primarily for skiing, wakeboarding, and tubing. As far as I can tell, the boat is as factory delivered, with the exception of electronic ignition. Myself and my buddies are all in our low to mid 50's, 30 to 60 lbs. overweight (when being kind to ourselves), haven't skied in more than 30 years, have never wake-boarded, and are essentially couch potatoes (aka Fat Boys). Given these facts, we obviously aren't planning to catch any significant air, do flips, etc., etc., nor are we looking to "Rock Out" the lake with Mega-Watt tower speakers. Assuming that we don't kill ourselves in the process, and actually progress to the point at which we might want to start jumping the wake (three minutes into the ride), will we be limited in what we can do with the tow rope tied to the transom hook or stock ski pylon, or should I consider, at the very least, getting an extended pylon? Money is not an issue, but I don't think that we really need a wake tower for what we will be doing, or do we? I'm concerned about the stress that an extended pylon might put on the through-floor mount, because no matter how well you secure it, it is likely to work that area of the boat very hard. I'm not against installing a tower if it makes sense, but then I'd have to get my cover modified and remove and install the tower every season. Certainly not show stoppers, but things to be considered. Thanks in advance for any suggestions.
OverMyHead
You will love the 86. Its a blast to drive and It has an inherently great wakeboard wake (size and shape) at boarding speeds without ballast. I don't board myself but I tow my son. I hear from all it is easier to get out of the water with the extended pylon. The pylon also lets you have passengers in the back seat (free ballast)The pylon has a strap and harness that goes from the nose of the boat to the top of the pylon. Properly adjusted it takes the load off the pylon mount.and works fantastic without putting a bunch of holes in your boat,
1987 Ski Nautique |
Definitely get the X-pylon. It pulls you up out of the water, my arms can really tell the difference without it.
I wouldn't bother with ballast if you are a beginner Recommend a Acme 540 prop if you still have the stock federal. Get the biggest board you can find, as that will also be easier to get on top of the water.. |
backfoot100
Pat,
First off, congrats on the boat and post some pics. Everyone here loves pics. Secondly, you'll quickly find out that tubing doesn't bode very well here. There have been countless discussions on the lack of talent needed to partake but on the flip side, it has also been a stepping stone for countless young ones before strapping a ski on so be prepared for that discussion....again. There have also been countless debates about tower vs. extended pylon. A quick search should provide hours of entertainment. Purists believe a pylon is the only way to go to keep the lines and intended use for the boat intact without drilling holes and mounting that God awful cage on top of your classic ride. If you want a tower, buy a boat that came from the factory with one and don't f**k up a classic. I guess you can tell which side of the fence I'm on. FYI, an extended pylon will actually cause less strain on your pylon because it's being anchored from the top so that is not a concern. Several here have made a loose, unusable pylon work for a season or more with a properly adjusted extend pylon without a problem. On the flip side, I also see the benefits of a tower and the space it can free up on the floor. Properly installed, it is much more stronger and can take side loading where an extended pylon cannot. So what does that mean???? I wouldn't want to try an "around the boat" with an extended pylon where a tower works fine. So if that trick is going to be in your repertoire you'll want a tower. Virtually anything else that I can think of an extended pylon will suffice. Ultimately the choice is yours and one you have to live with. My suggestion would be to get out and enjoy the boat. Get a feel for the old girl. Play around and get some water time skiing and wakeboarding. The whole concept of a higher pull point was never thought of when your boat was built and contrary to popular opinion, you don't need a higher pull point to be able to enjoy any watersports. If you feel you must have a higher pull point, then get an extended pylon to get used to it without doing any damage to the boat. After you get some experience and decide that a tower may work out better for you, sell the pylon and install a tower. Extended pylons resell pretty easily. Where in FL are you? A lot of members here from FL. |
Eddie |
[QUOTE=86ER] I'm concerned about the stress that an extended pylon might put on the through-floor mount, because no matter how well you secure it, it is likely to work that area of the boat very hard. QUOTE]
This is not really a significant concern with an 86 Ski Nautique. That boat was designed around securing that pylon. The floor of the cockpit plays no significant role in securing the pylon. There is a thick aluminum cradle spanning the stringers of the boat that directly ties the pylon to the engine mounts. You will very likely bend the pylon before you loosen the mount. Get the extended pylon, correctly install it, and there are no worries - it greatly improves the wakeboarding experience even for beginners and will help you on your deepwater barefoot starts as well. |
JPASS
I agree with the others on the extended pylon. It should work fine for what you're trying to do.
'92 Correctcraft Ski Nautique
quinner
Since you guy's have never wakeboarded and everybody above covered the pylon question I will offer my 2 cents on wakeboarding.
One thing I see often when teaching new boarders is the rider plowing too much and hurrying to stand up. Before you start, rotate the front of the board down by bending at the ankles and pointing toes towards the boat, so the board is at a 45 deg angle (or less) to the water surface, you do not want the board perpendicular to the surface when learning the start. Don't be in a hurry to stand up, rise slowly, that lower center of gravity should help with your balance. Forward foot can usually be determined by having the person relaxed standing straight up at attention per say, push them slightly in the center of the chest or center of back, whichever foot they catch themselves with "should" be their forward foot. Also if the person can imagine running and then sliding on ice, which foot would they lead with, same result, that would be their front foot. For beginner big guys you will want to run in the 18-20mph range, easy throttle at the start and slowly come up to speed. Good luck, betting you guy's are going to have a blast!! |
86ER
Folks,
Appreciate all of the information. I'll go with the pylon and see how that works out. I live in Melbourne, FL, but I'll be using the boat on lake Upstate NY. Unfortunately, the boat is currently up there, so I won't be able to get pics until the spring. |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6111 |
What lake in upstate NY? (my old stomping grounds...and JoeinNY's current stomping grounds)
proper tubing config
Acidents from tubing Kevin says it all:
86ER
I'll be using it on Lake Bonaparte, which is a small lake located in Harrisville, about 50 minutes from Watertown.
very well written opening post btw
75 Tique
Well that certainly qualifies as upstate NY. (some people think anything north of the Tappan Zee Bridge is upstate).
I spent my summers about 60 miles south of that on a lake in Forestport. In 1971, I spent a summer in Watertown. Met a guy there that the following summer became my "let's teach ourselves to barefoot" buddy. Most memorable summer ever. You didn't mention barefooting in your plans....never say never!!! 1972 |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
Good choice to go with the pylon. Honestly, just getting the rope up high so your gang can sit anywhere in the boat is the reason to go with it, of course the other advantages are there as has been mentioned. I'm a new boarder as well and the learning curve is steeper than I figured it would be, my ski experience isn't doing me much good!
Congrats on the boat, and a huge congrats on you and your buddies taking on a new sport. You're going to have a blast! |
td_in_nc
Senior Member Joined: March-30-2012 Location: Clayton NC Status: Offline Points: 381 |
I used a pylon on my 1985 SN2001 Worked great as it got the rope high enough if you need to have people sit in the back seat. Once you get confident enough to start jumping shorten the rope about 5 to 10' in front of the shortest loop (this will bring you a good wake for jumping). and slow down to about 15 mph water is much softer and less painful at this speed especially since we are not as you as we use to be. At least until you are comfortable. I agree with the other comment to get the right sized board. I weigh 200 lbs and learned on my kids 118 board - it was exhausting. When I got a new 142 board I was amazed how much easier it was. If money is no object I would get a couple of lessons so you learn the right/easy way
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 407 |
Own a 1988 - 2001 . I use a pylon and works just fine . I add 1200 lbs of ballast and board at 22 mph . Started when I was 44 and am now 52 . You said that you aren't planning on catching any significant air . I have a feeling that after getting over the initial fear you will probably be getting more than you planned . I mean , why not ? Have FUN !! Just start out slow and progress accordingly .
86ER
Guys,
Thanks again for all of the great information. Several weeks ago I purchased a Acme 540 prop based upon internet research, but it was good to see the same recommendation from member SNobsessed. I'm currently considering the stainless Sky High X Pole pylon extension. Does anyone have any comments (good or bad) regarding this pylon extension, or any others? I prefer to get one that slides over the existing factory pylon. Also, I noticed that in almost all of the wakeboard training videos that I've viewed, the front skeg has been removed from the wakeboard. Is this the preferred configuration, or just the recommended configuration for beginners? Additionally, what length tow rope would you recommended for the 2001 for beginners? I've currently got a generic ski tow rope, but I have no idea how long it is.. I'm sure that at least some of these questioned have been answered in the past, so I apologize if I'm repeating them. |
td_in_nc
I would recommend leaving the skegs/fins on and learn to ride regular and goofy from the start. We learned at full length which is good at first because it give you plenty if room to manuever before you cross the wake. I recommend not going faster than 16-18 when you are just learning to get up as falls are much softer at that speed. We Adjust the rope length to get the best part of the wake for the speed the rider is comfortable at.
I have Stainless steel Fly Hi, works just fine. I have the bow strap tied to the lift ring so that I can leave the strap on when trailering. Saves a few minutes threading the strap thru the bow eye each time.
75 Tique
Oh boy, here we go.
63 Skier
Thanks for the chuckle Larry, I was just about to post "uh oh"!
quinner
Private Conrad.. what is your major malfunction!!! LOL, so the OP knows, tying to the lift ring is not really recommended |
JPASS
Doh!
Chris,
I'm in shock!! |
Absolutely do not use a polypropylene "ski" rope from a high pull. It can come recoiling back into the boat with a vengeance. Get yourself a non-stretch spectra/dyneema rope.
Geez guys, The nylon strap that goes around the bow, not the cable that goes to the pylon.
If I had said 'cable', then you would have had legitimate ammunition. |
75 Tique
63 Skier
Chris, it's been proven time and again that even a 1/4" bungee with 4 lbs. of pressure from the side on the lifting ring can cause a Nautique to destruct into tiny pieces. |
75 Tique
Trust us. It's not pretty.
