Atlantic Marine |
AussieRy
Newbie Joined: February-22-2016 Location: California Status: Offline Points: 19 |
Posted: February-22-2016 at 7:23pm |
Hey Guys,
New to CC Fan, but seems like a great resource. Ive enjoyed watching from the sidelines for a few weeks. Here is the story.... looking for some advice. I recently picked up a 90 Ski Nautique that may need a new engine. If not now, then at some point down the road. I have a low cold compression in one cylinder, all the others tested great. The boat sat in Cali for a few years, but only has 300hrs total on it, so I remain hopeful. Im going to fire it up this week once I get everything ready on it, and am hoping to get a better reading after it runs a little. fingers crossed. Since I want to get up and running for the summer ASAP I am working my "plan B" which is to either restore the current engine through a local machine shop or purchase a remanufactured long block from one of the many I see online. I have seen comments on this forum about a lot of the suppliers (rapido, Jasper, Summit, US marine etc) but don't see anything about Atlantic Marine out of Florida. Does anyone have any experience with them? Looking for some advice so I can be back out on the river come March! Cheers, Ryan |
1990 Ski Nautique
Ryan,
Congratulations on your purchase. I suggest getting the engine running and then evaluate just how bad that one cylinder is. You didn't mention the actual results of your compression test but there sure is a chance you can run it as is. Then, when you have more time, pull the engine for a rebuild. Welcome to CCfan and since you have been with us for a couple weeks, you know we always ask for pictures! |
AussieRy
You're right, I knew that was coming.
#6 is reading 70psi. The rest I believe were around 110-120 Here are some pics taken the day I picked it up. before it got a detail. Currently in the workshop. Cheers, Ryan |
1990 Ski Nautique
Ryan it's a long way to California from Florida as you know, what happens if you run into trouble? I would google Atlantic if I were you. I have seen them at the Miami boat show,they have a slick catalog and presentation. Inboards are rare in the area here,I/O's even more so- so there is no one around here to ask. You might have a bad head or gasket and only require a head change or rebuild. A leak down test will help confirm better than a compression test.
AussieRy
Thanks Gary - good thought. I just assumed the rings due to the time it was sitting, but could be something else.
can't wait to find out and get it right! Ryan |
1990 Ski Nautique
Ryan,
Looks great. Thanks for the pictures. Gary's idea is a good one. Get back to us with the results. I'd also run the compression test again but warm. Do it once and then again with some Marvel Mystery oil in all the cylinders. Did the PO have any input on the bad cylinder? With very little time between now and when you want to put it in the water, I'd be inclined to use it as is no matter what you may find with the #6. |
63 Skier
Nice looking boat! That's a classic color scheme from those years, really like it.
Yes, might as well run it. You may get lucky and the cylinder seals better with some running, but not likely to do any harm. Did you take a look at the oil, nice and clean and no milky look? |
Orlando76
Geez, I think you bought my old motor. I had the same compression numbers with 6 being my bad cylinder too on a 485 hour motor. i was amazed at how strong the motor ran with the bad cylinder, I never would've changed motors but it would vibrate just enough the be noticeable from 600-1200 Rpms, after that it ran like a dream. I ran it like that for 9 months. Bought a rebuild from Summit due to previous super experience with another motor I purchased from them. |
74Wind
Cali. Ironic.....,a friend from California was just chastising someone for using that word that word at a party yesterday. Said (which I've heard before from others) Native Californians never call it Cali and it's a surefire way to tell a newbie.........
Seems like a great chance to test the theory. Are you a native? |
1974 Southwind 18
1975 Century Mark II |
AussieRy
Its the curse of where I am from - Australia. We have a habit of shortening words. Although I have lived here for over a decade so I should know better.
I think your theory holds water. |
1990 Ski Nautique
tryathlete
Welcome AussieRy! Keep us posted on that funky cylinder. Head gasket, rings a little rusty, sticking valve or lifter, none of this is very tough to fix. Sure one possibility is a bad cylinder, but that's only one possibility. Low hours bodes well for simple stuff.
Get her out on the open water and use her for a few days. Run that compression test again warm like others are saying. Save up those frequent flier miles and come to Green Lake this Summer. |
Duane in Indy
I personally don't put much faith in compression checks. For one thing there is no base line number to go by. In other words all cylinders can check within 5 pounds and ALL could be weak. The best way IMHO is to use a leak down gauge as others have suggested. A compression gauge only shows how much the cylinder compresses the air (hence the name). It does NOT show how long the cylinder holds pressure. By using the leak down gauge it will check the condition of all the components within the cylinder. By listening to the leakage you can determine what the problem is likely to be. Hissing noise in exhaust is exhaust valve issue, in carb it is intake valve, crankcase breather hissing would be rings. We leak our Nitro Funny car after every pass. (Usually blown up but just maybe we only have to pull one head) Long post but this gives you an idea. Even cheap harbor freight gauges will work. Duane
1978 Mustang (modified) |
74Wind
Duh...I should have guessed it by the name AussieRy. .. |
1974 Southwind 18
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
Nice looking boat. My brother had one identical to it.
AussieRy
Unfortunately the previous owner didn't know about the cylinder, but also didn't let me know about a lot of stuff. ha |
1990 Ski Nautique
AussieRy
Thanks everyone for your insight on this. I still want to run a leak down test to see where I am really at, but I did manage to get her started today and got the compression back too! Ran it for 2 minutes and read low 90s in the bad cylinder. Could not be more relieved and anxious to get out on the water.
here is an attempt at a link to the startup. link |
1990 Ski Nautique
63 Skier
Good news! I'd say after about another 1500 hours you ought to consider a rebuild!
Hard to tell with the audio, but am I hearing an exhaust leak somewhere? First I thought it was a ticking sound, then thought exhaust, but not sure. |
AussieRy
yeah, i might have jumped the gun on the rebuild. ha |
1990 Ski Nautique
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
AussieRy, I'm in a similar boat to you (pun intended). Last year I was looking at a 95 sport, did a compression test and numbers were very similar to yours. Mostly around 120 with one cylinder at 90. Got the advice on here that if it still runs well its not really a problem. Did a test drive and the boat ran great. Got it up too 43 mph, which isn't too far off what it would do new.
So I bought the boat. Got it for 7k without a trailer. I got the boat last fall and have been sprucing it up with minor improvements. Cleaned and waxed it, got a few small replacement parts, adding perfect pass stargazer and got all the seat bottoms replaced. The boat wasnt being used much in the last few years and apparently wasnt used at all last year. I'm going to run it this summer then get the engine checked out again once I've put a few hours on it. I have driven the boat a total of about 2 hours before putting it away and can't wait to put it back in the water and get it going soon. |
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
