  New Posts New Posts RSS Feed - learning to barefoot
 Post Reply Post Reply Page    <1 135136137138139 152>
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:11pm
And don't kid yourself on those "shoe" skis. They're more like trick skis than barefoot trainers but still build balance and skill.
20 on the boom should be plenty, 22-23 long line, you'll be surprised how slow you can go
lcgordon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:15pm
I have an excellent used 541 for sale if that's the direction you want to go (which I agree with).
Ill pm you about the prop.
As soon as my boat is back together (replacing the strut bearing and stuffing box then it needs realigned). I will be doing a gps run and getting tach readings. Im not sure how accurate my tach is. But I also have perfect pass so I will be watching both to get readings. The rpm range on the motor says 4400-4800. The prop that is on it is a 13x13 oj prop with some dings from the PO. Im hoping within the next week to have the parts and get it back together for a run. Altitude is 5280 and possibly couple times a summer going up to mountain lakes which are 7xxx ft.
Thanks again guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:17pm
Yeah those things are easy first try I got the spin and missed the handle second try I got it and rode it but missed the video. 3rd try was sloppy. I just got some BFC shoes in yesterday so I am expecting some hard falls trying it on those.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:21pm
I agree with Tim.
That 541 is an excellent choice at sea level but the 543 might be better at altitude. Definitely need to know RPM and speed with the existing prop first. We haven't a lot of experience suggesting props at altitude.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:24pm
Thats what I was thinking I will update you guys with info when I get it. Thanks again. Would it be safe to say to go with acme and not oj? Oj is like 50 bucks more expensive it seems too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:35pm
Acme > OJ in every comparison I've done. And I've done a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:36pm
Awesome thanks I will remember that
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:43pm
When speaking holeshot, speed holding, throttle response and top end I've never had an OJ beat out an Acme. Acmes have never let me down.
I got your PM about my 541. It comes with a money back guarantee (unless you *************** it up), so at least you can get a "free" data point if needed. Just pay shipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 1:47pm
^^awesome offer, do that^^
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 2:00pm
I may have to do that. What worries me is you could run your boat for 20years with no problems and the 20 min you are testing one you ding it haha. I would be uncomfortable doing that at the lake we usually ski it alot of places it is under 3ft deep. Not that we ever really have any problems I guess. I know the lake pretty well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 2:11pm
you break it you buy it, ask dave hart
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2016 at 2:19pm
Were gonna try to stay away from that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2016 at 4:28pm
https://www.youtube.com/watch?v=OXEKvU9B2Wg
First toe hold on the shoe skis.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2016 at 12:11am
You will likely still use those wood shoeskis to improve your skills with the small rubber shoes...or you will fall alot on the little ones. Use the big ones then use the little ones...and visa versa. Seipel teaches to steadily drop your speeds into the teens to increase drag which is more like on feet. This is just for turns.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2016 at 1:43am
Defiantly need to use the wood ones here is the first attempts at turns today not too good
https://www.youtube.com/watch?v=WiT16Qi20Jk
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2016 at 1:55am
feet closer together, start with elbows bent handle closer to body ...get a rhythum...1..2..3 on 1 get set 2 dip down some and 3 rise up and turn turn starting at your feet SLOWLY...think handle to butt and butt to handle....and then go try the reverse turn
my speed on little shoes is 27. the bigger ones slower
google shoeski king to see what you could do on those wood ones.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2016 at 10:08pm
Thanks for that. I got a guy that skis with me who is pretty good. But really I have no business learning turns. I pretty much just started barefooting and got my first toe hold on shoes just yesterday. I just like trying things that are way out of reach because sometimes you surprise yourself in how close you get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 3:38am
At least you didn't say you were gonna do it on your barefeet first try...but video can be good
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 12:23pm
I would have face planted before I even started to turn haha
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 1:33pm
Had some action yesterday..finally the river is cleared from the floating plants...
looks like the high tides during the week, moved them and drag them out to the open waters!
Valentino also had a blast on the EZ footer....I want him to move to the boom, but he wants to remain on the swivel...he is comfortable there....
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 2:09pm
Valentino ripping it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 2:10pm
Now that i see the picture looks like I need to lower the boom...
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2016 at 2:12pm
Cool shot and exciting
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2016 at 3:07am
Seb, with the kids in the swing I tell them do one foot, the other foot and then hop...they will learn alot...don't lower the boom much...he could push his arms out and bend knees more but just make handle a little longer and keep boom there
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2016 at 2:34pm
Good advice Andy! Yes is doing both one foots!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2016 at 1:15pm
Ice off. First trip out after turning 50........at about 23 second mark it looked and felt like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lcgordon Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2016 at 1:28pm
awesome crash and man thats some good water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2016 at 1:34pm
look down go down awesome friggin' crash
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2016 at 2:15pm
Watching that crash hurt my also over 50 neck, ugh
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2016 at 8:55pm
If you did not see stars I saw them for you
