leaks on boat any ideas???????? |
darkone ![]() Newbie ![]() Joined: November-04-2004 Location: United States Status: Offline Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: November-15-2004 at 8:26pm |
while fishing the other day i noticed water leaking into boat we fished approx 5 hours and picked up approx 2 gal of water could it be leaking around seals or shaft boat shows no cracking or holes but has some leak somewhere any ideas plz post ty
captan1 ![]() Senior Member ![]() Joined: June-02-2004 Location: United States Status: Offline Points: 180 |
I know I have a leak in my 78 and I'm guessing it's my mufflers/hose connections, under water while still. I rebedded with 3M 5200 all the underwater intrusions into the hull last summer, the only other spot I need to check soon is the rudder packing, probably notorious for neglect.
Rick ![]() Senior Member ![]() Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
I have a leak in my 2000 SN. I thought it was the steering gear but after repacking it continues. I now beleive it is from a drain plug in the muffler that has poped out or the muffler has worn a hole in itself. Unfortunately you have to remove the whole back end including the gas tank to access it.
dark one ![]() Guest ![]() |
i think the leaking could be coming from around the shaft or the speedomiter placment the boat is a 66 mustang and i don't belive anything has ever been resealed ty
Repacking thre shaft is really easy. You should have 1-3 drips a minute from the shaft when running to keep it cool. There are several articles on repacking on this site. Just do a search.
