  New Posts New Posts RSS Feed - Another breather hose question
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Topic: Another breather hose question
    Posted: January-13-2007 at 4:15pm
On my '90 PCM, I have a breather hose coming off the starboard valve cover, which connects to the flame arrestor. The port valve cover has a PCV valve, which is plumbed to carb spacer.
To make sure my roller rockers will clear (and because they look cool), Ill be installing new valve covers this spring.
On the new valve covers, the cut outs for the oil fill/breather hose are on the opposite side compared to the stock PCM covers. Does it make a difference which side the breather is on vs. the PCV? Ive seen it set up both ways, so I imagine it doesnt matter, but it doesnt hurt to ask.
I could always turn the spacer around so the PCV port is on the front, which would allow me to keep the PCV on the port side without running longer hoses. If it makes no difference, Id like to put the PCV on the starboard and not remove the carb.
I should now be able to close the motor box AND keep the 1" spacer with the new low profile flame arrestor* I just picked up.
*You wouldnt imagine the trouble I went through to find this flame arrestor! Thank you to everyone who I asked/harra$$ed to swap with me, and to those who helped me with my search!
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 8:43am
Tim,
Will those taller covers clear the exhaust ok?
92cc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 92cc Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 9:40am
It does not make any difference which side the breather and pcv valve are on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 10:43am
Thanks 92, thats what I suspected.
Alan, these VC's are still considered "stock height" so there should be no problem clearing the exhaust manifolds. I think there would only be an issue if one were to install the "tall" style. I believe AWhite70 and a few others have already installed these with no problem.
The RR's may have fit under the stock PCM's, but they will definitely fit under these, hence the switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 12:42pm
Not to mention they're an awesome looking cover
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 5:52pm
TRB;at one of the schools i went to,either Yamaha or Mercruiser,one of the students asked a question. The "teacher" answered with a very good point.With that answer many times i have relived that day in the cla$$room.His reply was "DOES THE MOTOR KNOW".There are lots of "things a motor knows,Spark,Fuel,Timing and a host of other variables. but it don't know or care where that hose is connected........ boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2007 at 6:52pm
Thanks for confirming my suspicion Doc. I couldnt think of a reason it would matter, but Im far from an expert. I had seen it set up both ways, but it seemed that RH PCM's have the PCV valve on the starboard, the LH on the port. Just a strange coincidence, I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2007 at 12:46pm
never knew valve covers where direcional, guess mine are bolted on backwards...NOT.
makes no difference which side it is on for the VC's or hoses
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2007 at 6:33pm
I put roller rockers on my Mustang about 8 years ago. You'll probably notice a big difference in the mid range power. I had to go with taller covers too. The bottom side toward the exhaust is tricky to screw down.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2007 at 8:20pm
79, the question was about the hoses,PCV on port or Starbd. TRB had a good question, and did it make a difference where they were installed? Just him an answer, the facts about yours are null and void.
Whats the deal about you putting yours on backwards?
We just ain't as smart as you 79, but we will keep on wishin'.............boatdr
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2007 at 9:21am
'doc, come on. That was probably the nicest post '79 ever had, he definitely could have layed into TRB but didn't. I think he deserves a little credit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2007 at 9:25am
Found this quote (from Feb 2004) yesterday while doing a little searching. Found it amusing.
Originally posted by 79nautique 79nautique wrote:
Will I guest I missed where this is a Correct Craft mechanic's/technician's forum. I thought it was for correct craft fans. Most of the post are from average joe's working on their on boats because they take pride in doing thinks for them self's. SS-102 you have a lot of valueable info but with it does come a lot of attitude. We all can not be former racers or have friends that build boats and incorporate your Idea's.
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2007 at 10:43am
Very amusing.
99
