CCF FAQ |
Post Reply | Page 123> |
Posted: October-09-2020 at 12:02pm |
Matt,
Some call the paint mask stencils. The sign shop will scan your tracing, clean it up on their computer and then cut the mask out of a special vinyl. It's the "negative" of how they would cut out say a letter.
80NautiqueNC
Newbie Joined: October-08-2020 Location: Charlotte, NC Status: Offline Points: 3 |
apologies that those are so large...
80NautiqueNC
Thanks for the feedback and glad I didn't start the sanding. I've added pictures of the boat. When you say 'paint mask' can you elaborate?
Matt, First, welcome to CCfan. Great to always get new members. Pictures are also welcomed. Before you do anything, undersatnde the hull side graphics are paint so chanches are very good they will not make it through a wet sanding and buff. Get a full size tracing of the graphics so a sign shop can scan the tracing and make a paint mask then you will be ready for new paint.
80NautiqueNC
Longtime reader here, first time posting. I've got a 1980SN that's got heavy oxidation. The stripping and lettering down the sides of the boat are 'raised' in the sense that I can run my hand over them and it isn't completely smooth. If I wet sand, do I run the risk of removing/damaging the SN lettering? Or is the wet sanding light enough that it will not do harm?
AlfaDon
Senior Member Joined: September-18-2011 Location: San Leandro, Ca Status: Offline Points: 407 |
Great work Kevin. The first video of Pete is a classic and helped me a lot!
KRoundy
Added a link to the great write up about shaft straightening, bearing installation and packing too. All with beautiful photographs. A true FAQ gem.
KRoundy
Hey - How did the FAQ become un-pinned?
KRoundy
Added the alignment how-to video. Not sure how / if to paste these pictures about engine rotation into the FAQ up front?
DrCC
Grand Poobah Joined: April-12-2004 Location: at home Status: Offline Points: 2868 |
For the twin engine fans.
Tim's great illustration of engine and prop rotation:
KRoundy
Added in the second grouping next to another shifter thread.
KRoundy
Added, Pete. That is very good stuff to understand how you can easily over-fill your engine with oil!
Nautique
Newbie Joined: July-23-2015 Location: California Status: Offline Points: 2 |
I use benzworld.org for my older car just like one might use CCF.
They have forums organized with "sticky" threads about procedures broken down by makes, models, and years. It's obviously way more detailed than what we need but it gives you lots of ideas for structure. Suggestion for dealing with logistics of building new threads would be leave current as is for now…… just construct new thread offline when finished just replace old with new. Hope it helps |
KRoundy
Done Rain Dog. Good addition.
I've been thinking about organizing this FAQ in some way, but it would be a ton of work. I'd like to create "sections" so it is easy for people to search. One section on Structure (stringer, gel coat work), another on Engines, one on regular Maintenance, one on Other stuff. I'm not sure how to do that without tearing down the FAQ and building it back up from scratch. Any thoughts or helpful advice? |
RainDog
Can I nominate the one time I was helpful to the site?
Strut bushing insertion tool http://www.correctcraftfan.com/forum/forum_posts.asp?TID=5931 |
KRoundy
Added a link about bearings for trailers.
KRoundy
Pete - what do you mean by an index? -Kevin
Kevin,
We're going to need an index to the FAQ thread! Then we'll ask Keith to insert it as the first post. |
KRoundy
Added another trailer restoration thread with information about bunks, side steps and spare tire mounts.
KRoundy
Thanks, Pete. That is a great write up. I added it.
Unless I missed it, here's the thread HW just pulled up - detailed 89 trailer restoration.
KRoundy
Woo hoo!!!! Sticky Baby!!!! :)
Added carb rebuild thread above. |
Bri892001
Here's another good Holley rebuild pictorial write-up from a while back:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24175&PN=1&title=carb-rebuild-88-2001 |
boardersdad
Senior Member Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
It is now a sticky!
Thank you.................... |
KRoundy
We have asked this a lot, but so far have not been able to get the request to "stick". |
boardersdad
Please make this a sticky... most important thread of all!
Bri892001
A good post by mamigacz on how to remove the primary fuel bowl:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=34538&PID=444268#444268 |
