  New Posts New Posts RSS Feed - Installing Drain Plug
piemat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piemat Quote  Post ReplyReply Direct Link To This Post Topic: Installing Drain Plug
    Posted: April-10-2016 at 9:04pm
Recently purchased a 1979 Southwind 20.
The boat doesn't have a drain plug to let water out. Is this common for Correct Craft boats? Does anyone have any insight on installing a drain plug?
I've looked all over the bottom back end of the boat and I cannot find a plug.
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2016 at 9:50pm
I'm not familiar with your boat but mine is in the center of the boat just in front of the engine.
LaurelLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2016 at 9:51pm
While I'm not sure on your Southwind, most inboards have the drain plug in the bilge. You'll likely find a threaded plug (with a "T" handle on it) going through the hull somewhere just in front of the engine. The plug can only be used while on a trailer or lift, not while underway as you would with an outboard that has a drain plug in the back of the boat.
The world is full of youth—what we need is a fountain of smart!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2016 at 10:14pm
Piemat,
Your Southwind has a garboard drain. Per Webster, a garboard is: "the strake next to a ship's keel" or IE, close to the center of the hulls bottom. The lowest point in the bottom is just forward of the engine. Previously, have you been running I/O's or O/B's?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2016 at 10:35pm
On some inboards, they just simply forgot to install the drain plug fitting.
We had to dealer install the fitting
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-10-2016 at 11:03pm
Pie - Welcome to the site!
Hope you enjoy your boat.
These guys know their stuff & will help you maintain it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2016 at 8:24am
Piemat,
I've been neglecting my duties! We always ask for pictures. We'd love to see some. Congratulations on the purchase and welcome to CCfan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 11:08am
Piemat,
Did you find it?
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 11:17am
Does not get much easier than this. (E-bay item)
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 12:13pm
Duane,
You've got to keep it original!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 12:55pm
Wait, wouldn't "original" be not installing one at all?
Post Options Post Options   Thanks (0) Thanks(0)   Quote piemat Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 3:40pm
Finally had some time to get to the Boat. It's been in storage and is making its way out! I did find the plug under the engine. Unfortunately, the roof leaked and it took on a few inches of water. The boat had some issue with firing when I put it up last fall so, now I'll start that troubleshooting process. I'm not sure what engine I need to order parts for. The water pump on the front of the engine has the ford logo and the valve cover says PCM 250. The engine Id tag says ERD WRR10. Is that enough clues?
Thanks for your help.
I'll get some pictures up soon.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 5:04pm
So, where was the plug ?      In the keel, or to the left of the keel ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 5:07pm
Piemat,
Sounds like you have a 351 PCM. For parts, Skidim, N3 and Nautique parts are great sources. I suggest a basic tune up to start and then before just throwing parts at it, do some diagnosing first. Great you found the garboard drain! Have you been running I/O's or O/B's previously?
BTW, it's a good practice to remove the drain plug during layup.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 5:12pm
In addition to Pete's post, It may also be helpful to get the numbers off of the distributor for the correct tune-up parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 6:31pm
ERD would imply it's an Escort (after PCM acquired them). Pete is probably in the best position to know what other PCM parts cross to it since he has one in his Tique.
Post Options Post Options   Thanks (0) Thanks(0)   Quote piemat Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2016 at 12:19am
Needs work, but I think there is still hope
Blamey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2016 at 1:26am
That looks like one hell of a tower. The boys on this site are gonna want more pics of that
Otherwise a nice looking boat.
96 Super Sport
