Overheating, water temp sender? |
O.L.DBoat
Newbie Joined: July-28-2015 Location: Minnesota Status: Offline Points: 16 |
Posted: June-07-2016 at 5:46pm |
anyone replaced a water temp sender before? i have 1500 hours plus on my 88 ski nautique. I've owned it 5 years and the hour meter hasn't moved. idling in the driveway running 40 degree water from the garden hose for an hour the temp gauge says 180. it did climb to 190 before the thermostat opened for the first time. the impellar and thermostat are new last summer. Im thinking replace the water temp sender and try again. I paid 160$ two years ago for winterization and upon initial startup last summer i saw the dummy forgot about the tranny cooler. It froze and split the solder so it did get warm last summer but i immediately shut it off and let it cool, fixed the tranny cooler and it ran like a top all last year. i kept a close eye on the temp and it did seem like it was consistent reading 180. hoping its just the water temp sender anyone know the specific part number?
O.L.DBoat
Theres more. i couldn't find the 1" port tranny cooler so i got the 1.5 " port tranny cooler. i just got some reducers to plug it in to the 1" system. could this be part of the problem?
The larger tranny cooler is not a problem, however the 1" shouldn't have been hard to find... The added fittings and joints are more places to pull air, which would result in a warmer running engine.
Senders are cheap but I would also be doing some verifying of the actual temperature skidim temp sender |
O.L.DBoat
copy that couldn't find my infrared gun yesterday. got er now going to run it in the driveway right MEOW
O.L.DBoat
infrared gun says its 108-130 degrees right at the water temp sender. the top of the intake manifold runs from 100-118, the ports at the bottom of the exhaust manifold got up to 348 but mostly stayed down around 200, tops of the exhaust manifold read a real cool 68 degrees. the oil filter read 120 at idle, revved up the oil filter read 158 degrees. hose water was 48 degrees air temp is 70 in the shade. i think a new water temp sender will read more accurate because the gauge was reading 180 the whole time
O.L.DBoat
and yea can't remember why i had such a hard time finding the 1" tranny cooler i know about skidim musta been using the wrong lingo
O.L.DBoat
any advice on replacing the water temp sender. I see its brass and its been there for thirty years. should i use some dope on the threads being dissimilar metals and all. i just have this image of me shearing that brass and having a hole in the top of my motor that id have have a pro fix.
Jeff,
Before you start throwing parts at the problem, what have you done to determine the sender is bad? Have you cleaned all the terminals and connections in the temp gauge circuit? Added resistance will cause a higher than normal reading. Have you checked to see if you are getting a decent 12 volt nominal to the gauge? Again, bad terminals and connections add resistance causing a voltage drop. Also known undersize wire to the dash. NO thread compound or tape of any kind on the sensor pipe threads. That's the ground source for the circuit!!! |
O.L.DBoat
Thanks 8122pbrainard I have noticed the whole time I've owned the boat the voltmeter no the dash reads pretty low.
Bri892001
Sounds like you're on to something with the low dash voltage. Does the temp gauge seem to read hotter if you turn on the nav lights, or other electrical accessory?
O.L.DBoat
It absolutely reads way hot when the nav lights go on, nearly gave me a heart attack but I'd heard on this forum that happens. Is it the small wire gauges that cause that or do I have an alternator issue? This is something I knew I'd have to dive into
Actually it is corrosion of the existing wire and connections. If they had used a larger wire to begin with it would have had extra capacity but being most likely on spec at the time, now causes trouble.
