  New Posts New Posts RSS Feed - Bad starter - replace (URGENT)
rmaytee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Topic: Bad starter - replace (URGENT)
    Posted: June-23-2016 at 9:25pm
I'm at the lake for a camping boating trip and My 2000 SAN wont start. It has struggled to start all season. It takes 1-12 times of pushing the start button for it to actually turn over. Today when I went to launch it wouldn't start. Wouldn't turn over. Now it keeps popping the breaker, and occasionally blows the in line fuse at the battery (ignition wire?)
I'm thinking the starter has gradually been going out, and now the solenoid is causing it to short out/blow fuse. So you agree with my hypothesis? I'm going to pull the starter and send a pic to the dealer and see if they have a match that I can go get in the morning and try to salvage the rest of this trip. How difficult is the job?
Y2K SAN
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2016 at 9:42pm
Tim,   I am not sure if your san is a V drive or not, but that may complicate the removal/install. If you are pulling the starter, I would run it to the nearest autoparts store and have them test it before buying a new one, it should be similar to the auto version for testing to see if it spins/engages,   You could have a wiring problem, instead of a starter problem.    any chance you have a multimeter there with you?   Battery voltage and main electrical cable would be a good place to start and would help us with the trouble shooting portion
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2016 at 10:51pm
Definitely start withmaking sure your connections are clean, ALL grounds, and battery terminals. you want to do that regardless if the starters bad or not. If your blowing the main breaker is a sign of something wrong. I worn out starter will do that if its bad enough but it would take a lot of pushing it to do so.
a napa might have a RR starter if the dealer does not.
1988 Barefoot nautique-454
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2016 at 12:43am
Tim,
Without testing, you are simply guessing at the problem. Start with what been said above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2016 at 3:25am
Thanks. I was unfortunate enough to be getting to this as the shops were all closing down. All battery connections look good. I even simplified it by disconnecting the second battery and didn't include the amplifiers. Same problem. I pulled the starter and will make the hour trip from our camp to the dealer as the crack of dawn. I like the suggestion to stop at an autoparts store for testing. I will do that On my way.
Y2K SAN
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2016 at 6:30am
You can test it yourself if you have jumper cables. Starter out of the boat. Black cable to - neg side of battery and to the starter case.    Red cable to + pos side of battery. Touch end of red cable to nut on the starter stud. If it is good it will run (and jump a little) . Take a picture of the starter solenoid on the back of the engine (assuming it is a Ford) and that will help the parts guy in case the starter is OK.
As Pete would say: Use your V.O.M. and check it out. Harbor Freight and others have a 12 volt test light with alligator clip on end of cord. Looks like a lighted ice pick. Should be in everyone's tool box on boat
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2016 at 12:50pm
Starter was fine. Now I don't know what to do. Just trace wires I guess.
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2016 at 6:35pm
Tim,
Get the VOM out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2016 at 1:09am
What's the VOM
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2016 at 6:37am
What's the VOM
Volt Ohm meter
Originally posted by Dreaming Dreaming wrote:
Tim,   any chance you have a multimeter there with you?   Battery voltage and main electrical cable would be a good place to start and would help us with the trouble shooting portion
Sounds like you will need some help.. Start with getting voltage readings from the battery back through the start relay (solenoid) to the starter during engine cranking. Report back as to what you find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2016 at 9:40pm
I dropped the boat off at the dealer and they are saying there is a second solenoid not attached to the started that they think is the issue. There is a second solinoid? Anyway, part has been ordered. Hopefully this works.
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2016 at 9:44pm
Originally posted by Duane in Indy Duane in Indy wrote:
   the starter solenoid on the back of the engine in case the starter is OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2016 at 11:43pm
Well. 8 days into the Nautique dealer and they determined it was a starter relay. $650 and they said it's all fixed. Wife brings the boat home and I get home from work and test start it in the driveway and it only clicks. Doesn't even attempt to start. Starter just clicks like a silenced machine gun. Just to rule out the possibility of the battery not having enough juice, I pull out the charger to top of the batteries, and the hatch doesn't open. It just clicks down in the breaker box area. No breakers have popped, but nothing happens when I try to open the hatch.
Never been more frustrated. I feel like I'm at the same place a week ago, only $650 more in debt on my credit card.
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2016 at 11:52pm
2 minutes after my last post, I decided to look and see if there was some way I could jump some power to the hatch by my perko switch. Wouldn't you know it. The perko was switched off. Turned it on and it starts, and the lift works. I never turn off my perko. I just use the silver switch under the breaker panel. Quite embarrassed, but relieved I didn't run my truck and boat through the shop window like I had planned.
Y2K SAN
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2016 at 11:56pm
victory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 4:56am
On a related note, so you all recommend that I turn off the perko switch after each day of boating, or is it sufficient to just leave the perko on and turn off the silver switch under the breaker panel?
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 8:34am
Originally posted by tryathlete tryathlete wrote:
victory.
Let's see, 650 bucks to replace a solenoid that probably cost about 30 bucks..
That's a victory alright..................for the dealer.
Pete had him on the right track before it went to the dealer
Hope he had more done than that
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 9:38am
Acting in haste can cause it's own problems and this one was $650 worth!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 11:45am
Agreed. I didn't really understand that relay was a separate solenoid than the one attached to the starter. I'm not much for electrical testing, but I suppose it's time to get learning. Sad about the cost, but super happy we're up and running.
Y2K SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 12:16pm
When your in a hurry to fix something for the sake of vacation or a upcoming trip (I think we have all been there) It's always a recipe for mistakes and overlooking the simplest of things.
When you get stumped, sometimes you just have to hand it off to someone else in the name of progress.
I wouldn't feel bad. just a lesson learned.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 12:23pm
+1
We've all been there before.
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 12:49pm
Anyone here would tell you a backup boat will cost you a heck of a lot more than 650 but yet many here have more than even 2. Just forget about it and go out and have fun!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 1:47pm
Keep in mind the dealer tech had to start from scratch in the troubleshooting diagnostics. Plus testing time on the lake. This takes longer when it's a nice day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 1:48pm
Originally posted by JPASS JPASS wrote:
+1
Tim,
As JP mentions, we have all been there. I sure have many times. It's great it's running so go out and enjoy the water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmaytee Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2016 at 2:29pm
I agree everyone. I'm stoked to get back out. I do plan to keep this boat for a while, and as it gets older, I'm sure this isn't the last episode I have, so it will be good to learn more about it as I go.
Thanks everyone for the kind words and the advice. I love this community.
Y2K SAN
