  New Posts New Posts RSS Feed - Prop shaft hull housing
sterlingmermaid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Topic: Prop shaft hull housing
    Posted: August-08-2016 at 8:33am
Hi I am replacing a broken shaft where the shaft comes through the boat a chunk of rubber is missing not sure what to call it to order new one with every search it talks about strut bushing
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 8:43am
Terrence,
You'll need to be more specific regarding the chunk of rubber. The prop shaft runs through the hull log. On the log there's a rubber hose forward where the shaft stuffing gland is attached. The shaft isn't supported by rubber inside the log. Then at the aft end of the shaft near the prop, there's the strut that supports the shaft. Inside the strut, there's the cutlass bearing. It's typically a rubber lined "bearing". Which chink of rubber are you looking at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 9:06am
No this is where the shaft comes thru the hull brass fitting with 4 screws the shaft sheared at that point and damaged the rubber around the edge. I tried to post a pic but it wouldn't let me
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 9:20am
Terrence,
Try posting a picture again. Use the "post reply" and not the "quick" that's at the bottom of each thread. Click on the icon of the tree with the up arrow. A brose box will come up allowing you to select the picture off your computer.
The only component with 4 screws I can think of in that area is the actual shaft coupling where it bolts up to the trans. But, unless someone put a rubber "trans saver" on it, there's no rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 9:31am
This is under the boat part of the shaft log but on the outside
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 10:14am
All you should see on the hull bottom where the shaft exits, is a hole. Again, the shaft is not supported at the log. No rubber!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 10:23am
It's a brass hole with rubber sleave
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 10:35am
It always helps to tell us what year,model you have. Are you talking about something like this-
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 10:45am
Terrence,
I looked at your previous posts and did find you referenced a 96 SN with the broken shaft. Is this the boat you are talking about in this thread?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 11:02am
Yes 96 ski Nautique
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 11:03am
Yes that's it
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 11:21am
That's the log You'll have to call a dealer,but since your profile says United States that leaves a pretty big area. I guess our site sponsor White Lake would be your best bet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2016 at 12:47pm
Ok thanks
tk
