  New Posts New Posts RSS Feed - 2007 SAN236 Not Charging
kylem428 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylem428 Quote  Post ReplyReply Direct Link To This Post Topic: 2007 SAN236 Not Charging
    Posted: August-14-2016 at 10:51am
So we dropped my cousins boat in the water yesterday. Anytime I can remember it the gauge showed over 14 v when running. After turning on a ballast pump, I watched the gauge drop to 11.8. Confirmed this on the tac digital read out also. While running, I Checked voltage at each battery. Each was at 12.1. Isolation switch was on 1+2. Checked voltage wire at alternator - 12.1. Checked voltage at alternator output - 12.1.
Shut off engine and did the same. Voltage was +.2 volts all the way around.
My thought is that the alternator is smoked and that's where I need to start the diagnosis.
Thoughts??
Kyle
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2016 at 2:55pm
If the Alt is shot check over on PN, seem to remember seeing an ad recently for a new or lightly used one that should be a direct replacement.
Have you checked with your local NAPA to see if they can test it for you??
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylem428 Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2016 at 9:55pm
Took the alternator off and in to Oreilley to test. Failed. I guess I'll be ordering a new one from nautiqueparts.com!
Kyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 12:59am
Kyle
Kyle,
What was the specific failure? A diode bridge module is cheaper than the complete alternator!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylem428 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 9:44am
They didn't have the ability to specifically diagnose what went wrong. Any chance I can do that myself and order the part?? Where do I start?
Thanks,
Kyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 9:50am
See if Pete can walk you thru his repair, otherwise as mentioned here is a used one for sale
http://www.planetnautique.com/vb5/forum/classified-group-buy-section/gear-for-sale-by-owner/496377-alternator-100-amp-gm-pcm-ra097009-2005-on-5-7-and-6-0l
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 10:14am
Kyle,
It sounds like the auto supply simply checked the output, didn't get a good result and simply called the alternator bad. There are plenty of online videos that walk you through both testing and repair. They show and explain way better than I could in words. Complete kits are available for total rebuilds.
A couple example kits:
If you do consider a repair and do find the diode bridge is the problem, then they are available as a simple assembly. Here's one example:
Yet another option is to take the alternator into an "automotive electric" shop. They will test, determine the exact problem, install the needed parts or do a complete rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylem428 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2016 at 10:32am
Thanks Pete and Quinner. I missed that used one in Quinners original post. I'll probably pick that one up and then take some time to see if I can get the original back to functioning.
Thanks!!
Kyle
