  New Posts New Posts RSS Feed - Engine drain plug
Engine drain plug
leftseat88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Topic: Engine drain plug
    Posted: September-19-2016 at 10:59pm
Evening All,
I have a 96 Sport with the GT-40 with EFI. While winterizing, I managed to strip the threads out of the "block" on the Starboard brass drain plug. Not only are threads gone in the block, the threads are pretty much done on the plug. Has anyone done this before and how do I fix it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2016 at 11:01pm
Drill and tap to 3/8 NPT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: September-19-2016 at 11:04pm
Wow, that was fast, thanks. Any idea where I can find the new brass plug. Can I assume I need a brass plug?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2016 at 6:47am
Home Depot!
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2016 at 6:57am
McMaster Carr sells brass pipe plugs Another alternative could be to use a Stainless Steel Hex Nut Expansion Plug for 7/16 Pipe Size $6.87 Each #2599K27 (tap drill size for 1/4" pipe is 7/16")
I recommend using Petes answer, but not everyone has access to or knows how to drill and tap a block with the engine in place.
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2016 at 8:46am
I would run a 1/4" npt tap through the hole first, the tapered pipe threads may allow you to save it without upsizing. Any hardware store will have the plugs- go with brass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2016 at 9:08am
I like the way Tim thinks, definitely worth a shot, it's worked for me and at other times it hasn't Nothing to lose doing this first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2016 at 9:38am
I too like the idea plus, brass male fittings have a tendency to run oversize so with just chasing the block, it may work.
