  New Posts New Posts RSS Feed - Oil Extractor Pump Recommendations
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Topic: Oil Extractor Pump Recommendations
    Posted: October-04-2016 at 10:46am
Looking for Oil Extractor Pump Recommendations. My Suck-Up pump is about 20 yrs old and has seen better days. It was a great pump however appears to be NLA.
Prefer vacuum style, searched online and the descriptions all seem a bit vague, ideally something that includes a hose that can go down the dipstick and the trans, in a perfect world including an adapter that could screw on the drain hose end would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 11:51am
Chris,
I have the Mityvac 07400 which is now model MV7400. It comes with all the different size hoses. I only had a problem with it once when the vacuum check valve at the bottom of the hand pump pugged up with sludge. I called Mityvac to find out if they had been having problems with the check and they told me to drain the reservoir after each use. I had left it sit partially full so the sludge settled to the bottom.
Mityvac
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:04pm
Dad, Rico and me all have mityvac's too. Dads old suck up finally gave up the ghost.
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:12pm
62wood let me borrow his Topsider Oil Extractor when I changed the tranny fluid last season. It worked well, I didn't like that I couldn't tell how much was extracted though. I can see how the Mityvac would be better in that regard.
-Spiral
'89 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:50pm
I got the Topsider because of its lower c.g. and wider base (less likely to tip over) but totally not thrilled with it. You should definitely buy the mityvac instead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 12:54pm
We've got the MV7400 and I'm very happy with it. Works fast and is easy to handle, no spills. Fits in confined places. Found it on sale at West Marine for $50.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2016 at 1:12pm
I've been using the Pela 6000 for years now. Works great.
'92 Correctcraft Ski Nautique
OldSchoolBlue84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolBlue84 Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2016 at 12:31am
+1...been using it for a couple of years and gets the job done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2016 at 2:23am
Deleted
Blamey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2016 at 11:33am
I have the topside, only extractor I have every used. Worked fine the one time I changed my Trans Fluid.
Guess I should've ponied up the extra $20 for the Mityvac but when you are bleeding money during your first year of boat ownership you gotta save some dollars somewhere.
96 Super Sport
chuckactor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuckactor Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2016 at 6:05pm
I have had great luck with my Pella PL-650. Also works great on cars with belly pans.
Chuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2016 at 7:21am
[QUOTE=quinner] Looking for Oil Extractor Pump Recommendations. QUOTE]
Chris,
Have you decided and purchased yet?
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 11:48am
Dumb question alert!
I've used these things unsuccessfully in the past. Always felt that I wasn't doing something right as the amount vacuumed seemed unsatisfactory given the work involved.
New boat is going to require me to use one of these and I've ordered the Mightyvac 7400.
I know to get the oil to operating temperature, but here's the dumb question. Once I get it to temp and begin to extract, are you pumping the entire time or does the siphon/vacuum eventually kick in and it sucks itself out?
With regards to lowering the suction hose into the dipstick tube, do you simply push it in until it stops an then pull back every so slightly or what? Also, does there need to be a seal around the suction hose and the dipstick tube? I'd think not, but just checking since my previous results were not good.
Are you guys able to pull out 4-5 quarts with these pumps?
Steve
2011 Sport/Air 200
Excalibur 343
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:19pm
If your new boat still has the oil pan drain hose it is best to connect to that. It won't siphon,maybe it will if it's lower than the engine but I change them all from inside the boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:30pm
+2 for the MityVac. I have the MV7300 Pneumativac and use it for various fluid extractions. Great tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:32pm
Gary, I like this idea. Does the pump come with adapters to fit the oil drain hose? The boat does have a hose, there's just no hull plug within 6' of it.
Steve
2011 Sport/Air 200
Excalibur 343
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:36pm
I got a barbed hose fitting that is the same threads as the drain hose in the boat and connected it to the vac's hose with a a rubber hose-
To remove oil from the trans or v drive I connected a short length of brake line to the vac hose-
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:39pm
Getting the fluid warm for better flow is critical. Second, you need to select the proper tube diameter. Some tubes don't fit properly and won't reach down far enough into the fluid reservoir and then only extract part of the fluid. Allow proper venting so that the vacuum isn't fighting against another vacuum.   When doing PCM transmissions, some connect a small flexible piece of copper tubing so that the tube/hose gets all the way down into the fluid reservoir. Just don't let the copper tubing fall off inside the tranny! I have had to push and twist the plastic tubing to get it to go all the way down sometimes. Also, I make sure that the end is not cut at 90 degrees, so that there is not a vacuum block between the hose end and the bottom of the pan. I cut the ends on a 30 to 45 degree angle.
Yes, I can pull out 95% of the fluid in most cases.
Keep in mind that some high end cars (Mercedes/BMW) recommend fluid extraction as the preferred method vs. drain pan and pulling a plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:42pm
No Steve I just happened to have on hand of what I needed,but any good hardware store should have what you need. I just remove the engine oil from inside the boat,my Nautique lives all year on the lift so I can't do it from outside anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2017 at 12:59pm
Thanks guys. All good comments
Steve
2011 Sport/Air 200
Excalibur 343
