  New Posts New Posts RSS Feed - PROPS
PROPS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 1:49pm
Why would I put anything but a bronze prop on a 1915 boat with a 1927 engine?
You should go with stainless, the flexing of the bronze prop when you channel those 15 HP through it will kill performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 2:59pm
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 3:26pm
Pete have you actually been working on the launch or are you thinking ahead on the prop? Start a thread on it if you have some wood working done please. I'd like to see what you're up to.   In the "off Topic" section of course.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 4:27pm
Sure he came to sell props but we are going to fix his Sanger. What Sanger does he have? What's wrong with it?
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 5:13pm
??? Did I miss something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2016 at 6:43pm
Yeah I guess...see page 1...propguy has a specialty in barefooting and a Sanger with something wrong with it...maybe backfoot fixed it
This is the life
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 10:56am
Hey Andy,
His Sanger is an '88 DX with a 260 Mercruiser. Nice boat but it definitely could use some more ponies. It's either WFO or nothing for footing. Even then it only tops out about 40-41 with a footer in tow. A couple more MPH would be really nice. Gorgeous boat though.
It had sat for some time because he gets pretty much all the skiing time he wants as part of the Gardens ski team. It just needed a good tune up which I did. Wires, points, plugs, cap, rotor, condenser.
It would start and idle perfectly and we ran it around the lake for 15-20 minutes. It ran great.
A week later he called me and said he was out driving a competitive trick skier. The boat ran great for about 30-45 minutes and then started missing really bad. It had rough idle, stumbling and finally die. He managed to get it back to the dock and let it sit overnight before he would look at it again. The next day he was amazed when it fired right up and it ran perfectly again for 30-45 minutes and the whole thing started all over again.
In trying to get the boat back to the dock after one of these outings, he left the key on overnight which burned out the points and messed up the starter solenoid so I replaced the points again and replaced the starter solenoid.. I also removed, tested, cleaned and coated with NO-OX all the ignition wires from the starter switch, solenoid, starter, battery and wiring harness. I wanted to make sure that there were no wiring issues causing this problem.
He had also loosened up the gas cap when this happened to make sure that the vent hose wasn't plugged. He removed and cleaned out the anti-siphon valve which was perfectly clean also eliminating fuel delivery issues.
We were kinda baffled and I found a tech note online from Mercruiser about vapor lock issues on these engines. Mind you, I've never been a big believer in vapor lock as I've personally never experienced it so I was skeptical.
We arranged to meet after work one day and see if we could get it to happen while I was with him. Remember, at this point I had not experienced any issues at all. I had tuned it and run it for 15 minutes and it had run beautifully. When I got there, he had everything cleaned out of the boat and the engine cover removed so we had no obstacles working on it.
We beat the snot out of that thing for an hour and 20 minutes and didn't get so much as a hiccup out of it. It ran perfect with my only objection being it needs more ponies. The only thing I could possibly come up with was the vapor lock theory when the engine was installed.
We found the air hoses from the deck air scoop to the bilge were rotted away and not allowing proper air flow through the bilge. I still contend that this single thing shouldn't cause vapor lock but what do I know. Then the next question is why would it now suddenly start to vapor lock when it has never done it before?
To date, I haven't heard if he has had any issues since ordering new vent hoses but I don't know how much he's used it either. So that's the long winded version of what's wrong or what was wrong with his Sanger.
WHEW!!!!
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 11:45am
Vapor lock was common on the early MPEFI mercruisers, same as the early (pre-FCC) gt40's. A hot engine compartment would cause fuel evaporation on the high pressure side... No provisions on those motors to keep the hpp, lines or filter cool- the fuel return came back to the filter housing (not the tank) so add some heat and remove the flow and you get some heat soak/vapor lock. Experienced this on my 502 mpi, solution was to crack the motorbox after running. Not a great solution.
I agree about the heat soak on a carb engine... Smells like BS. Check the fuel inlet screen on the carb, I've seen those partially plugged and cause strange issues (not necessarily symptoms like running out of fuel).
JD ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD ski Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 2:13pm
I had a car that was pron to vapor lock and the symptoms sound similar to what has been described. With the exception of the car would vapor lock while stopped in traffic (no air flow blowing through the motor compartment) heat would rise reaching the fuel lines and stall the motor. After it sat long enough it would start right up. Wrapping the fuel lines in tin foil and adding wooden close pins actually helped a little (looked horrible).
If the motor temperature is still normal vapor lock may not be the issue. Although as this boat has some years on it another issue could arise. I have seen water jackets in the heads rusted closed and the temp gauge remained normal. But probably not.
However, the boat issue sounds like it happens under load. You have checked all the normal issues with proper reasoning. The one thing I have not heard mentioned is moisture in the fuel. The boat is older and moisture can build up over time in a tank with condensation. I know you guys are aware of this but it has not been mentioned and this would happen under load. Something to look at.
At my location we see temperatures as high as 115 and as low as -20. Condensation problems are not uncommon. I do not know if this would be a problem in Florida. I store my cars and boats with a full tank of gas (less room for condensation) and Sta-Bil in the tanks. I also frequently add Chevron Techroline fuel injector cleaner to all my vehicles carbed or injected In some cases you may need to purchase specific fuel/water treatments found in cold climates.
JD ski, slicing, dicing, and shredding since 1981
1999 Air Nautique, GT40 Pro Boss, Trail Rite trailer
1975 Century Resorter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 2:49pm
Eddie, it would be interesting if your test run, thrashing the boat for over an hour without any issues, were repeated pretty closely with the motor box in place. If the problem occurred you'd be pretty well sure it was heat related, most likely vapor lock.
I learned about vapor lock in the '80's and I don't think I've seen it happen in the last 2o years, which would jibe with the age of that boat. A couple of easy fixes would be to run the blower when idling or stopped, and to look at the stat that's in it and if 160, maybe run a bit cooler thermostat to keep the engine heat down.
It would be nice if Rob checked back in to this thread. It's a free country and fine if he doesn't want to, but you can't be too thin skinned when posting online, have to learn to take a few shots and just roll with it, especially if you are looking to get a business going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 4:51pm
Eddie is that no-ox marine approved or telco approved
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 4:57pm
88 Sanger not 98. Should be carbed but I didn't get a look under the motorbox when he had it over.
Coil could be breaking down but you should have been able to repeat the symptoms. Eddie is no hack he would have been able to diagnose the problem had it reoccurred. All is well that ends well.
Hi Rob.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 9:16pm
Ken,
Deep Blue has the DJ355 bronze 12" for $364.00 The list is $473.00.
Rob,
Can you do better than Deep Blue?
PROPGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PROPGUY Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2016 at 10:01pm
Nope
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 10:31am
Hi Rob.
I said was an '88 and yes, definitely carbed with a Rochester which I know nothing about.
Forgot to mention that the coil is also new. From SkiDim specifically for Mercruisers. The old one was so corroded that terminals were almost unrecognizable. In answer to your next question, it measures 1.5 ohms as the original did and Mercruisers use a resistance wire instead of a ballast resistor. The coil gets warm but not hot by any means.
The fuel has also been replaced with new and new filter/water separator so we know that water in the fuel isn't an issue.. I had a two gallon gas can at the ready to swap in place of the fuel tank when we went for our test run but didn't have to use it so that aspect has not been verified.
All the evidence thus far does point to vapor lock but again, I'm still skeptical.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 10:48am
LOL...I'm sure it isn't marine approved but by far the best stuff I've ever used to prevent corrosion.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 3:51pm
We've run the old carbed boats in over 100 degree weather without issues. We've seen them "load up" upon stop and shut down and becomes necessary to open throttle wide open to start.
What prop does he have? My 260 would get 42 with a footer so it's really not too far off. But the rough running is strange given all that's been checked...maybe give the Rochester a kit.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 3:53pm
Of course there is the $9000 solution...a complete fi 383 Merc stroker 350hp....they plug right in.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 7:03pm
Eddie I know you know it's an 88. Someone started down the fuel injected road.
Crummy fuel tank? Does he normally run low fuel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 7:20pm
I don't doubt eddies ability to identify the year of the boat, but perhaps the year/applicability of the Merc bulletin? My point was to confirm that vapor lock is real, but perhaps the bulletin wasn't appropriate for the 88 vintage engine and perhaps it was meant for a mid-late 90's counterpart (possibly with the same name?). Perhaps Merc's service bulletins were engineered only as well as their engines.
seacamper View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 9:29pm
I guess I am Rob's first CCF customer. Here is the 542 he finished:
It turned out great. Thanks Rob.
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow
1988 Mastercraft Tristar Closed Bow
1969 Seacamper Houseboat
1986 Harris Pontoon
2004 Seadoo GTX SC + Flydive Xboard
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 9:33pm
Somehow I have ended up with a couple of big tubes and a small container of the stuff,have no idea from where can't always find it when I'm looking for it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PROPGUY Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 9:58pm
Seacamper (Tom) I wish we had a before pic, that one was a little rough, I guess all that time sitting on the bottom of the lake. Thanks so much for the business!!
      Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2016 at 10:39pm
      Rob
Here we go.
]pic 1[/URL]
]pic 2[/URL]
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2016 at 10:45am
Not sure what prop is on it Andy. As far as I know it's the factory one. My next thought would be a rebuild but again, I've never touched a Rochester.
Agreed on the 383 upgrade...LOL. I'm sure Rob would too.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2016 at 11:09am
Tim,
This is the service bulletin. As you can see it's from 2001. I know well after '88 but it does specifically say All Mercruiser 4,6 and 8 cylinder engines. It also does mention carbed and EFI in the content and does refer back to at least '96 model year engines.
So what years does it really encompass? I have no idea but all Mercruiser 4,6 and 8 cyl. engines does cover a pretty broad spectrum.
I guess the one thing that really jumped out at me was the air temps and ventilation in the engine compartment that is specifically mentioned in the service bulletin. This one detail ironically enough seemed to eliminate the problem once the engine cover was removed. Coincidence or just dumb luck? I have no idea right off hand. More info and testing is needed to verify the cause and effect at this point.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PROPGUY Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2016 at 11:47pm
Hi guys sorry for the absenteeism but I am busy running my business and don't spend a lot of time online. I'm surprised how this thread went from me "spaming" to you guys helping diagnose my boat. I appreciate all the input and theories, I haven't had it out since Eddie and I ran it without a issue I believe that the issue was/is the lack of fresh air into the engine box due to the fresh air hoses not working and getting good airflow into the box, causing vapor lock. Andy the prop I have on it is a OJ 13x13, it used to get 42 mph now its only 40 on GPS, I think I lost about 200 RPM (timing?) Yes the 383 would be an awesome upgrade but I don't have a spare 9k laying around. I will build a 383 at some point, probably a 400HP one. Thanks seacamper for the prop repair. Have a great weekend guys and thanks for the help with my boat.
    Rob (PROPGUY)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2016 at 10:18am
    Rob (PROPGUY)
That's just good old CCfan initiation hazing, Looks like you're in, Welcome
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 2:29pm
Rob I can help with a lot of info on that 88 DX...mine is a 90. One of the best things you can do is add the factory cavitation plate aka barefoot plate. It is the same one used on the DXII. Now here we get into some hull differences. An 88 should have an "original" DX hull ...the DXII hull has shortened lifting strakes see pitot mounting spot...the 88 hull should be like my 90 having full length strakes which has more similarity to the Sanger Outboard hull in design. Many DX's sit on DXII hulls...ive not seen a DXII on a DX deck though...the early 90's Sanger mixed and matched those lower hulls. So what does this all mean? It means your 88 with a plate and 400hp will have a wake as good or better than (in regard to barefoot wake slalom) a brand new 55,000 DXII. My 90 has a wake that hall of fame barefooter Willie Farrell calls it "too easy".
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 2:36pm
With 350hp I'm turning the original OJ 13X13 5100rpms which tows a big fat footer 47 mph and just at 49-50 no skier. I did run a 400 hp engine and it went more than 50 easily. But it blew up...do not order a motor from blueprint engines. That's another story.
This is the life
