Good CT Mechanics |
dawsonpriority
Newbie Joined: January-30-2017 Location: Southbury, CT Status: Offline Points: 20 |
Posted: January-30-2017 at 10:23am |
Looking for a good mechanic or repair shop for a 1990 Sport Nautique. I'm planning on installing a trim tab to improve the slalom and a few other minor repairs along with a hull buff job.
Any good suggestions around Southbury, CT? |
What leads you to believe that a trim tab will improve the slalom wake?
I don't know of anyone in our area that I'd trust to work on my boats. |
dawsonpriority
I've owned different boats throughout the years and always loved the old sports. I finally have one knowing that the slalom wake isn't as good as the traditional ski, but the entire family fits. Doing research about hull hooking and the technology behind the new boats, it seems if you can just lift the back end up a tiny bit it will remove the pop we get at slaloom speeds. They make a slick little 12x9 plate that will fit under the fixed ski deck allowing us to adjust it from the driver seat. It's a pretty easy install really, I just don't have the time.
I think you'd be better served to add a little weight to the nose, at least on a temporary basis. Much easier way to play around with improving the slalom wake without drilling holes. I suspect that trying to manipulate the slalom wake significantly may prove difficult on the semi-vee hull. The vee does not respond to weight like flat bottoms do, in my experience.
dawsonpriority
I appreciate your thoughts. I've done the nose weight and the vee design proved engineers correct. The deeper the v cuts, the more the water displaced and dropping the transom. Per some data and discovery, if you lighten the nose and lift the tail, overall weight should decrease wake. It's kind of a last result that will hopefully settle the pop. Not much would be a big difference is softness as well.
Perhaps I am not fully understanding... are you saying that adding weight to the nose and adding hook to the transom don't have similar effects when applied in moderate amounts? That has been the case on the flat bottoms, to some extent. Unless you're changing the overall weight or generating more lift through some sort of hull feature (either would raise the boat up higher in the water, reducing the displacement and thus the wake), then all you can really hope to do is change the hull's running attitude. Or perhaps manipulate the way the water converges behind the boat? Spreading the weight over more surface (forcing the nose down, and the transom up) should reduce the wake slightly... but I've found it hard to have much effect on the v-hull (this trick works well on flatter hulls). I'd be curious to hear what you've found if it doesn't align with that line of thinking.
bwinn
Senior Member Joined: July-13-2009 Location: ct Status: Offline Points: 396 |
Peter, welcome to the site! Where do you take that 90 sport? Most people I know around here do their own boat work. Being a seasonal sport up here id say boat mechanics are fewer and less skilled. If you have any desire to do work yourself there is a wealth of help and information at your fingertips here.
dawsonpriority
You're right. It isn't making the boat lighter, but adding forward weight to a v hull isn't helping like the flat bottom boats. It does change the attitude without having to displace more water in the front, the most v-ed portion, and a trim tabs wake from displacement ends up being eaten up by prop wash becoming softer. The lighter the chine and strakes rest at the very aft end, the best, but if you weigh down the front it seems to counter the efforts forcing hard edge wake lines from the keel like function of the hull's v stern. This wedge like effect of heavy boats don't draw under the stern so lifting it wouldn't matter. I like to think of it as balancing the majority of weight on the middle of the hull giving it the most splash with the least cut.
dawsonpriority
Hey Bwinn,
We are mostly on Zoar. Occasionally sight seeing on Lillinonah. I used to do all the work myself, but time is tight these days. I may end up doing this myself and I'm sure it would be fine. Just dreading the work in the cold driveway. |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
I would be careful adding a unknown device to that particular hull especially if you are family oriented.. Would hate for the boat to pick up any nasty tendencies for the wetted surface to find other ride attitudes . If I wanted a sport for slalom I would seriously consider moving out of the V hull boat and into a 93 or newer Sport... That particular Sport is kinda a black sheep and really does not do anything well except maybe evening cruise with sweetie!!!
bwinn
I hear ya on not having the time or ambition to work out in the cold. My advice is, before you decide to drill any holes, ask lots of questions here and make an informed decision. Trim tabs on that boat would definitely detract value to me and I'm sure others. Could you be masking a problem like wet foam? Zoar is nice. I've been down the last 2 seasons for a mini reunion and its always a blast!
dawsonpriority
A new boat is always a nice thought. I've missed the Ctmini's due to schedule, but I hear its a blast. I'll do some more homework and may look into a newer boat if anyone wants a 600 hour '90 sport for now, let me know!!!
I concur, if the family likes to slalom, you are blessed.
Get a boat that excels at any slalom speed and loading. |
