  New Posts New Posts RSS Feed - acme 541
acme 541
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Topic: acme 541
    Posted: April-09-2017 at 9:15pm
My neighbor has an 01 Supra Launch. Best I can tell the stock prop is an acme 541. He is checking his manual to verify. Thing is, his prop is at the bottom of the lake, so I am helping him source a new one. An outfit call wakemakers has it on sale for $379, no shipping. Do think that is as good as he is going to do for that prop? Do any better directly with Acme?
Looks like retail is like $469. Not that folks here are experts on Supras, but would someone have a basis for a different prop?.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2017 at 9:38pm
Larry one of the sites spinners,Delta Propeller lists it at 364.04 and we get 5% off when you use the code
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2017 at 9:39pm
Larry,
Hopefully we have a member who will know the correct prop but if not, there's got to be other sites that cater to Supra's??
If your neighbors prop just came off the shaft, suggest he takes a look at the proper prop thread that shows how to lap a prop to the shaft. If the shaft broke, one of the causes is alignment so suggest he takes a look at the alignment video.
Hopefully he finds a prop and gets back out on the water shortly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2017 at 5:35am
Get out your scuba gear and go find the prop. It would be worth an afternoon in the water to save that much money. Unless it is 100 feet deep or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2017 at 10:49am
The 541 is a pretty good prop, its just the lh version of the 540 that is ideal for most direct drive CCs. I used to have a slightly less than perfect used one around - but I haven't seen it in a while so its possible I gave it away or sold it- or that it is sitting on one of my work benches covered in engine pieces. If he didn't like the performance of it then let us know engine details and previous RPM and we can make an alternate recommendation. - Gary has the info on the best price above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2017 at 11:47am
Already in the works. We have a mutual friend whose family has mulitple divers. I think they are planning on giving it a shot on Friday. Shouldnt be more than 15 - 20 feet. Area isnt super well defined, but not crazy huge. Problem is there is probably a 1-ish foot tall weed crop in the area. If so, its gone for good.
Originally posted by JoeinNY JoeinNY wrote:
The 541 is a pretty good prop, its just the lh version of the 540 that is ideal for most direct drive CCs. .
The owner really isnt a tinkerer and didnt know what size prop he had. He was going home to check his owners manual and I did a little homework and I came up with the 541. He said it was a flour blade that was lost, so I am guessing prop swap by prior owner.    Not sure if he is going to seek out a four blade or go with the 541.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2017 at 11:55am
The 4 blade would be a down grade over the 541 for sure - and possibly cost more - there is an oj xmp 3 blade that is comparable that I wouldn't rule out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2017 at 11:09am
Remind me, does delta have a try and return policy?
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2017 at 11:23am
Larry -- I don't think so. I was hoping to test several props a few years ago, and they said that they wouldn't allow them to be returned after a test.
1999 Python
1980 Ski Tique
1968 Mustang WIP
