pitts. pa. get togethers |
wfdavis
Newbie Joined: March-05-2016 Location: pitts. pa. Status: Offline Points: 2 |
Posted: March-06-2016 at 10:54am |
any get togethers in pittsburgh pa. area
wfdavis
AAM196
Hey Bill, it is a rarity but has happened.. lol. Where do you reside/boat? I don't keep my boat in the river, but frequent the Ohio a pool down from the city but have been all around Pgh.
JHadji
Groupie Joined: August-18-2006 Location: Pittsburgh, PA Status: Offline Points: 77 |
Hey - is there an engine mechanic you recommend nearby? Pleaseurecraft 351W
1988SkiNautique2001
What's the problem with the motor.
More info needed. |
Hot engine restart problem still?? |
Thanks Pete
John where are you located I could probably help you out on some minor things like the carb problem and such. |
Bueller ... Bueller :)
JHadji
I'm north (Gibsonia). Details: it starts up and runs fine, but when I shut it off hot (like to pick up a skier) it won't restart. It turns over at first but then tends to lock up after a few tries. If I wait until it's warm, it'll turn but not start. Eventually, when it's cool, it'll restart. The only diagnosis I've done is to pull the plugs and there was no water. It might be the carb or starter or both or worse. Unf I'm not an engine guy. It's all original w/electronic ignition I did myself (thanks to you guys here) and regular maintenance.
1988SkiNautique2001
JHadji
Would love to find a go-to mechanic I could trust nearby. If not, with a little wisdom from the sages around here, I've not been too afraid to change parts on my own.
1988SkiNautique2001
When you did the EI, did you check the timing? Timing too far advanced will cause starting problems. |
Dreaming
I was thinking timing as well... |
JHadji
Yeah, adjusted it at the time but it's been a while and pretty easy to check again. Will let you know.
1988SkiNautique2001
John I'm just outside of Mars off RT 228 I could give you a hand figuring this out.
AAM196
While hard to diagnose without being there... sounds timing related. Has this always happened since the EI upgrade?
If you are unable to fix yourself, I'd go to Johnny's Marine Services, 88 Factory Street, Monongahela, PA. Only PCM mechanic I'd trust. AFTER PAUL of course! A pack of smokes and a 6 pack will have you sorted! |
Thanks Andy but I don't smoke anymore been over a year now.
A case of Molson Canadian goes a long way still Oh yeah LETS GO PENS !!!!! |
AAM196
Good for you paul! But I don't know if I trust a mechanic who doesn't smoke...
Let go pens! |
JHadji
Paul - that'd be GREAT and you're really close. My email is jhadji2@yahoo.com. I sure do appreciate your offer to help me troubleshoot!
1988SkiNautique2001
phrnjohn
Newbie Joined: April-05-2015 Location: w. mifflin, pa Status: Offline Points: 2 |
Would definitely like to see something happen​ here in the 'burgh.
Look's like we're getting quite a few fans here in the 'burgh guess we'll have to start looking at some dates.
I'm heading for DCL tomorrow for a week but will be good after the 28th. John I see your a nurse how is your during the week availability? Where do you usually go? A friend of mine from your area and I have been hitting the pool up by the Fox Chapel yacht club. |
AAM196
While we have a ton of thing going on, always, I am always down for something! Anywhere within strikin distance of city works! Fox Chaple pool is nice..
