New project 1965 mustang |
Post Reply | Page <1 6789> |
Bilkolayne
Senior Member Joined: September-13-2016 Location: Sanford me Status: Offline Points: 135 |
Found a brand new tailer made 66 inch windshield for $100 today going to pick it up this afternoon. Still working on the engine I had to get my old lady a new truck this last week so that has taken up most of my spare time and also I had family come into town. Hope to have it running right this week
Bilkolayne
Got my windshield I will post pics tomorrow some time.... got a hell of a deal $400 tailer maid for $100. I'm excited
Bilkolayne
Have not mounted it yet but it looks really good |
Sharp looking boat!
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21192 |
What's the height on that windshield? Something about it doesn't look quite right.
Bilkolayne
It's 17inches I think it is a bit big but could not pass it up for the money.... I think the original one looks to small anyway |
Bilkolayne
Finally got it running right I put the new distributor on and it's running great.
Bakchose
Gold Member Joined: November-04-2004 Location: Boston, MA Status: Offline Points: 554 |
Any chance that you are going to put it the water this weekend for a test run? |
Bilkolayne
Prob not I don't have controls in it and I still need to pull the steering cable off to lube it..... I also winterize the engine last night so I think I'm ready to cover it up for a wile and finish it up in the spring. |
Bilkolayne
OK so here we go back at it.... just picked up new carpet for the interior. Hopefully order controls and exhaust pipe this week. Still need to free up the steering cable and build front seats. Little bit of wiring left to do and a new flame arrestor and we will be ready for the water. |
Bilkolayne
So I've been pretty productive. Build a whole new subfloor out of pressure treated plywood. Carpeted the whole floor. Picked up new throttle cable shifter cable and steering cable. Replace exhaust pipes. Hope to install the cables today and finish my wiring. Only thing left to do is clean out the fuel tank. Put some fresh gas in it and test run it on the lake. Hoping to have it in the water this weekend.
Bakchose
This weekend's forecast is looking pretty grim. 65 and raining both Saturday & Sunday. Hope it changes. |
Bilkolayne
Update.... got the new steering cable in place then found that my Rutter is a little bit bent. Going to take it to work tomorrow to straighten it out. Got all the gauges wired up and went to start it for the first time after sitting all winter. She started right up. Just got to figure out this alternator wiring or order a one wire alternator. Probably put the rutter back in tomorrow and hook up the steering as well as hook up the controls for throttle and shifter. Also I am looking for a flame arrestor for a Mercruiser Quadrajet if anybody happens to have one that they are willing to sell please let me know.
Duane in Indy
Did you contact the folks in San Diego about the alternator yet?? Nothing simpler than a one wire hookup. If a Holley style ( 5" neck ) will fit then I have this one. $25 + shpg. Duane |
1978 Mustang (modified) |
Bilkolayne
Duane in Indy
Thanks for the reply. I was able to get my buddy in Baltimore to send me one it will be here in a few days. And also I think I'm just going to go ahead and go with a one wire alternator. |
Bilkolayne
Update. Got the steering all hooked up and straightened out my rudder. That's the good news the bad news is I was running it yesterday and I think I spun a rod bearing in the lower end. Luckily enough the engine is easy enough to pull out only 5 wires one fuel hose 1 water hose two hoses for exhaust. Probably going to yank it out and replace all connecting rod bearings and crankshaft bearings and the oil pump maybe this weekend hopefully if I can get the parts in time.
Duane in Indy
And the crankshaft!!!!!!! |
Bilkolayne
Depends on how it looks. Hopefully it's not scored up its only spun for a few seconds |
Duane in Indy
So what were the symptoms that lead you to believe you spun a bearing in only seconds of diagnosis?? |
Bilkolayne
I was setting the timing at 8 degrees at idle and read it up a couple times to check Max advancement. So get up to about 3500 RPMs then started to hear a slight squealing noise with some rapping coming from the bottom end. I looked over to see what my oil pressure was and it was only at 5 PSI. So all-in-all sounds like oil pump failure then wiped out bearings
Duane in Indy
Hope it's not a main bearing. Cranks are fixable.
Bilkolayne
Yea I know lucky enoff the parts for the 283 are dirt cheep. I just need to put it under a tree and pull it to see what happend
Bilkolayne
Have not had a chance to pull the engine out yet. Just found a buddies born then I can do it in. I tried to register the trailer today and having issues because I cannot find a VIN number on the trailer in the prior owner had no information on it. Also the tag that is on it does not belong to the Venture trailer. Kind of baffled on what to do now.
If there is a # it will be up by the coupler. Might have been painted over. You can try registering it as homemade
Bilkolayne
Yea I looked all over for it and found nothing.... gonna need to go back to the dmv and try for a homemade
Bilkolayne
OK so the last few days where interesting. I belt a Gentry crane remove the engine check all bearings and I found 1 connecting rod bearing that was wiped but not spun. All main bearings are fine. I replaced all the connecting rod bearings and Polished the journal with the bad bearing. I then put it all back together put it back in the boat and it was still making the noise. so now that I knew that I did not spin a bearing I let it run a little bit longer and found that the noise was coming from the timing chain cover. So this morning I pulled the harmonic balancer and the cover to find all three bolts on the camshaft COG to be loose and hitting the timing chain cover. I put it back together with blue Loctite new gaskets and fired it up and it runs great now. At least I know the lower-end has good bearings now and a new oil pump and screen so this engine should be pretty sweet.
Bilkolayne
So the boat is running like a champ. I set the valves yesterday and reset the timeing, hooked up throttle and shifter linkage. New altinater is installed and charging. I need to wire up the bilge pump and blower then I'm ready for the water. Plan is to put it inn the water tonight or tomorrow for a test run and if all gose well then boating all weekend.... also I was able to get the trailer in the boat registered yesterday..... still no front seats so milk crates will do for now.
Bakchose
Are you going to run it in Mousam? I just got up here and plan on putting the dock in tomorrow since it is suppose to be 90 out. Doesn't look like the markers are in yet. If you are launching it in Mousam and have not been out there go online and look at a map. It's a little tricky out there.. again I'm in carpenters cove the every top of the lake. I'm in wooded patch with the new stairs and deck in the trees and a green canoe on the dock and/or pile of dock pieces. Feel free to pm me if you want my cell # if you need assistance if something arises.. can't wait to here it pass by..
Bilkolayne
Bakchose
Yep, Acton trading post on lower Mousam. Filling up the glass of wine and going to the lower deck. Maybe a can catch a photo or two.
