Broken prop shaft |
Post Reply | Page <12 |
81nautique
Not to beat this to death but I stumbled onto the patent info, regarding the coupler taper it appears the steep taper was deliberate to facilitate "easy" removal and decrease man hours required.
From the patent application "A coupling receives a steeply tapered end of a propellor shaft and is secured thereto with a lock nut held in place with a set screw. A housing taper is steeper than known locking tapers to facilitate housing removal. The housing is internally threaded to receive an extractor element which, after lock nut removal, is screwed into the housing for abutment with the end of the propellor shaft with continued advancement of the extractor element resulting in housing separation from the shaft." full link |
Just curious, is everyone that has bought one of these using a torque wrench to lock the shaft into the taper? Does that matter?
phatsat67
Ken, is that coupler side splined too? MC has used splines for propellers for a while now.
tryathlete
Splines on both ends seems like a winner to me. There must be some logical reason why the keyway is used instead of splines.
From wiki Splines are ridges or teeth on a drive shaft that mesh with grooves in a mating piece and transfer torque to it, maintaining the angular correspondence between them. ... An alternative to splines is a keyway and key, though splines provide a longer fatigue life. |
Duane in Indy
More than likely a 10" crescent and a piece of pipe |
1978 Mustang (modified) |
And please, anti seize on the nut threads. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11059 |
The ones I've seen had splines on both ends, but I don't know if they all are |
Duane in Indy
Don't forget-----use a brass nut
