Velvet drive |
connorssons
Posted: August-05-2017 at 3:10pm |
Looking at a 79 mustang fir a friend water test revealed reverse gear but no forward gear boat has been sitting 10 years any thoughts
Show the seller what a new trans costs and deduct that from the sales price. At the minimum it needs a rebuild
Jay SE IN.
Newbie Joined: December-07-2016 Location: southeastern in Status: Offline Points: 29 |
I just rebuilt mine last month. It wasnt too bad. Downloaded and printed the manual at the library. New gaskets and drive clutches was about $185. Clutch plates very simular to GM turbo 400 . But the previous poster is correct. Tell them what a rebuilt one out the door costs. ($1700?)
Was the pump in spec? A clutch pack and gaskets are not a rebuild!! |
Jay SE IN.
Yes. I have over 40 years. experience working on automatic transmissions.
Automotive or marine? |
Jay SE IN.
I was trying to encourage someone. Not tear them down. Im done now.
Duane in Indy
Pete, could you please elaborate??? Where did you find the pump specs, and how do you check them??? Are you talking about pressure specs or dimensional specs?? Duane |
1978 Mustang (modified) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11090 |
Pete's gonna learn us all about Borg Warner's.
Don't forget, he thought that a car auto like a C6 or Turbo 400 had dry clutches not too long ago. I figure Jay knows what he was doing with whatever Pete wants to call the job. I remember you asking the same question before with no answer back Duane |
Duane in Indy
Jay, Good for you that you took the initiative to tackle your own trans. I too did the same as you and now have over 25 hours on mine. Most people with mechanical ability and the tools can achieve success doing their own and avoiding huge charges. One member keeps harping about the pump being so much of a problem and that it needs rebuilt to be a "Complete" rebuild. A pump can be purchased new for around $150 and takes a total of less than 3 minutes to install. You have to either install the old one or the new one anyway so it is no big deal The Velvet Drive is a very simple design. Takes an afternoon to "Rebuild" Duane ps. stick around, it sounds like you have a lot of knowledge that you could share with us.. |
Wrong Ken! I'm the one who wants to learn since pump tolerances aren't published. So Ken what are the max clearances? |
fgroce
I have rebuilt several automatic transmissions, and I am by no chance an expert. But what I have learned so far is the clearance in clutch packs has been set up by the steels thickness. So as long as you replace the steels with the same thickness you should be good to go. If not then try again. The clutch packs I have been working with have about a .040 window in the tolerances between tight and loose. I agree rebuild your own and save the money. I hear everyone say don't run synthetic transmission fluid. We have been running Amsoil ATF for over 25 years in our 88 2001 Ski Nautique with no problems. Good luck with the transmission rebuild.
FGroce
I don't throw out the same stupid comment to every guy that asks transmission questions Pete. Like Duane and Jay a few posts back, I 'll actually encourage somebody and tell him that he can do it with a manual a few special tools and the desire to try it. Seems like I told Duane he could handle it in spite of your discouragement a while back.
And Guess what....................he did it and made some special tools that he'll duplicate for anybody that wants them for a reasonable price. You don't know the tolerances, I never claimed to and they aren't in a B/W manual either like you said. So why do you ask Jay a few posts back if the pump clearances were in spec ?. You're just spewing sheet( that's the Mexican pronunciation by the way) doing your usual job of trying to make somebody feel like they know nothing and can't have possibly taken their transmission apart, fixed what was wrong and have it work ever again even though your transmission knowledge is lacking to put it politely. You never saw a tolerance from Eric posted other than a look at score marks on the pump housing surfaces and if you could feel them it was probably replacement time. That may not have even come from Eric, might just be one of those things I learned over the years that may or may not be true, but it works for me. |
Frank You're not supposed to say that you use synthetic ATF, on CCF That's a well kept secret among those of us who do You'll get jumped all over (or we both will) for that statement. It's easier to say "Yep use Dex 3" |
Ken,
Your comments are well taken. Thanks. If I ever do find out the pump tolerances, I'll be sure to share them just like you share all your knowledge. |
boat dr
Dreaming
nice to see you back Doc!
DrCC
Eric had you guys fooled, evidently still does, he even hinted to that notion at one point.
I guess he figured, if people were such an expert, they would be able to figure it out themselves in short order. |
quinner
OK, can you guy's enlighten me on the trans fluid, my fading memory is that Eric always recommended against synthetic, because it is too slippery iirc?? I have spewed that advice ever since and certainly won't any longer if that is not a fact??
Duane in Indy
I doubt that you will ever find the tolerances for the pump. My recommendation is to inspect the pump for wear and replace if you think it is needed or use the existing. The only function of the pump is to provide pressure to the forward and reverse pistons to lock up the clutches----period. So a "REBUILD" is basically to replace the seals and the clutches as needed. Guys, it ain't rocket science!! If I can help with special tools I will do my best to help. Duane |
Just me speaking, but many years ago I rebuilt a transmission that was given to me, put it in the boat and after hearing all this talk of "too slippery" etc figured I'd find out for myself.
I put in some synthetic Dex 3 equivalent and have never had a problem but it's a lot easier to say "use Dex 3" and you won't have any problems. I'm on a very strict maintenance routine with this trans by the way. I check the fluid every now and then and I haven't changed it in at least 700 hours. Kind of a torture test. Myself, I'm happy with it but the choice to use it is up to the owner. I did it because it was a free transmission that I spent a little on to fix it so if I screwed it up, no big deal. Go to the MC website and there are plenty of people using it with no ill effects and probably the same on PN or the Malibu crew. They probably change their fluid though I've kept my mouth shut cause I figure if somebody switches and has a problem of any kind it gets blamed on the synthetic ATF and some clown named Ken O. I figure if it's got to meet a spec it doesn't matter if it's synthetic or dino based stuff as long as it meets the spec All I can say is "don't do it because I do it." cause I like to do things like this to find out for myself. |
baitkiller
My gear was a metal box full of rusty water I dragged out from under a shipping container in Fort Myers. The fwd clutch was welded together and the main plates and pumps tattooed with corrosion. I put a kit in it and dressed all the flat surfaces on a granite slab with wet and dry. That was ~400 hours ago. Seems to work OK. I borrowed a few special tools from a friend.
Duane in Indy
Thanks KenO, Truer words were probably never spoken, thanks. Duane
Duane in Indy
^^+1 |
By the way Pete
You have a package coming USPS if the post office people can find your house. Should be there Thursday The address way up there in the Northwoods didn't come up in their computer . |
boat dr
boat dr
backfoot100
Good stuff Ken. I did kinda the same thing with my last 98 Volvo S70 turbo. I beat the snot out of that sucker for 409K miles when a teeny bopper rear ended me which the insurance company promptly totaled out on me. The last time I changed oil in it I ran it 8K miles between changes and in that 8K it was down a half qt. of oil. I insisted on using nothing but that piece of crap orange Fram filter that everybody chastises just to make a prove a point. Never mentioned a word about. It was still one of the fastest cars I ever drove from a rolling start to about 100MPH when the insurance company came and loaded it on a flatbed. |
Eddie |
Some love and we'll call it an EI reversion kit or something like that so he can change his Tique back to points if he wants to. Might come in handy in something like a nuclear blast with all that EMP radiation that supposedly kills electronic stuff |
Ken,
Yes, that point plate will come in handy when North Korea sends their love over to us. Thanks for thinking of me. BTW, leave it up to the USPS computer system to not recognize the address! They deliver every Monday through Saturday to this box on hwy. 32 Three Lakes Wi. |
