  New Posts New Posts RSS Feed - Poor Man's GT40 Diagnosis
 Post Reply Post Reply Page    <1 34567 8>
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2016 at 9:10am
No fuel pumps and no spark (no start) fixed by replacing the fuse in the battery box fuse holder. This is a boat that had no been retrofitted with the fuse elimination:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=38652&PN=1&title=efi-gt40-help-and-opinions
Added to next to spreadsheet:
Fused Line in Batt
Box For EEC Power
Updated Spreadsheet:
https://docs.google.com/spreadsheets/d/17VemuIOaa9i8kEply-ZmFOSyjyzz8rd7B0WEuIT_6S0/edit?usp=sharing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2016 at 11:28pm
Fuel pumps not priming/no start caused by three separate items.
-Potentially defective lanyard
-Low pressure fuel pump
-Wires pulled lose inside of Fuel Control Cell (High Pressure Pump) during filter change.
As described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=38636&PN=1&title=gt40-fuel-pumps-inoperative
Updated spreadsheet:
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 11:25am
Originally posted by Bri892001 Bri892001 wrote:
EEC Relay Fixed Engine Loping as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24848&PN=1&title=gt40-engine-loping
Updated the Spreadsheet with Lewy's findings.
Hey i was just reading this because i was having the same issue, I thought he said it was the idle air control motor that he replaced to fix this issue, not the EEC, of course i have no idea what the EEC relay is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 4:01pm
That's a good catch. I think I had meant to link that entry directly to Lewy's particular post within that thread. That's the only thing I can think of. It gets a little tricky to keep track of, when there are multiple boats being talked about within the same thread. Lewy does mention, what we were calling the EEC relay, later on in that thread.
In that instance, I believe I might have been calling that fusible, separate, wire from the battery box the EEC relay. I realized later on that that was a separate thing, and a source of some issues.
There is a retrofit that gets rid or that fused wire from the battery box to the engine.
As far as the actual EEC relay, I believe that it is one of the two, frequently replaced, relays. One is for the fuel pumps and one is for the engine computer.
Sorry for so much confusion, I just try to follow it the best I can myself. Your best bet is to start a new thread, under the engine heading, and include GT-40 in the subject. If you want, you link back to your new thread from here. You'll likely catch the eye of the GT-40 experts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 10:32pm
No confusion at all, or atleast i dont think
Issue-Boat idles fine at idle, but when warm it idles erratic and shuts off, but will start right back up just fine
Solution for me- replaced Idle Air Control Motor or whatever its called
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2016 at 11:36pm
Brent, I added your fix to the spreadsheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2016 at 9:10am
Replacing Idle Air Control fixes loping idle. This post also comes with an updated part number: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=39377&title=gt40-isc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2016 at 9:46am
Fuel pumps not running = engine not running. Fixed by replacing ECM (ECA is the correct terminology as explained by Paul, AKA the engine computer) Relay. This is one of the two relays in the back of the motor. One of which is for the fuel pumps and one of which is for the ECA:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=39443&title=gt40-fuelpumps-not-running
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2016 at 6:48pm
Replacing Fuel Pressure Regulator solves poor idle and eventual stalling.
Ruptured FP Regulator diaphram was allowing gas to leak into vacuum lines.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=39282&title=1997-gt40-efi-poor-idle-eventually-shut-off
Column added to spreadsheet for poor idle and stalling. Spreadsheet same link as above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2016 at 8:59pm
Baffle Broken Loose, restricting muffler and causing reduced performance and slow acceleration.
Fix was to repair muffler.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=38572&title=gt-40-slow-acceleration
I updated the spreadsheet and added a new row for the broken muffler. I logged it under the reduced top speed column:
kylake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kylake Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2016 at 3:12am
GT-40 1998 SNOB warm engine shutting down; problem solved [Low pressure fuel pump]
As in other postings, my Nautique would start when cold and run great until the engine hit regular operating temperature (160 degrees). Then it drops to idle rough for 30 seconds or so and shut down (sometimes with a backfire). Would not re-start. After reading postings here, I replaced the easiest suspected part first: idle speed control valve. Test drove and got up to temp and it shut down again resulting in a 100-yard paddle back to the dock. Installed a new low pressure fuel pump. No problems during the test drive plus a 20-minute in neutral idle at the dock. Issue seems to be fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2017 at 4:19pm
Anyone have a motorcraft part number for the MAP sensor, i did not see it int he spreadsheet, surely somebody has replaced it
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2017 at 9:56pm
Ford-AA5Z-9F479 Map Sensor base number is 9F479 the prefix varies with revisions.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2017 at 5:35pm
Unclogging clogged fuel pickup screen, solves runs&dies fuel starve problem as discussed here: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=40597&title=98-gt40-rpms-drop-when-engine-warms-up
Updated Spreadsheet added in Clogged Fuel Pickup Row, Runs and Dies Fuel Starve Column: https://docs.google.com/spreadsheets/d/17VemuIOaa9i8kEply-ZmFOSyjyzz8rd7B0WEuIT_6S0/edit?usp=sharing
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2017 at 1:39pm
I google that PN, my map looks nothing like that, it's more of a rectangular box with a hose nipple on it.
Has anyone here replaced there MAP sensor
I did not see it on the spreadsheet, just curious of symptoms
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2017 at 10:05pm
The MAP sensor on the GT40 is shown in picture below just above the ACT with the vacuum line running to it. Look through all the google images that the search found, you will find one that looks the same.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2017 at 5:19pm
Brent, what symptoms are you trying to remedy with the MAP sensor, also what have you tried to fix said symptoms. I haven't seen that particular part come up in the time I've been paying attention, but that doesn't mean it never has.
If you start a fresh thread with GT-40 somewhere in the title, you'll get a good amount of GT-40s weighing in. Hopefully a solution will be found and I can post it back here and add it to the spreadsheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2017 at 1:31pm
Fuel Pump (FCC) not priming because of loose battery connections.
As described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41292&title=fcc-issue-where-to-start
I added a new row in the spreadsheet for:
Tightened Loose
Battery Connections
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2017 at 6:47pm
A second/separate issue solved in the same thread as above.
Replacing a low pressure fuel pump solves a hot restart issue as described in this specific post by by mtguy:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41292&PID=531631#531631
Spreadsheet Updated:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2017 at 6:53pm
Low RPM misfire fixed by replacing broken/damaged spark plug as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=40837&PID=526898#526898
Added broken spark plug rows to spreadsheet. Same spreadsheet link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2017 at 11:41pm
Bogging under full throttle solved by replacing anti-siphon valve and braided fuel line between Low Pressure Fuel Pump and FCC.
As described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41488&title=2001-gt40-bogging-under-full-throttle
Updated spreadsheet under "Reduced Top Speed" column. Gave half credit to anti-siphon and braided fuel line:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2017 at 1:18pm
Lack of power after overheat fixed by replacing fouled/damaged spark plugs as discussed here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41631&title=need-some-gt40-help-gents
Logged on spreadsheet in broken spark plug row and split in the columns for Hesitation and Reduced Top Speed:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2017 at 1:27pm
Skip/hesitation on acceleration solved by replacing spark plugs and TFI module Edit; TFI module was the fix as mentioned below as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41734&title=gt-40-slight-skip-on-acceleration
I logged in the spreadsheet (same link as above) under the hesitation column. I attributed half to spark plugs and half to TFI module. Edit: Logged just under TFI
fgroce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fgroce Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2017 at 6:09pm
On the skip on acceleration the plugs were Platinum and looked brand new, I really think the module fixed the problem. Just my opinion.
FGroce
88 Ski Nautique
For 28 years
Now 2002 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2017 at 11:08am
Ok, I'll amend my post and the spreadsheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2017 at 12:09pm
No power in gear fixed by replacing faulty fuel injectors as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41742&PID=537812#537812
Logged in the Hesitation column in the Fuel Injectors row on the spreadsheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2017 at 12:15pm
Engine surging solved by properly installing the correct spark plugs as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41778&PID=537476#537476
Logged in Rolling Idle column on Full Ignition Tuneup row.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2017 at 2:18pm
I never got around to logging this one. Intermittent loss of power at speed fixed by replacing distributor. The base problem was a loose/dislodged PIP Hall Effect Sensor.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=41558&PID=538985#538985
Distributor Complete Rebuilt Row
and split between the Hesitation and Reduced Top Speed Columns
Updated Spreadsheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2017 at 11:23pm
No start condition solved by cleaning/repairing engine 10 way harness as described here:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=42231&PN=1&title=diagnosing-no-start-gt40
Edited:
I added in the No Start column and created a new row
Corroded 10 (or 8?) Way
Engine Electrical Harness
Updated Spreadsheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-21-2017 at 12:18am
Corroded 10 Way
Updated Spreadsheet
That 10 way connector is really an 8 way connector and it seems like putting something in the spreadsheet about the manual being wrong in reference to the connector would be a good idea too.
