1972 SN Promo Project |
Page <1 10111213> |
Frankenotter ![]() Platinum Member ![]() ![]() Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Bada$$. Tanks for the assist Joe! The card gave me rug burn I pulled it out of my pocket so fast. I was looking at either replacing the entire circulation pump and housing or trying to create a new one on the CNC. |
1999 Ski Nautique 196
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6157 |
Circ pump impellers aren't directional ?
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
everyone wants to complicate things… Listen zach… I mean maybe ish. The marine parts diagrams showed a unidirectional brass looking impeller in the illustration similar to what you would find in a pcm circ pump for a small block ford – but called out the exact kit number I linked to, and the picture kit matches what he currently has. So maybe ? but is the business end of that impellor even raked or is it perfectly radial from the center? If its radial then it will pump the same in either direction, if its raked it’ll still do better than the no circ pump having engines that are running around all over the place.
for what its worth, when I was looking at new "Chrysler Marine Circ Pumps" they were all listed as "bi-directional". I would imagine that would include the impellor as well. On the flipside, I noticed the impellor on a car pump was flipped upside down so the flukes protruded outward instead of toward the pulley.
I just didn't know how they determined direction with impeller design. I would agree with you if the blades aren't raked it should work reasonably well in either direction pushing water into the block.
The rusty impeller in the video looks identical to the one in the kit. At least to me it does.
( previous statement about making on one the CNC sounds like more fun though) ![]() |
1978 Mustang (modified) |
tryathlete ![]() Platinum Member ![]() ![]() Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1799 |
Yeah CNC or laser cut the blank and form up the blades—better yet just get it 3d printed—wait—it’s only $50! Chris—I’d definitely get the steel impeller e-coated. |
Make it out of S/S. Oh wait!!! We can never agree on what grade of S/S to use.. ![]() ![]() |
Depends on what decal you put on ![]() |
Duane do you rebuild water pumps? ![]() |
Buy 2 kits, don't bother coating. Change it in 20-25 years. You won't care after that.
Never tried. |
Duane only builds from scratch.
Yup. That's pretty much what's going on in my world. |
Welcome to chapter 30.......The Wild World of Water Pumps
So, I ordered the OEM rebuild kit that Joe found. Thanks Joe! It turns out the parts and even the shape of the impellor are exactly the same as original. ![]() ![]() The gasket arrived crusty and broken but I'm not super concerned about that. What IS concerning, is the company that Tim found to overhaul water pumps is MIA. I was in contact with them for a week about doing the rebuild and I was ready to send them the parts. Litterally overnight, their website wend down, phone is off the hook, and no replies on their facebook page. http://arthurgouldrebuilders.com/ I'm trying to resist the urge to rebuild this thing myself. I have access to a full machine shop and 20 ton press. Has anyone ever attempted doing this? |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7963 |
Chris, just sent you a PM.
I'm also overhauling the Jabsco raw water pump. As you can see, the shielded bearings were seized. They are Hoover 77203-625 bearings. Not made anymore. However, for anyone trying to service one of these bad boys, just call your local bearing joint and tell them you need a 5/8" ID, 40mm OD, and 12mm wide shielded bearing.
Everything was just press fit and held in place with a retaining ring. ![]() |
If anyone has a jabsco pump that they want to sell, let me know. I might need some parts if this one doesn't preform
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21207 |
Jabsco huh? My 70-71 Chrysler’s have sherwoods. Single or dual pocket?
Can you post a pic or jabsco pump number Chris?
Ii have done a lot of searching and I believe it's a 17200-0000.
Ok folks, I'm back at the promo after buying a house, getting married, and being lazy in general. I'm making this post to dig this thread out of the archives. My old computer gave up the ghost that I used to edit photos for the very particular CCF server. I'm playing with a new program to edit pics to the delight of the website.
I had wondered about this project thought it had been parted out.....
It's not far away.
When i left the boat last fall, I was in the middle of making new primary stringers from scratch. There were a few reasons for this, but mostly because i was adding an engine cradle and going with the "floating floor". I decided that it was smart to do a test fit of the old block and trans on the new stringers to verify alignment before permanently gluing the stringers in place. Here are a few pics of the setup. I just wanted to make sure it was close. The engine mounts on the trans were cocked a little which is why there looks to be lateral misalignment. It was a horrible process trying to wrestle the block in place by myself while being mindful to not step on the thin floor areas.
Now for a few questions.
1. Does anyone have an extra forward engine mount.......loop.........pin.......thingy. Mine has gone missing between the machine shop, disassembly, and moving parts. ![]() 2. Can someone measure the distance from the floor to the bottom of the dash? mine seems very tight right now. Especially since i don't have cushion on the seat yet. ![]() |
Normally I would horde this but I am in the middle of a shop move
However if you still need a pump you might want to pick it up https://syracuse.craigslist.org/bpo/d/sterling-chrysler/6965558200.html If not I suspect I can spare an pin thingy |
Frankenotter—that’ll fit in the jump seat, no problem
Page <1 10111213> |
