Battery Replacement |
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 388 |
Posted: February-22-2018 at 12:50am |
OK... I have a 1999 19’6 closed bow. The battery in the boat does not allow the top lid to close. The manual has nothing in it about Replacement type. Can anyone offer a suggestion on the type and size that allows the battery lid to seat completely down as it was designed to do!
Thanks |
Otto
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
Mine states the battery group size on the underside of the battery cover. It's in storage or I would check.
Group 65
Otto Throttle
Thank you!
Otto
gt40KS
Gold Member Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Group 34M should work also. Choices are scarce and expensive for our boats. Both Odyssey, Northstar and Interstate make highly rated AGM's in a size that will work, but they are pricey.
JCCI
1995 Ski Nautique GT40 |
The "m" (marine) is not needed. Just use a group 65 starting battery like Tim mentioned. |
Dekka batteries, made by East Penn, is still made in USA.
Otto Throttle
The battery box lid on the boat says group 48....It is hard to find a group 48 battery. Interstate has one one for $166.00. what say the group??? Any other suggestions?
Otto
Don't buy the highest amp rated battery. The lower Amp rated batteries are in the same size case and the plates are smaller. This leaves more room for them to vibrate in a boat as you bounce over wakes without the plates touching each other. Makes for a longer life battery in a boat application. I would look at 650CCA rather than the 800+ models.
It will save you money upfront and in the long run in a boat. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11045 |
Here's an old thread talking about this. It's been hammered out numerous times
Unless you're hell bent on getting a Group 48 for some reason, TRBenj's Group 65 or a 34 from Uncle Wally's battery emporium should do just fine at a reasonable price unless you're equally hell bent on spending a lot more Group 34 10.3 long 6.8 wide 7.9 tall Group 48 12.1 long 6.9 wide 7.6 tall Group 65 12.1 long 7.5 wide 7.6 tall .link |
Otto Throttle
Group 65 was a winner and fits perfectly😎 Thanks everyone🚤
Otto
