83 New Stringers & Floor |
Post Reply | Page 123 9> |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Posted: March-07-2018 at 9:23pm |
Figured I would just try a thread on my 83 project if OK with y'all
Motor is OUT |
jterr
Cut the passenger side floor partly out
jterr
Tank and exhaust out
jterr
Don't look good
jterr
Took some Foam out in big chuncks
Then this mess |
MechGaT
keep it up!
'92 Sport Nautique
jterr
Just a note for foam removal doubters. This boat has not been used in over a year. Every piece of foam I have removed is wet. the part next to the battery box actually had water on the floor, below the foam.
I was gonna leave some cause it looked and felt dry-WRONG- it's all coming out |
jterr
A question--As long as I leave the stringers in can I remove all the floor?
And any suggestions as how to get that carpet out, man wish I could find that glue to use today??_LOL |
John,
You will want to remove all the flooring and the stringers down to the bare hull. Do you have the boat on the trailer? You may want to consider some extra support if hull shows any signs of flexing or "oil canning". The Henry 263 is a "pro" grade that's waterproof in 2 hours. It's harder to find than the typical Henry 663 you find at most stores. |
jterr
[QUOTE=8122pbrainard] John,
You will want to remove all the flooring and the stringers down to the bare hull. Do you have the boat on the trailer? You may want to consider some extra support if hull shows any signs of flexing or "oil canning". I was asking about floor as I read should do one side first. So can I take the complete floor out and leave stringers until I do one side and keep the hull OK??? I think I'm asking this right Boat is on trailer. Thanks for glue info. |
connorssons
Yes you can remove all of the floor, it wont hert anything. If you remove your primary stringer and secondary on one side at a time you should be ok. But if it was me I would build up a couple extra supports if you remove both primary and both secondary stringers you need to have supports on both sides of boat if you're going to leave it on the trailer
jterr
Got to the thing that looks like a footrest on drivers side. Is it necessary to take this out also??
John,
The stringers (and the foam) extend forward under the kick so yes, it needs to come out too. |
jterr
Oh boy getting harder and harder
jterr
I read to not pull motor bracket with motor, when can I take it out ?
John, I'm assuming you are referring to what some people call the engine cradle. You can pull it out anytime after the engine. |
jterr
Correct Thanks |
jterr
Got the Pylon and Motor cradle out ..
Still chopping Foam, actually found some dry foam and wood in back. Question- Should I try and save these boxes??? Tried to load a picture, biut said Upload error not enough space on disc..What disc??? |
What "boxes" John? If you are talking wood, I don't feel it's worth the effort to scab in new to old.
Regarding the disc, the site is having problems this morning. Keith and family are probably off on a spring ski trip and can't do a reboot!! |
jterr
The 2 battery boxes in front of the pylon? |
jterr
I got them out and am almost to front....Notice puddle of water with no where to go
jterr
I know I'm nowhere ready to put stringers back in. I was wondering can Oak be used as a stringer?
Have alot and my neighbor just got a saw mill.... |
rolleronariver
Senior Member Joined: May-24-2016 Location: Rogers, AR Status: Offline Points: 195 |
I know some guys will chime in on this that know more than me but I would be concerned about the oak rotting. Douglas Fir is what I went with in mine. It really isn't that bad expensive. Some people struggle to find it but I luckily found it in our hometown very quickly. Just call around to some lumber yards. Also, make sure it's moister level is low before you fiberglass it in. |
92 Sport nautique
White or red? |
jterr
Mostly Laurel Oak, also have some Hickory. Just curious..
Thinking about the composites also.. |
John,
No on the Laurel Oak and a definite no to the Hickory. Both are not at all resistant to rot. Even with CPES, I'd worry about them. |
jterr
Yea the more I read the more I'm leaning to the composite
jterr
Update:
Cleaned the mess so I could see.Next will get in and cut out the front.. |
jterr
Question- What is kcel for floor replacement, might be spelled wrong??
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11155 |
Probably klegecell. If you google it, you'll get a lot of info |
