Electrical issue |
Far north downunder
Newbie Joined: May-11-2018 Location: Australia Status: Offline Points: 37 |
Posted: May-11-2018 at 7:49pm |
Hi I’m the proud new owner of a 1994 ski nautique.
The second day out I encountered an electrical issue which shut down the engine and the ignition breaker light went out but the breaker did not pop out. After a breaker panel inspection pushing the breaker buttons and a bit of head scratching the ignition light cam on and the boat fired up. The boat has been beautifully maintained by the previous owner who recently replaced the ignition breaker and renewed the dash wiring, he has given me the old breakers just in case the are the issue but I think it may be either a loose wire, kill switch issue or the ignition may be the problem. When the boat dies the other accessories still have power Any suggestions |
MechGaT
When it happens again, use a volt ohm meter to see where the power is flowing and where it is not.
'92 Sport Nautique
desertskier
Platinum Member Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
Sounds like a loose wire. Check the connections at the back of the ignition breaker. Pull on the wires to make sure there isn't a bad crimp.
