  New Posts New Posts RSS Feed - raw water pump direction
88skisupreme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Topic: raw water pump direction
    Posted: February-24-2007 at 2:58pm
Just took off the raw water pump to check the impeller and I forgot which way it goes back on, its a Sherwood, on a 351. Does the side that has the impeller go to the left or right of the hose?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2007 at 3:50pm
Im a$$uming this is for an '88 Ski Supreme? Is the motor reverse or standard rotation?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2007 at 1:12am
yes and yes
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2007 at 8:02am
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2007 at 8:38am
RH rotation, aka reverse
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88skisupreme Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2007 at 7:27pm
Well I didn't answer that second question very well
I had some 1" clear hose so I just put a piece of that between the raw water pump and engine to make sure the water flowed once it was in the lake.
