  New Posts New Posts RSS Feed - 1981 SKi Nautique Restoration
 Post Reply Post Reply Page    <1 2345>
Wisky Badger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 1:11am
We got the carpet installed last weekend and finished some odds and ends on Friday night. I still need to install the piece that the pylon goes through but besides that the carpet work is complete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 1:20am
I just went back to page one,what a fantastic job you have done!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 1:21am
Today we did some engine work, installed a new cutlass bearing and reinstalled the strut.   This is a picture of the alignment, I think it came out pretty good.
Now I have to get the new coupling on the shaft.   Do you guys think a gas grill will work to bring the coupling up to temp or is an oven a better option?   Also am I shooting for a temp of 400 degrees or 500 degrees?   I would have went with an double taper shaft but the shaft we had was straight so I thought I should just use it.   I am not looking forward to this step of the process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 1:22am
Gary,
Thanks for the complement, it has been a really fun project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 7:19am
Jacob,
Yes, it's looking fantastic. Great job.
The gas grill will do it just make sure the coupling is in it long enough. I'd say 30 to 45 minutes on high. Don't put the coupling directly over a flame. Since you have the engine out, you will have the luxury of getting the coupling on the shaft outside the boat.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2018 at 10:21am
Good rule of thumb for coefficient of expansion for your steel coupling would be:
.0000064 per inch per degree Fahrenheit
So if you measured your shaft and the coupling and came up with a .002 interference fit at ambient temp then 325f degrees should make the i.d. grow .00208"
500f should make it grow .0032"
I would shoot for around 400f (.00256") and freeze the end of the shaft also.
Work fast and put a split collar on the shaft for a stop block so the collar will stop at right place.
I am not a Mechanical Engineer but I know where to look for the data.
Other ME's are welcome to pipe in here
Long story short: use 400f or 500f and you should be OK
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2018 at 8:58pm
It has been awhile since my last update so I will post a quick update.
We have the engine back in the boat and where able to get it all aligned.   We test ran it on trailer using a bucket of water and it ran great after waking her up from a 21 month siesta.
Last Saturday we transferred the boat to a Supra trailer while the Correct Craft trailer is getting sandblasted and painted.   Hopefully the trailer will be ready by the end of the week.
r
The goal is still to have the boat and trailer ready for Green Lake on the 13th and 14th.   There is not a lot left to do besides install the new windshield, install the seats and take it for a shakedown run but I am running short on time with other things going on. I will post some better overview pictures once she gets back on the correct craft trailer and her seats are installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2018 at 11:00pm
The boat is finally back in the water.   I missed getting it ready for Green Lake by about four days, we will try and make it next year.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2018 at 11:04pm
Here are a few more pictures of the final product.   I still have a few more minor things to accomplish as projects like this are probably never complete.
Fall of 2016
Summer of 2018
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2018 at 11:10pm
I built a rear bench to add a little storage.   I made it removable with some threaded inserts installed in the removable floor panel to make it easier to service the boat or if you wanted to remove it if you didn't need the rear seat for the day.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2018 at 11:13pm
The transom decals are obviously not original but I think they look pretty good and it was a lot easier to do it this way vs. taping off the old graphic during the painting process.
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2018 at 11:32pm
What a transformation - Great job!!   Nearly 2 years without your CC, but now you've got an amazing piece of history to enjoy for a very long time. Congrats!
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 1:01am
Nice work!
MechGaT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 1:39am
Way to go!
'92 Sport Nautique
Snorman14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snorman14 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 1:58am
Where did you get your speedo gauges
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 2:50am
The speedos came from Cabelas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snorman14 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 9:08am
Thanks boat looks good
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 11:38am
Outstanding work, that looks amazing! Love seeing the kid in the passenger seat, getting to enjoy your hard work.
Fabcon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 6:42pm
Really nice job
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
sport1999 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sport1999 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2018 at 8:31pm
Great thread and nice to see happy ending!
BrianReno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianReno Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 11:21am
Wisky Badger your resto came out simply awesome, great job. Any chance you have the details/measurements for the rear bench/storage base? That is exactly what I want to add to my 77 SN.
1996 25' Eliminator Daytona
1977 Competition Ski Natique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 7:42pm
Brian, does your boat currently have a back seat or at least the back rest to the back seat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianReno Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 7:50pm
Yes I have the back rest portion of the seat, missing the bottom cushion. I have been thinking of doing a base and really like how you did your setup.
emccallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 8:51pm
Having that backseat storage is really a nice edition. Here is another variation on the rear seat. I wanted a removable middle cushion to keep skiers (NO TUBERS) from stepping on the middle seat. I designed mine after the mid 90's SN rear seat.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=16539
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 9:10pm
Ernest's aft seat mod. Link
Post Options Post Options   Thanks (0) Thanks(0)   Quote emccallum Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2018 at 9:16pm
Thanks Pete! I was going to go back and try to remeber how to fix that, but you beat me to it. Been a while since I posted a link and as soon as I saw it didn't auto hyperlink I thought of you! :)
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wisky Badger Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2018 at 12:33am
I wish I would have saw that seat mod, nice work.
I can get you the dimensions that I used but I would suggest using them as a guide to make custom fit it for your boat.    My boat didn’t have the rear back rest so I had to fabricate that also. I think the key to making the back seat look right is getting the height correct and getting the correct slope on the rear seat base.   To do that I used the observer seat brackets as a template and a Johnson T Bevel to transfer the angles.
T Bevel
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianReno Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2018 at 10:55am
That's my plan I was sure I'd have to tweak it a bit for my application but a baseline to start with will be a huge help.
austinbenincasa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote austinbenincasa Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2018 at 2:37pm
Great boat! Turned out fantastic. Might have missed this detail while reading through the posts. When you painted your new red stripe, was there any protective clear coat that you painted over the red? If not I'm guessing the paint is very durable and can handle buffing compounds? Also, if you were to do it again would you spray on the stripe or use a roller method again?
