  New Posts New Posts RSS Feed - Foam removal
Foam removal
 Post Reply Post Reply Page    <1 34567>
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2007 at 7:28pm
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 9:25pm
hasbeen my pain comes when Eric says he is finished with his pain. Either way you get it done there is going to be pain involved. Eric looks like you are making great progress. Did Randy get his seat back yet? If so how does it look?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2007 at 10:35pm
Ok Eric what the hell are the elbows and flex tubing for? Drainage under the foam? Wire duct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 8:11am
Im curious as well. Ill guess theyre for the blower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 8:57am
blower and venilation for engine compartment, there is one on each side, you have one that connects to the blower and the other to vent it. you'll see the 3 vent tubes up front, those pull fresh air in through the vents on the front of the boat into the engine compartment and the back ones exhaust the hot air
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 9:29am
So that an Eric mod and not factory right? Makes sence and should be an improvement for airflow in the motorbox.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 10:44am
it was actually a factory thing but i did go up in size, there are 3 vents in the front and 2 in the rear, im still trying to figure that one out
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 12:03pm
I think this is probably a better design. I don't think there is enough room on the outside in the Ski Nautiques. However, witht he deep V of the Barefoot, there is room for the vent come down the outside of the main stringer. Just a guess. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2007 at 6:04pm
So Eric who do you ask for help when your stuck on something? Looks like the changes to venting should help the air flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2007 at 7:47am
no one to really ask except for the guys on this site, been around boats long enough to figure things out though
eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2007 at 7:50am
BK the tubes go on the inside of the floor uprights, the exhaust lays on the foam section right next to the mains, pretyy roomy in there i have to say
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 6:18pm
Eric sounds liek you might have an 85 BFN to work on next, but tullfooter just has some gouges no stringers. Sounds like a piece of cake for you.
Any new pics of your latest works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 6:34pm
Eric are we close to having to have me make a final choice on carpet color?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:06pm
i remember you said a darker gray?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:08pm
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:13pm
Looks good! Carry On!
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:29pm
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:34pm
Looks really good. Great work Eric.
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 8:46pm
Eric that looks sweet. It's looking close to being done. You must really be getting after it. Did you miss lunch a couple days this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2007 at 9:25pm
Eric I see the pic of you working on the trans. How did it look on the inside, or don't I want to know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2007 at 8:31am
not only did i miss lunch i also skipped some dinners, I want to get her done, trannies are starting to roll in and i dont want to get cluster f-d,
probably another 2 weeks or so, the hard part is done,
Did you order a prop? and am i installing the manifolds? by the way they are 3.500 at the manifolds then drop to a 3.00 I spoke with the Boat Doc already
farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: March-04-2007 at 9:58pm
Eric,looks great.Did you borrow Skibum's camera for that last picture?   Farmer
sterlingmermaid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sterlingmermaid Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2007 at 6:14am
Eric I haven't been on here for a few weeks did you make the floor out of plywood and then glass over it? It is hard to tell from the pictures
tk
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2007 at 7:40am
Tk 3/4 and glassed it in , resined both sides and edges, used alot of rough cut poplar
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2007 at 9:47am
87BFN, I picked up your 514 Stroker from Robert Yates today. I'll go ahead and throw it on the truck headed for Eric's. You can pay me when you're down in May for the race. Better add a few more inches of pitch to that prop also.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2007 at 9:53am
Cant guarentee the hull with that monster in there
