  New Posts New Posts RSS Feed - Stringers
Stringers
 Post Reply Post Reply Page   123 10>
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Topic: Stringers
    Posted: November-05-2018 at 9:47am
What is the purpose of wrapping the stringers with fiberglass? It seams it keeps the water in and adds to rot. Can the stringers be epoxied down and left exposed to the air to dry out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2018 at 6:06pm
I think the fiberglass adds quite a bit of structure to the wood, kinda like putting it in a pipe.
If you just glued the wood down, once it started to decay, it could separate along the bottom just above the glue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2018 at 6:40pm
That's my point just like in wood boats I wonder if the wood will last longer if it allowed to dry out being exposed to the air.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2018 at 6:42pm
You get have the fibers to bond it with rest of the hull and give it more surface area and strength.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2018 at 10:47pm
Wood boats do rot especially where water isn't allowed to dry typically low in the bilge and aft at the transom. If you bond the bottom of a stringer, the wood that isn't saturated next to the resin will stay wet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2018 at 11:07pm
Just not having foam would be all that's needed. I had a 64 AM Skier in the late 80's with it's original floor and stringers and no foam, no rot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2018 at 7:39am
Michael,
Are you planning a stringer job?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 9:38am
I am having trouble finding Douglass Fur in my area . Somebody mentioned Southern Yellow Pine as a good alternative ? What do you guy's think?
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 11:54am
What type of mammal has "Douglas Fur"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 3:53pm
Mike when Greg did the Pumpkin Patch he got the lumber at Sweetwater lumber
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 5:49pm
That is 1.5 hours one way I hope there is something closer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 5:56pm
Or you could go with the LVL like Kris did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2018 at 6:42pm
Would think a local lumber yard could get it for you. We drove an hour for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2018 at 9:40am
I checked with Sweetwater Lumber they do have Douglass Fur . They Quoted me 152.00 for a 2x10x14 and 75.00 for a 1x6x10. 450.00 for the stringer material is too much even the Southern Yellow Pine was very expensive. I will check into a LVL next.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2018 at 9:45am
Give the Pro Desk a call at your closest HD. Cumming???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 8:56am
Well here it begins . I acquired a 68 Mustang . There is more wrong than right. As fate would have it a 86 Supra comp became available needs a lot but good engine and trans plus other parts at a cheap price. The Supra is in better condition but I already have a 92 comp. The idea is to marry the two together and end up with a running reliable boat that will be easy to pull to CC gatherings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 9:16am
Michael,
Careful with that fiberglass floor pan. Great find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 9:27am
One of those little voices in my head is saying that you'll be getting some comments from some people about putting a lefty engine in the little boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 9:39am
I am sure I will make some unhappy with this build . I am in uncharted waters here . This conversion is dictated by available materials and cost. I am not trying to restore a classic more of a resto mod. I am open to any and all thoughts and ideas concerning this conversion . You guys know more about these boats than I will ever know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 9:52am
My thought is Michael better consider adding plenty of floatation foam after the stringer job.
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 10:04am
Michael,
I will take that floor pan off your hands.....
66 Skylark
93 SN
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 10:22am
Congrats, Mike! That's going to make a great Reunion Rig. You and Gayle will do an excellent job blending original with the "updated" comforts of a daily driver.
When do the tower and ballast system arrive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 10:29am
And you'll probably make more people happy doing it your way
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 11:18am
Go for it!!!   You are a long ways from choosing rotation issues. Rebuild the hull and then make final decisions for drive train direction. Build it to please yourself. Bring it to some meets if you so desire. Don;t worry about the ones with negative comments as they won't show up anyway. Their boats are stuck to the trailers and wont be able to launch anyway
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 11:37am
Please post a pic of the transom Mike, like to see which hull you have. Someone at one time did a lot of work in removing the foam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 11:51am
See the motor box, did you get any interior with it??
Looks like a fun project. Lots of work and $$ ahead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2018 at 3:32pm
Interior, Mike don't need no stinkin interior - he married well and his better half can spit out Vinyl for that little boat in no time flat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2018 at 8:40am
I did a Supra Comp a few years ago . When it came to foam I decided to cut closed cell 2'' thick foam and loosely fit it under the floor between the stringers and bulkheads. That way it didn't block off the scupper holes I added to the stringers so the water could drain to the bilge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2018 at 8:46am
Floor two front seats and upper rear seat and seat pan came with it. Fiberglass engine cover too , Someone said I wont be able to use the original engine cover with the 351 I am planning to install . So it might end up with a Supra engine cover???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2018 at 9:16am
Great looking project. Nice year and style to restore!
