Stringers |
Page <1234 10> |
Author | |||
Sounds like a plan. Better than the pool noodles some have used! ![]() |
Nautiquehunter ![]() Platinum Member ![]() ![]() Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
HD was no help in Flowery Branch I will check in Cumming. I will do the loose foam I don't want to build an anchor.
What do you mean they weren't any help? What specifically did you ask for? Did you talk to the pro at the pro desk like I suggested? |
Mike,
When you call again, do make sure you talk to a Pro at the pro desk but also it may help using the proper nomenclature for LVL's. Tell them you want ether a 1.55E or a 1.9E x 9&1/4". and then the 14' length. |
juniorwoody ![]() Gold Member ![]() Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
I like that Pete is supportive of his place of employment but check Lowes. Much better store and since HD took the veterans discount away from many of us and Lowes gives it unequivocally to all I really respect that. If your a vet it will save you money. Seems HD wants the military person to be either maimed or on active duty so as a Vietnam vet with an honorable discharge, I don't qualify after I once did. To give and then take back is rather insulting. Sorry Pete but the truth. Lowes is very thankful to vets and offers discount to all who serve or have served.
Jack, Sorry to hear you have a problem with the HD BUT, you are very wrong with the vet discount at the HD. You may what to investigate why you personally had the issue. What ID did you use? BTW, I too prefer shopping at Lowes but the closest one to me is 90 miles. |
Pete, I am not wrong about the vet discount. You should check for yourself. Use the same ID with Lowes as well. It is my VA card with photo ID. HD discriminates. against those who are not maimed or active duty. Believe me I have been around the issue with them to no avail. Only ended up frustrated and pissed off LOL. I do take every opportunity to inform other vets that there are other options less offensive. Just spreading the love around as is my way.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11182 |
Pete, read the link below
There's one pretty big difference in the 2 discounts Let's say you served 4 years in the Navy with an honorable discharge as an example. Which place gives you a discount? link Thanks Jack for pointing this out |
I think its the Flowery Branch location . They have never been very helpful . They are more concerned with closing aisles and stocking the shelves than customer service. They once told me to leave a closed aisle and wait for them to stock the shelve . I went to lowes.
DVskier ![]() Senior Member ![]() Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
I have been denied the veterans discount before at Home Depot, then again a few months later it was allowed. All of this happened at the same store. I've never had an issue getting the veterans discount at Lowes, even on sale items. Here in SC you can have your drivers license display your veterans status, HD didn't accept that when it first came out so I had to show my DD-214 form. All in all I'd recommend Lowes if you want the veterans discount. Blowers is also easier to navigate with better lighting.
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13521 |
how should this affect non-veterans?
Just a guess here but if we both went to Lowe's and bought the same thing for 500 bucks, we'd have the same thing except I'd have an extra 50 bucks in my pocket still that you the non vet wouldn't.
![]() I'm kinda simple minded though and I can barely spell 'rithmetic |
please repeat experiment with Home Depot. I'm still lost.
Nautique Newby ![]() Groupie ![]() Joined: March-28-2017 Location: Alabama Status: Offline Points: 93 |
I also used LVL for my main stringers because I could not find Doug Fir around my area. I got my LVL at a local lumberyard. I think I got a 2" x 16" piece and cut it in half. That along with the clear pine for the secondaries was around $100.
I hope I don't screw this up!
Jack, I just got home from the morning shift. I got in this morning and after the morning readiness check for my department, I went and saw my store manager and then also talked with the head cashier. Being very concerned with your problem, I wanted to check the policy just as you recommended. The bottom line is all stores and all areas do not follow the corporate policy completely. My store doesn't follow the policy fully. It seems that the HD's asset management IT has detected fraudulent military ID's in certain areas of the country and those areas scrutinize the proper ID's. You mentioned you were honorably discharged so it sounds like you didn't serve full term. Per my store manager (also a vet) she questioned what your ID is. Is it the DD214? That's the one that can cause problems at some stores in certain areas. Was your discharge based on medical? The VA should issue you a different ID. Sorry this happened, Pete |
Pete, the DD-214 is the official document that you receive when being discharged and it serves as proof of service. The honorable discharge is noted (or not) on the form. It's also possible to receive a General or Bad Conduct discharge. Depending on the service man (or woman's ) conduct they will receive one of these types of discharge. BTW to DD-214 doesn't have a photo on it.
My state and many others will issue a Veterans drivers license upon being presented with the DD-214. Hope this helps. |
Just for you ![]() Go back to my other post about somebody who spent 4 years in the Navy and got an honorable discharge. We go into Home Depot and each get the same 500 dollar item. We both walk out having paid the same 500 as compared to Lowe's where I only paid 450. Lowes gives the discount to any veteran who was honorably discharged, you don't need to have been a career military guy who retired after 20 or so years. The guy who served 4 years gets no discount at Home Depot unless he meets some other conditions like a medical discharge as one example It's in the link I posted earlier, In 2017 Lowes started giving the discount to any honorably discharged veteran. |
HUH?? ![]() ![]() |
1978 Mustang (modified) |
so there are no financial implications for non-veterans at either store
Hey Hollywood, Great Lakes US Navy base is right down the road from you. MAGA and serve your country. Bonus Lowes has no limit of $500 like HD.
Depends how you want to look at it ![]() |
I have a commercial pro HD credit card they used to give a 5% discount for contractors. They ended the program years ago so I don't use their card anymore . I am a very small business but still manage to spend 30 to 50 thousand a year in materials .[ That is 1500 to 2500 discount Hollywood.] I still deal with HD only because they are convenient to get to in areas I work. I wish they would lay out all their stores the same. Its really frustrating to find things in different stores .
Funny that you brought up the layout Mike. I stopped by one of my "local" HD's (it's 50 miles away) for a toilet shut off valve. Wandered the plumbing section finally had to find someone and ask. They were not in plumbing, but rather over where the toilet display was. Was informed that there is actually 3 places in the store where they could be. Could not find the actual one I needed,didn't feel like trying to find the help again so I left. Did buy a case of Mexican Coke though so it was not a wasted stop
Sorry for the unintended thread jack. Thanks Pete for your honest concern. HD deserves the bad review I give them when I can. Will try and answer your questions.
First off, honorable discharge means you served your duty to completion honorably. After 14 months in Vietnam and with my training time included I was released from active duty with the honorable discharge. All those released from the military get a dd214. I have that but I presented my veterans administration card that shows I am enrolled in the program that supposed to help us vets with medical issues. That's another story LOL. Glad you brought up how your store and others don't necessarily follow corporate policy. After the CT HD discontinued my discount and was was still getting it in FL I used to take my slips from Ct and get the discount reimbursed in Fl. That's a gas. My VA card is current and with photo ID so no replacement needed and so you can see how the HD has tarnished their image over what prolly was a well intentioned policy to begin with. It has become downright offensive. Really sorry for the jack here LOl. |
Just being a handful of years younger than you Jack I understand where your coming from. Kinda like to think ole El BJ is in a special place......
I look up the aisle/shelf location/inventory status before going to HD. Saves a lot of time.
BTW, I was there once (hadn't done the presearch) & I asked the customer rep to look up an item location & they couldn't figure out how to do this! |
Jack,
Thanks for the reply and explanation. For those of you that have those fancy phones, and use all those fancy features, there is a Home Depot app that may help you find items. I see customers using it frequently. BTW, my cell phone only makes phone calls!! Chris, Even though I know my store very well, I too will go to the HD web site and look up the item I'm looking for. Not so much to get a location but more so to check inventory and to see if my store even caries it. All HD's do not carry the same inventory and some may be seasonal. Like the Rhinelander store doesn't carry window air conditioners all year like Gary's down there were it's 600 degrees all year long! ![]() ![]() I also use the buy on line and pick up in store very often especially if the item is large or not in stock. When it's available and or picked it's waiting for you up front. Small it will be at the Special Service end of if large it will be at the Pro end. Mike, getting back on track with the thread, ![]() |
Pete, is there a down side to leaving it 1-3/4?
Page <1234 10> |
