Boat Lift |
DPUK
Groupie Joined: January-01-2018 Location: Oxford UK Status: Offline Points: 50 |
Posted: February-16-2019 at 2:44pm |
Hi, had problems finding a cantilever boat lift over here so I built one myself, just wonder if anybody tell me what is the best material to use for the bunks, have looked at some Shoremaster lifts here in the uk and the later ones seem to use timber but not been able to investigate too close as they are covered with carpet and nobody at the lake to ask as we are closed until next month, its for a 1997 196 if that makes any difference.
Cheers Dave |
Barefoot Gramp's
Dave,
You must have pressure treated lumber for rot resistance over there correct? That's what is typically used here. |
DPUK
Yeh, I figured that's the timber to use, do you think 2 x 6 would be ok
Barefoot Gramp's
Dave,
A 2x6 may or may not work. It depends on how it's mounted and how much support it has. How about posting some pictures. I'd love to see what you came up with anyway. |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Online Points: 1415 |
If you use wood take a look at Accoya treated timber we use here in Europe.
Lets have a go
Roger, I see it's also available in the states! I'm going to have to do some more research on it. |
DPUK
Morning Guys, 06; 30 Sunday here, will post pics later today when it gets light, basically took all dims from another well known make and re produced in my garage using a chop saw and pillar drill . plated and bolted all joints as you will see and then took to an engineering company just up the road and had it welded. Now to start on the canopy, this should be fun as I have bought a new tig welder and going to teach myself to weld so I can do all of it, could take some time as I an aware of the problems with welding ally. just made sure anything that was going to lift the boat was welded by professionals. sorry going on too much now. will send pics ;ater today
Cheers Dave |
Barefoot Gramp's
DPUK
Wow, just looked at accoya, 50mm x 150mm x 3.4 mtr nearly £300 may use u secton ally.
plenty of time, will keep on searching. Cheers Dave |
Barefoot Gramp's
DPUK
Sorry guys having problems uploading photos, will keep trying
cheers Dave |
Barefoot Gramp's
uk1979
Lets have a go
DPUK
Very good my friend you got it in one.
Barefoot Gramp's
