Velvet dip stick |
Page <1234 5> |
Author | |||
jterr ![]() Gold Member ![]() Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Now that the dipstick has been resolved
![]() Seeing as I have all this out of boat, should I rebuild the Velvet Drive? When I bought the boat I never had a chance to drive because stringers were so bad. I have looked for rebuild in forums but can't find, still not asking the right way I guess. Thoughts and Suggestions Thanks JT |
wheedle ![]() Newbie ![]() Joined: February-22-2019 Location: Seattle Status: Offline Points: 6 |
If you have something to spin it with, you can test it. Keno has talked about using a pto off of a tractor.
I have read this before, but have yet to rebuild mine. https://www.mastercraft.com/teamtalk/showthread.php?t=53874 |
Very good info, think I will rebuild as I have it out of boat.
Thanks |
Why jump to conclusion that it needs rebuilt?? I think lake testing would be my choice. But first drain the fluid out and look for debris. If it does not show a lot of metallic particles and or chunks then chances are good that it is OK. Rebuilds are not the easiest thing to do. Get a manual and review it. There is a video on Master Craft forum that is very helpful also. Some special tools and an arbor type press are needed for the clutch pack. Seals and gaskets don't constitute a rebuild.. One of our senior members was going to report back to me what a "full rebuild" consists of but I can't seem to find that post. Good luck |
1978 Mustang (modified) |
Motor and tranny are out of boat sitting in barn...... |
OK, I and others have rebuilt them. If you need assistance it is only a "post" away
John,
Good advice from Duane. Drain and pull the suction screen at the bottom of the case looking for debris. If it looks good, don't open it up. I have 54 years on a velvet at it still runs like new. |
Don't be too surprised if the screen is missing. Some have been tossed. ![]() |
Don't expect the price to be the same as this one was. ![]() |
Ok before I just start unbolting things , where is this drain plug and screen located ![]() |
John, The screen will be behind the cooling line (hose) fitting towards the bottom of the case. |
Will check it tomorrow, if it warms up going down to 35 (WTF in Florida) tonight.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10786 |
Here in the link below is how a real backyard hack would test his transmission ,(partway down the first page). You can at least see that it spins in fwd and reverse and check pressures in fwd and reverse too with a couple of gauges. Duane, I see some words about what a rebuild is or isn't from that senior member you refer to in the same linked thread ![]() link |
A little light reading from the reference section of CCF in the link
Page 54 has strainer info If you have a 10-17, it's a later version of the 71C and most of the same info applies. You can find later manuals that also cover the 10-17 but not in the reference section of CCF link |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3624 |
The tranny is like an automatic. Fiber Plates inside squeezed between Metal plates when you engage. There will be material in the oil. These are very durable tranny's and easy to repair when broken so I would vote for use it after installing new fluid. Run it a while and install new fluid again just to make sure it is clean and ready for long term use.
I made the mistake of using my reverse as a brake in a panic stop and broke mine. the clutch plates fractured. It was not hard or expensive to fix it. I was 20 years younger then so maybe it would be heavier and harder to do now. |
But Mark, using reverse on a boat are the brakes. ![]() ![]() |
Speaking of reverse...
Is this a reverse rotation engine. I looked for a tag but I guess when the PO did all his crap to this engine took it off. It is a 351w PCM I'm guessing as it is painted a gold color???? Also while removing the alternator it wasn't hooked to anything , so it is probably wrong also.... ![]() |
Take a pic of the prop. Or if it is an ACME prop then post the part # |
Pete, going to neutral probably would have been just as quick of a stop but I was rolling at 40mph coming around a blind curve in the river to find 4 boats coming at me head on, one jet boat cut hard right for some reason which put us on a collision course. I went for panic stop, avoided any collisions but scared the poop out of me. We avoided contact by about a foot, no more. My reverse at full throttle came from many years driving jet boats, the technique worked much better in them. Blew the clutches right apart in the velvet drive.
I still had enough forward gear to make it back to the dock without reverse. Fixed it in one day in my garage. They are pretty tough. |
Guessing you only broke the reverse clutch disc and then it lost mesh. Should not hurt anything else. (other than your pride)
You could pull the plugs and distributor cap and turn the engine from the harmonic balancer bolt. From the front turn it CCW and if the rotor turns CCW you have a reverse rotation engine. That'll be a definite way to tell without having to make any assumptions |
I think I make out a XX RH 13????
Speaking of props, what is the difference in a 3 blade and a 4 blade (I have on my 79)
1
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6119 |
Pete, I am guessing by context and how he said it, he wasnt braking for a nice gentle stop while idling into the dock. I get the sense it was a pretty quick 35 to 0 in 15 feet kind of stop. |
Was wondering if the 4 blade will work on the 83 ![]() |
Well theoretically a one blade prop will “work” . What you need to ask what prop would be best for my boat and my use.
Back to the tranny , I took this out
Is the correct part to drain and check? If so I saw no debris in the fluid although ( drained it though a paper towel filter) it looked a little dark. That being the case might just keep as is and replace fluid and see how it runs once I get boat back. |
Told ya so |
Where can I find that hose and fittings in picture? That fitting is rusted pretty bad and I can't get it to thread back down into the tranny, as it is binded up at the top of elbow.
Page <1234 5> |
