  New Posts New Posts RSS Feed - 81 Southwind81 19' stencil
Southwinds81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Southwinds81 Quote  Post ReplyReply Direct Link To This Post Topic: 81 Southwind81 19' stencil
    Posted: April-23-2019 at 10:37am
Hi all. I am looking for the stencils for a 1981 Southwinds.   Any and all help is appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2019 at 1:25pm
Mark,
Do you mean stencils (paint mask) for hull side graphics? If so, I feel you will not be able to find them. Are any graphics still visible? They can be traced and then a vinyl sign shop can make paint masks from the tracing.
Are you in the process of restoration? tell us more and post some pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2019 at 3:12pm
If you can see the old graphic ghosting, you could also tape them off and repaint them with rustoleum. Looks a little complex but it could be done and at least it is single color (what I see in the brochure). I like a vinyl tape for that process. 1/4"-1/2" for the longer lines and curves and 1/8" for the tight curves. Good luck, and yes, pics please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2019 at 3:25pm
Originally posted by samudj01 samudj01 wrote:
   I like a vinyl tape for that process. 1/4"-1/2" for the longer lines and curves and 1/8" for the tight curves. .
3M fine line tape
Post Options Post Options   Thanks (0) Thanks(0)   Quote Southwinds81 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 9:26pm
All of the stencil was buffed off so I nee some sort of stencil or guideline to go by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 10:06pm
Mark,
Sorry to hear the graphics were buffed off. A PO? The early 80's Southwinds weren't a model with large production numbers so finding one to copy/trace the hull graphics is going to be a challenge. Have you checked the diary section for other Southwind owners? .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 10:11pm
Mark,
I just did a search in the diary section. Between 79 and 82, 22 Southwinds pop up. I suggest trying to get in touch with any of them who would be willing to trace the hull graphics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Southwinds81 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2019 at 10:06pm
That is great advice, thank you. I will do that.
