  New Posts New Posts RSS Feed - 56-Atom next steps help
56-Atom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2018 at 10:35am
Thanks for the info. I will look around and change out for the spring start-up. Any reason to add the zink additive now for the winter storage?
I appreciate all of the wisdom, care and attention this forum shares as I wish not to damage this piece of family history...that also needs to pull some skiers as it was built to do!
56-Atom
https://www.facebook.com/media/set/edit/a.1729455880510267/
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2018 at 11:07am
I'll attempt to share a few links of the motor running: if this does not work I will attempt to share a facebook link
First fire up: Pardon the excitement
https://drive.google.com/file/d/1PaSyZtkbR_iwwLNm7rU9cA4y7GUzVP09/view?usp=sharing
First Float running one 1 cyl
https://drive.google.com/file/d/1hKE34yeOkkBJRWl0FGOoWTdYA-T7ufJF/view?usp=sharing
2nd float w/ four cyl fired up:
https://drive.google.com/file/d/1TKkFaSF5qUPZxMTsQbKTHLVKPNRLSpRP/view?usp=sharing
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2018 at 11:48am
Attempting a facebook link:
https://www.facebook.com/media/set/?set=a.1729455880510267&type=1&l=0b02f55d2f
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2018 at 8:38pm
staying with 6-volt system and wondering if "original" fuse panel is safe or should I upgrade?
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2018 at 9:19pm
John,
The fuse panel is not original. They weren't fusing any electrics back then. Why do you feel it's unsafe? If anything, it makes the boat safer. Keep it.
BTW, for those of you who are ACBS "naysayers", adding fusing is NOT a point deduction in a judged show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2018 at 10:38pm
Thanks Pete,
That would explain why a closer look reveals turn signals, heater/AC ect.... looks like it car off a car panel.
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2018 at 10:51pm
Any points-off for wire ties?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2018 at 7:24am
Originally posted by 56-Atom 56-Atom wrote:
Thanks Pete,
John,
It's not a panel off a car. It's a Stewart Warner marine panel.
EDIT:
John,
Sorry, I misunderstood your post. I was too focused on the gauge panel. Yes, the fuse panel could have been made for a car but as mentioned, the gauge panel is a Stewart Warner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2019 at 6:01pm
Boat update:
1956 Atom was launched last week with several days of cruising around Silver Lake, Michigan. We even pulled up my 18 yr old son up on 2 and dropped 1). More adjustments I am sure will come as she tops out at 2500 RPM's at this time. Thanks for all the help on this project.
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2019 at 6:07pm
John,
You should be getting at least another 1000 RPM. What prop (dia. and pitch) is on the boat? Have you set the timing? Setting the timing on the old flat heads is easy. All you need is two people. One at the helm giving it full throttle and the other at the distributor. You turn the distributor till you get max RPM and back it off slightly.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 10:58am
Boat update:
No pictures of your boat from the top of the sand dunes? Silver Lake is beautiful. Good luck with the Atom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 12:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 3:12pm
Boat update:
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 3:16pm
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 3:22pm
Thanks for re-posting these...almost forgot about the first fire-up day! All that excitement over one cylinder...
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 4:51pm
Ah to be 19 again at Silver Lake with a dune buggy and a Bultaco Alpina. Seems so long ago.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2019 at 6:55pm
John,
Will check props when back up at the lake later this month. I did try to adjust timing as described, but no higher than 2500.
Any one near the Silver Lake Sand Dunes area from July 27-Aug 4th are welcome to stop by for a beer, some tinkering on the engine, a ride on the lake and I have a Jeep we can hit the dunes with.
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2019 at 1:31pm
John,
Thought I would give an update on the 56-Atom. After a great first summer of cruising at sub-rpms of 2500 which was good-enough, I went back to tinkering on things. We checked everything and applied all recommendations from the forum group, change of props, timing, fuel intakes, air, carburetor linkages, jets...thank you!
On the day that was to be the last run of the season...met an older gentleman at the boat launch who offered to take a look. He immediately ID the issue as a weak breaker arm spring. I adjusted it with a slight bend via needle nose pliers and we ran it up to 3000rpms. Adjusted timing (which is pretty fun with my daughter at the helm running wide open down the lake with one hand on the ski pole and the other on the distributor cap) ...with no improvement.
Back at the garage...replaced breaker arm spring, adjusted points .020 and talked my wife into doing one more run for the season...and to our excitement, we watched the RPMs tac up to 3400 which is max per manual. A wave runner clocked us at 32 mph. Felt exhilarating and hoped the old plywood would hold together!
Have put her to bed for the season and look forward to making her "more original" for some shows next summer as well as getting to a reunion or two.   I think the FB link covers most of the steps in the restoration that began in 2012.
Thanks to the CCF community, you have been a major part of getting the 1956 back up to speed!
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2019 at 1:51pm
MechGaT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: November-10-2019 at 8:15pm
Nice! Looking good!
'92 Sport Nautique
