  New Posts New Posts RSS Feed - Fuel Sender / Gauge Issue
91NaughtyQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Sender / Gauge Issue
    Posted: July-23-2019 at 4:26pm
I know there has been many posts about the subject, but I couldn't find an answer so posting now-
The issue I am having is that the gauge reads empty once at half a tank. I have visually inspected tank level.   I don't want to just order a new sender if there may be something I can check and or fix. Any thoughts?
Thanks,
Gary
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 5:45pm
Gary,
Without pulling the sender, the only things you can check/do are:
Clean all connections that may be causing extra resistance.
Make sure the tank sender is grounded well with no resistance to the block.
Check to see I you get the 12 volts nominal to the gauge.
I have a feeling there's an issue with the sender.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:14pm
Thanks,
Gary
Did this just start happening or has it been like this for a long time?
1993R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1993R Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:19pm
I had the same issue and replaced the sender with one of the new electric ones.
It helped a little but I still hade the same issue.
Now only 1.4 tank off
It ended up being my contacts in the dash.
Once I cleaned them it was fixed.
Also lowered my temps by a few degrees
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:37pm
Thanks,
Gary
It has been this way for a while, but I didn't realize it. I just thought I was burning through a lot of gas. It dawned on me when I was on E (I usually never go below between 1/4 - 1/2) and went to fill it up and it only took 16 gallons.
Thanks,
Gary
1991 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:40pm
I completely rewired the dash 2 weeks ago, (fixed my temp issue and a host of others as well) so that isn't it. I did a quick test (ski dim tech had me do it) and the sender is bad. Ordered a new one today. I will post an update once installed and I go below 1/2 tank.
1991 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:46pm
   I did a quick test (ski dim tech had me do it) and the sender is bad. .
Gary,
Did he have you ground the sender wire to see if the gauge pegged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:51pm
I imagine he had you ground the sender and watch the gauge peg at FULL. (edit Pete was a little faster on that question)
You probably have the floating arm type sender and often with a little patience you can tweak (AKA bend) the wire arm that the float is on to get reasonably accurate readings from FULL to EMPTY.
You might have to do that with the hew one too if you bought the same type .
If you got one of the electronic WEMA type, they're generally better as long as the tube is right for the tank depth.
You can search for WEMA on here for info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 6:59pm
Gary,
Yes
1991 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 7:01pm
Keno - That is correct and yes it is the old float and arm type. I bought one of the new stainless ones with the rod to the correct length and the float rides up and down on that.
Ski Dim Part
Gary
1991 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2019 at 7:04pm
Gary,
Yes
That's simply a very quick test and not at all conclusive. It basically tests the gauge and not resistance in the wiring from bad connections nor the sender.
Get the VOM out and:
Gary,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2019 at 12:34am
New sender fixed the issue. Thanks for all the input guys.
1991 Ski Nautique
