I'm an idiot... problems at the ramp |
ViperSammy ![]() Newbie ![]() ![]() Joined: August-13-2019 Location: Georgia Status: Offline Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: August-20-2019 at 3:59pm |
So, I have mentioned that this is my first Nautique, and I am working through some rough running issues...
To that end, I went to put the boat in the water to give it a test run, by myself. Something told me to keep it strapped to the trailer, but did I? Nope. ![]() So, there it sits. I checked underneath and it was sitting on the prop and rudder. ![]() The rudder is not bent, it just is scraped up on the bottom edge. I am so mad at myself, I can't see straight! A little word of caution: Trailer bunk glides are REALLY slick! I put these on my trailer over the weekend, and it really made loading it at the ramp easy. And I was able to "brake check" the boat up into the stops. But, I didn't think they were that slick. I was not going fast down the ramp, and I did not hit the brakes... But, I heard the sickening sound of metal on concrete and stopped immediately. Anyway, that finishes my year as I will be returning to work soon, and have to winterize it by this weekend. What should I be on the lookout for before putting it back in the water next year, other than the obvious? Don't be like me, Scott |
'85 Ski Nautique
bfootr ![]() Senior Member ![]() ![]() Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Don’t feel bad. Happened to me over 30 years ago. Guy pulling me out popped the clutch and I had not hooked up the front. The back of the boat slid off onto the concrete. Painful lesson learned!
Don’t beat yourself up too much. But do put carpet back on the bunks. I was test driving a Ski Nautique once for another party out of state. Blah blah blah, finished up a lack luster test drive and the seller backed the trailer in really really deep. I thought well that’s not how I do out but wtf... I drive the boat onto the trailer. Boat is floating. Seller hooks the bow hook which had a broken safety clasp. Seller pulls out and for a moment the hook catches and pulls the boat with trailer but as the trailer started to grab the boat the bow shifted and knocked the broken safety hook off the bow eye. The trailer caught the boat for a second but as the boat was 85% out of the water, with me jumping, waving and shouting in the boat, seller had windows up, tunes on, ac max, and the boat slid off the trailer and landed completely out of the water, on concrete sitting on the hull and running gear.
Thanks for the encouragement...
Even though I knew I wasn't the only one that's ever done this, I still feel like such a fool. ![]() ![]() ![]() Learned my lesson, and will NOT let it happen again. And yeah, the glides are coming off in the spring. And the trailer is getting a winch. Scott |
'85 Ski Nautique
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 891 |
I feel your pain...
I always thought it looked cool to drive-on/off at ramp. While everyone struggles with guides, winches, etc my wife would back in and before she came to a stop, the boat was on, pushing against stops as she gently drove out. Boom! Done! Always feared that the boat would simply slide off with me in it, fortunately never did. Now I'm one of the guys winching and strapping before pulling out of water. With a winch, try and mount it so the strap pulls level, and not downward. You don't want strap tension so tight downward that it 'lifts' the transom off the bunks. Pretty boat btw... |
1994 Ski Nautique "Riot"
You wouldn't happen to have a good picture of your winch setup, would you? And thanks, btw. It needs some gelcoat TLC. But, otherwise it's in really good shape. Scott |
'85 Ski Nautique
Is this before or after ramp incident? ![]() ![]() |
Ha! Already ordered a new prop. Will have to wait until spring to really check it out, but it didn't look like the shaft was bent. The rudder was damaged, but I don't think it's too bad. Everything seemed to still be tight under there as far as the prop shaft strut. Scott |
'85 Ski Nautique
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3633 |
Sorry it happened. Might wish to convert back to carpeted bunks.
Even with carpet, if the carpet is wet the bunks are really slick. We should all keep this in mind. I was in a car wreck while towing with wet bunks leaving the lake 4 years ago. I had tie down straps on the back and poles with a winch in the front. The stop poles bent out in a huge V shape, my tie downs both snapped and the boat came up and over the guide poles and almost into my rear window. This was from a panic stop and a 10 MPH collision. The wet bunks offered little resistance to the boat sliding forward so I can imagine they offer little friction to keep the boat from sliding backwards. I did see a boat slide off the trailer while pulling out years ago while fully loaded. It was a mess. I now have a safety chain connected to keep the boat from going forward and another to keep it from going backwards on the trailer. We live and learn. Our 78 Nautique had only the winch in the front, no straps in the rear and we used to drive it on the trailer and pull out every time, in the old days I was towing with a front wheel drive car that had no power, by powering the boat forward on the trailer it gave us enough power to get up the ramp, we never hooked the boat to the trailer till we were out and drying it off for the drive home. Looking back I think we were lucky to never have it slide off. I think it will be prudent to use a dial indicator to verify your prop shaft is still straight. Measure as close as you can near the propeller mount on the smooth surface not the threaded end. Slight bends will give you lots of vibration. If it bent this is where you will find it. Good Luck. Mark |
Thanks Mark... Interestingly, my cousin pulled the boat to me from Indiana, while I wasn't home and put it in my storage unit. When I went to put it in, I immediately texted him and asked, "Do you know you pulled this thing 1100 miles and the boat was not strapped to the trailer?!" Funny thing is, this boat spent most of its time in the water on a lift. They only ever trailered it from the ramp to their garage, about 5 miles. It never had an anchor, cleats or fenders because they just didn't use it that way. I will have the prop shaft checked out before I use it again. Thanks for that. Scott |
'85 Ski Nautique
Yea those bunk glides work in both directions...
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2901 |
+1 for the idea of a bow-hold down chain. I installed a grade 80 chain as a "crash chain" when I rebuilt the trailer last year.
Like the original post, I had a similar incident that ended OK because of the crash chain. I was in the boat and my son was backing the rig into the water at the local marina. My son removed the stern tie-downs properly, but then removed the bow strap without my knowledge. Fortunately, he did not remove the crash chain. While backing down the ramp, my son applied the brakes and the SNOB started to slide off the rear of the trailer. I was mid-scream when the crash chain pulled tight and the boat stopped its backward slide........still safely on the trailer. The only casualty was the soiled under armor... JQ |
Johnny I believe I would have dirtied my pants also sitting in the boat when that happened.
The reason I added two chains was to keep the boat from sliding back with one and the second chain keeps it from sliding forward. Going backwards my chain allows maybe 4" travel before it would stop the boat. Going forward it might allow 2" forward travel before it tightens and stops the boat. I found once it starts moving all that weight and speed of movement add force that can cause damage. Best to stop it early or keep it from moving to start with. I was not smart enough to figure out how to achieve front and back movement with one chain. Overkill to some I am sure but I had the failure and had to pay to fix the results. It all happened because Deer ran out in front of us heading home from the lake. And I learned from that, if Deer Run out in front hit them! If you hit them your insurance blames the deer and you get a free pass, if you wreck while you miss the deer the insurance company blames you and you are charged as at fault with an accident on your record and paying deductables on the repairs. |
From the picture that prop doesn't look that bad.
Send it to Delta they'll fix it, I've sent them worse than that and they turned out fine. |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10808 |
You've got me curious now JQ, boxers, briefs, boxer briefs, maybe boxer jocks ? ![]() |
Yeah, return those bunk slides to the vendor along with your repair bill for damages.
I rarely hook the bow on any ramp really. I will if I have an inexperienced driver in the truck or the ramp is super steep. The bunks do a great job of holding the boat in place. CC trailers were designed to be drive on in operation and are some of the best in the world. They don't need any help as they were designed properly from the beginning. I'd look more at the shaft being bent than the propeller damages. You can check the shaft without driving. Go to Harbor Freight and pick up a cheap dial indicator with a magnetic base. Set it up aft of the strut as close to the taper as you can get it. Rotate it and record the differences in 90 degree increments. Sorry for your problems but at least there's no gel damage. |
Thanks for that. How hard is it to replace the shaft if it is bent? And, any recommendations on which dial indicator? There are several on there, and I am sure one works better than the others. Thanks again, Scott |
'85 Ski Nautique
I think they used to sell a kit with a stand. Go for that or just grab one one amazon. something that measures .0001 should do the trick.
And.whatever you do ....................don't forget to take into account the all important issue of carpet directionality as so thoroughly discussed in typical CCF fashion in the thread linked below
![]() link |
That's some funny stuff right there! I plan to replace the carpet on the bunks next year. My conundrum is that I don't have a place to keep the boat while I work on the trailer. I did the glides while we were at a condo we rented on a lake here. Has anyone had any luck just lifting one side of the boat enough to replace the carpet? I do use a turnbuckle now that I bought recently. I had it on until I got to the ramp. Obviously you can't leave it on the boat to launch. No safety chain, yet, But, I want to install a winch, since I often load and unload alone. Scott |
'85 Ski Nautique
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
A piece of rope tied from the trailer to the lifting ring works wonders. Doesn't have to be tight, but will save your boat it slips back.
Anyone had any luck filing an insurance claim for these "accidents"?
Not trying to commit fraud, but I wonder if this would be covered? Scott |
'85 Ski Nautique
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3340 |
I would eat it and not deal with increased rates or nonrenewed policies headache.
They will get it back from you one way or the other So I guess you have your choose of headache |
I kind of doubt they would cover it anyway.
The Comprehensive on the policy's examples are more natural causes and stuff, than accidents or mistakes. Scott |
'85 Ski Nautique
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6119 |
yup. Not making sport of anyone, just "lessons learned" Pretty sure we've all done something like that. Those skids have bitten more than one person. I never did that, but I did almost sink my boat and fry my engine one spring when I dropped it in and started it up with the water inlet hose detached from the thru-hull. Not as bad as one incident I witnessed at a ramp once. Guy backing his I/O down the ramp. About 20-30 feet shy of water, boat slid back. Lower unit dragging along the pavement. Guy in car didnt hear or see it. Kept backing up. Others in his party start screaming at him to stop. Finally did. Dont recall how he fixed it. Can imagine he winched it back up onto the trailer, but I dont remember. |
It kills me when people jump in their vehicle and back down the ramp with the windows up, A/C cranked and radio on. ![]() I heard and felt this as soon as it happened. |
'85 Ski Nautique
desertskier ![]() Platinum Member ![]() ![]() Joined: December-19-2006 Location: Az Status: Offline Points: 1115 |
I hit an underwater rock and my insurance covered it. I have Boat US insurance. They didn't even blink. New prop, rudder. shaft, strut and some gel coat work. At the time it was about $7k. It doesn't hurt to ask them or contact your dealer and let them handle it. Also the dealer installed an ARE shaft, 4 blade prop and a tune-able rudder. |
RealDeez ![]() Senior Member ![]() ![]() Joined: August-01-2019 Location: MI/IN Status: Offline Points: 130 |
Saw a boat drag an Escalade all the way down the ramp and into the lake with all four wheels locked all the way down once. I think he thought he was going to shoot it off the trailer. So it can go the other way too, I suppose.
Putting our 93 sport in I have to give it so much gas I'm not sure it could slide off the carpeted bunks but now you've made me even more nervous than usual. |
Lake James, IN
93 Sport Nautique |
80SN Barnfind ![]() Senior Member ![]() ![]() Joined: December-13-2010 Location: Niagara River Status: Offline Points: 122 |
Scott, Here's a link to the setup for my '80. LINK Bunch of other threads on winch posts on the site as well. |
Knowledge comes by taking things apart: analysis. But wisdom comes by putting things together.
Nice! I need to learn how to weld.... |
'85 Ski Nautique
