  New Posts New Posts RSS Feed - Overheating
Overheating
Evilsizer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evilsizer Quote  Post ReplyReply Direct Link To This Post Topic: Overheating
    Posted: September-02-2019 at 11:26pm
My 78 does not overheat on a fake lake but does when in the water? I'm so confused
bfootr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2019 at 11:36pm
Same thing happened to me. Probable cause is a bad impeller and/or obstruction to or from the water pump. In my case, most of the vanes of my impeller had broken off and were lodged in the water pump INLET hose. Would run at proper temps with the Fake a Lake attached (due to the added water pressure and simply idling, but would over heat at the lake especially when accelerating). Check the impeller first and see if there are any obstructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evilsizer Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 12:36am
Thank you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 1:37am
The fake lake supplies water from your hose with 35-60 pounds of pressure.
Your Raw Water Pump depends on suction to pull water from the lake.
If you are overheating at the lake there are a few things to verify and check.
As already mentioned if you had an impeller fall apart in pieces those pieces all need to be retrieved. You will find them spread out in your cooling system.
The only real way to get them out is to remove the hose and start flushing each of them.
From the boat inlet all the way to your exhaust manifolds. The thermostat sometimes catches a few pieces and one member reported finding chunks inside his main engine block water pump.
While doing all this you might consider adding a Timmy T, affectionately named after our own TRBENJ who invented and shared his how to tips.   The Timmy T is actually much easier to hook a hose to and it only works if your raw water pump is providing suction so it more accurately acts like pulling water from the lake.
All hose connections on the inlet side including your water strainer must be sealed tight or the raw water pump will pull air rather than water.
If you have any air leaks you will struggle to pull water to cool properly.
To find the posts that give this information it helps to use Google or DuckDuckGo, type in your request, TimmyT   Correctcraftfan and search. The forum here is great but the search funtion is not so great, the google search is more effective.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evilsizer Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 5:33pm
Could the pump be on upside down?
RealDeez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealDeez Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 6:11pm
That never happens.
(Extreme sarcastic tone)
Lake James, IN
93 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 7:49pm
Originally posted by RealDeez RealDeez wrote:
That never happens.
Guilty as charged!
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: September-03-2019 at 10:52pm
Guilty as charged here also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evilsizer Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 11:21am
Hey guys. Just purchased the boat. A 78 Ski Nautique with the 351. My impeller is missing chunks. I checked the thermostat housing and found no thermostat was installed. Does this mean a total rebuild?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 3:39pm
Again, no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 3:48pm
Keep pulling hoses till you find the missing pieces. Reverse flush if possible and Install a new thermostat. Your boat would take the 140 thermostat. Buy the Marine version.
Shooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shooter Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 4:59pm
I had a similar problem on my 2000 SN, but solved it with bfootr's advice. I had searched long and hard (and unsuccessfully) for the vane pieces downstream of the pump. Finally found them on the inlet side!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 6:08pm
Yes, when you pull the boat out of the water, the cooling water runs backwards..
