GT40 No Start |
Post Reply | Page <123> |
No problem Ken I realize it gets frustrating and confusing for Kyle having to relay all this to his mechani . Did not realize how the diode had been wired up but I was curious so I looked at the diagram
DAC 207
Newbie Joined: October-07-2018 Location: Maine Status: Offline Points: 8 |
I just went through a similar problem with a functional low pressure pump and in intermittent lack of output from a new HP pump. I had a failing kill switch that would allow the fuel at start then die allowing the motor to run for 2 second then stop. Jumping the kill switch fixed the problem ( new switch will be hear in two days).
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11034 |
Maybe you should update your other thread that says the issue was the high pressure fuel pump Here's a link to it link |
BlueDub
Groupie Joined: July-02-2014 Location: antioch Status: Offline Points: 40 |
I picked up the boat from the mechanic yesterday and got on it in the driveway last night. He is confident that everything is working and the HP pump is just bad (maybe defective from out of the box). Frustrating because the assumption that it was good for it was new potentially led us on a wild goose chase. Anyway, before ordering another pump I wanted to poke around and see for myself. I jumped the pumps like in the picture, they both made noise. I unplugged LP to clearly hear HP humming, it was. I disconnected the return loop hose and it was squirting fuel with both on, but with the LP pump unplugged and jumping just the hp no fuel comes out of the hose. It is making noise, but seems to not be moving any fuel.
BlueDub
Thanks Dac. I’ll jump the kill switch for safe measure before swapping pumps. It does crank and when you push it you can hear the pump so it appears operational, but at this point I see assuming things is not a good strategy. I do regret not tackling this thing myself from day 1, but I just really hoped the pros would just make short work of it and get us back to skiing. Anyway live and learn, lifetime of CCF learning makes my future bright.
[QUOTE=BlueDub] I just really hoped the pros would just make short work of it and get us back to skiing. QUOTE]
Don’t think there is anything wrong with that thought. The problems we have are a short season anyone good wants to work all year. Then the fact that for the most part they have been pretty reliable so there is less experience and are now also obsolete so no support. Now throw in the fact the youngest ones are pushing 20 years doesn’t help either. |
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 329 |
Take a close look at the hose leaving the HP pump. they have been known to fail and that would just pump all the fuel back into the FCC.
You need to put a pressure gauge on it or you will just be guessing that it's working as it should be. It's simple to hook up, they don't cost much and can keep you from throwing money and parts at it. |
BlueDub
New pump is in. Starts and runs for a second or two then dies. Is it maybe the PIP keeping it from running. It won't stay running with it jumped either.
It seems to me that you still haven't put a fuel pressure gauge on it recently. Without knowing the fuel pressure with the key on engine off and jumpering the pumps with the STO plug, you really don't know much at all What's the pressure with the newest HP fuel pump installed You could randomly throw a distributor in it as the easiest way to resolve a PIP issue if there is one, since the distributor has to come apart completely to change the PIP sensor Or you could randomly throw a TFI 4 module at it too, but they're all shots in the dark. So............I'll yell it kinda loud WHAT'S YOUR FUEL PRESSURE? |
BlueDub
The gauge I have is not great but it shows near 12 psi with key on and jumper attached. New pump no difference. I'm going to open the fcc later and check the wiring inside because the 12 volts I was able to measure was at the plug outside, I'm thinking maybe the lead that goes through the fcc maybe? Or that hose in there, but I inspected that and it looked good. Hope to have time after work today.
It should be 39 +/- 3 psi.
You probably have a fuel injected car hanging around that you could test the gauge on to see if it's accurate if you know what the car system has for a pressure spec. Or you could get a loaner gauge from a parts store and compare readings. |
BlueDub
I’m at work on lunch planning my attack for when I get home. I suspect that this wire pass through is not delivering power to the pump, because I do get that 12 volts right up to that plug outside of the fcc. Planning on checking the spade connectors inside as soon as I get home. But this plug available on SkiDim does not look exactly like the one I have on my fcc. https://www.skidim.com/prodinfo.asp?number=RF121085
There had been a change over the years because the older style could leak. I’m sure skidim has the picture of latest version
BlueDub
I figured it out! Will post details in the morning.
tryathlete
Waiting with bated breath, for the answer to the problem.
Looking at the time he posted, maybe he was having a dream
He was just logged on at 4:26 pm with no update to be had. I think I'll just assume he's too busy driving it to do an update right now |
BlueDub
Unfortunately we are no-wake everywhere around here because of the recent storms, I was lucky enough to have my mom come and hang with the kids today so I could get out there and install the new interior and do major detailing. I was not dreaming last night, I was up all night until the wee hours cleaning up the mess made by 8 weeks in two different shops. Which leads me to the explanation of the problem. Here is my conclusion and process last night which led me to it. I will attempt to present it somewhat completely but it was quite an ordeal as you know.
Started by checking voltage from lead all the way to the HP pump itself along the way refreshing connections as nicely as possible. 12 volts to the HP pump without a doubt. So why is it not moving fuel? Inspect that little hose, it is in tact but somewhat soft from sitting in fuel, notice that it has a little crease from where it might have been folded/twisted, simulate what might happen if the filter binds in the can when it is being screwed on and sure enough that thing folds like it was stuck that way for about 8 weeks. So I flipped it, (this was about midnight so I'm not going to ACE to buy fuel line) thinking it will not likely kink spinning in the opposite direction. I also trimmed a bit off the end to have a nice tight fit and be sure it didn't bottom out in the can and push up to kink also. Screwed on the can so carefully that I was sure the filter didn't bind. Now I have positive without a doubt voltage to pump and no way that hose is the problem. Why is the fuel not dumping out the return in the tank?! I decide that I need to go back to square 1, lots has happened in two months and who knows, better start at the beginning. Check the screen in the fuel pickup in the tank. That is where I notice the most disturbing thing, there is no anti-siphon on the pickup! Look at the return and there it is, someone (not me) took them both apart and reassembled with that on the return, no way for fuel to flow into the tank. I am so excited I am sure that I have figured it out, make them correct, turn the key to hot and the fuel is dumping out the return. Yes I have done it, time to celebrate, turn to start and nothing. Are you kidding me!! Maybe if they had that wrong what else did they do? Look carefully at the fuel lines routing from the FCC to the injectors, try to remember what I read, it goes passed the regulator and then to the Schroeder valve? or the other way? I'm delirious because it must be 1 am but I'm going to flip those to see, what is the worst that could happen? Hit the starter and it starts and runs like new. Run into the house to tell my wife, get reprimanded for smelling like gas and sent back outside, go back outside shaking with excitement from the accomplishment. Wow. So after that I spent some time winding down and preparing to put in the new interior cleaning up the mess and whatnot. Sidenote, that was Friday the 13th and there was a full moon so I walked down to the lake to sit on the dock and enjoy. I noticed the neighbor's jetski was not on the lift, and I am the guy he usually asks to pull it and I haven't yet. So I go grab my light and find it floating down the way, take a walk down the shoreline to secure it then, finally, take in the view, what a night! Lessons learned. When you are stumped, take the time to restart from the beginning, do not assume anything. I admit that it is likely when I installed the new HP pump at the very beginning that I could have twisted that tube and that is all it was all along. Do I regret going through all this? Heck no. I needed to pull the boat to do the interior and this was the golden opportunity, that is why I threw in the towel so willingly and passed it off at the start, the timing was perfect. Also, when we bought it I wanted it to like new for next year, engine gone through thoroughly, many shakedown cruises and no bugs, and for the interior to get done. I can now say that goal has been met for sure. I have always loved looking at this site, but mostly soaking up info without much opportunity to use it, but after the support I got from everyone here to figure this out I feel a deep and sincere appreciation for the Correct Craft Family and have never been prouder to be a par of it. Thanks to all of you. |
Kyle,
Congratulations!! No wake again on the chain due to high water? Happens every time Blarneys opens the valve to dump the urinals directly into the lake! |
BlueDub
Good one. It is probably pretty high up by you guys too, but much more swim-able no doubt.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
It is working. Good Work! What a bunch of hurdles thrown in the mix.
Yea Pete we got 3" Wednesday night so it was no wake on the upper and lower river,then Thursday night we got 2.75 and they closed everything. With the multiple restrictions and my mother in law in and out of the hospital this season it wasn't worth putting the boat in at all |
But there's one big unanswered question left here.
Did you take a shower before you snuggled up with the wife? |
tryathlete
I’ve burned about 250 gallons of gas on Deep Lake so far this season. The chain has been a nightmare the last few years with rain and flooding. Good thing you’re on high ground, Gary! Maybe Quinner will throw a party and I’ll see you again soon! |
It's always been a nightmare without the high water. |
Wishing the best. |
BlueDub
Say what you want about the chain, our lake is as far removed from it as one can be, and our dock is in a huge nowake zone so it is safe for the kids. Also, when you are a teacher like me on summer break skiing weekday mornings is as good of glass as anywhere. I get the Chain O lakes rap, but we actually have it real nice where we are at.
tryathlete
At least you can ski at sunrise to sunset and then some—and weekdays are
Golden if you’re an early riser! |
I suppose only you know what the condition of that hose is, but if it's been twisted/kinked enough to stop or highly reduce flow like your simulation in the picture, I'd be replacing that hose pretty quickly even though things are OK right now |
I’d go and get PCM’s kit anyway, it’s a heavier hose and clamps to match. Used to be a dollar didn’t see how they could do it for that, it’s now 12
