  New Posts New Posts RSS Feed - Gas Tank Gallons
Gas Tank Gallons
Arvada View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Topic: Gas Tank Gallons
    Posted: October-08-2019 at 4:26pm
Can someone give me an idea of how much fuel a 1969 Correct Craft Mustang can hold. I have searched around but can't seem to find it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2019 at 4:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 11:25am
Thanks. Boy I really like the Barracuda with the center console. That looks really cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 2:24pm
They do take up valuable real estate in the boat but are certainly different. I happen to know someone with a Mustang here who has one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 2:41pm
Without a door it looks like it might be hard to in and out. A tilt steering wheel would really help or a NASCAR removable one. . I'm an old guy so that seems like it would be tough.
Thanks Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 2:43pm
On another note. I want to change the dist to electronic. I know there are kits out there but I thought I would ask you for your opinion. Have you ever done that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 3:22pm
The EI conversions have improved and are pretty reliable. Why are you converting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2019 at 3:58pm
Dan,
I thought you had the engine running?
Thanks again. I replaced the rotor, cap and capacitor and she started right up.
Again, why the thought of converting?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-10-2019 at 2:02pm
I did have it running great. Unfortunately 2 weekends ago I wen to run it in the driveway prior to a Sat morning outing and it started but ran really rough. Coughing and backfiring. So, I changed the wires, fuel filter, plugs and capacitor. Still runs rough and stalls in neutral. It also will not run over about 22 RPM's.
Next is to check the fuel, add some additive and fill the tank. It's really weird. The first time I took it out it ran really great. Then 2 weeks later all the problems started. I figured gas or points now.
Any advice. Firing order is correct I double checked. Dist never moved. I am out of more stuff to do than what I stated above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2019 at 11:07am
Dan,
Before throwing more parts at it, check to see if the anti siphon valve at the tank pickup is clogged. The problem could be fuel and not ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2019 at 6:33pm
How do I get access to the siphon? I am sure it's obvious but I am new to owing a boat and not very mechanical, but I am quick to learn. I've done some light engine work mainly just part replacement and oil changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2019 at 7:16pm
It's right where the fuel comes out of the tank, usually screwed into a 90 degree fitting with the fuel line clamped on the other end.
It's easy to mistake the anti siphon valve for a regular barbed hose fitting
Here's a typical anti siphon valve in the picture
so.........did you check/clean or maybe replace the points?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arvada Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2019 at 11:22am
Thanks Keno I'll check that out this weekend and let you know how it works out. Did not clean the points as they look ok to me, but as I stated I am not a well versed mechanic. I get a picture and show it here when I get the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2019 at 11:58am
Did not clean the points as they look ok to me, .
Just looking at them won't tell you much. A VOM to check resistance will but, just running a piece of fine abrasive paper through them is easier and faster.
