  New Posts New Posts RSS Feed - D.U.I. Marine distributor
99airwarrior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 99airwarrior Quote  Post ReplyReply Direct Link To This Post Topic: D.U.I. Marine distributor
    Posted: December-22-2019 at 2:49am
I Have two Davis Unified Marine distributors. One has a standard rotation gear. The other has a CCW rotation gear that I have in my 1985 2001 351w ccw rotation. Can I swap the gear from my ccw distributor to the new standard rotation distributor or is their a difference with the advance weights ? I know the module and pick up are the same. The standard rotation part # is M35820bl and the CCW is part # M35820RRBL. Thank You Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 8:01am
The only difference in the 2 distributors is the gear.
A distributor for a RR 351W rotates CCW and a distributor for a normal rotation 351W also rotates CCW.
This is because the cam gear and the distributor gear are cut differently from each other on the 2 engines.
So the answer is yes you can swap gears
If you're not familiar with the process do a little reading about removal and installation of the gear on a 351W.
Google is your friend, or ask here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 12:04pm
Based on the part numbers you provided in the post, both match up with a SBF Windsor 5.8 engine. As such it is highly likely that the weight and spring assembly will provide identical timing curves (provided both units are bone-stock and unmodified).
The last 2 letters indicate distributor cap color. You may want to exchange the "BL" unit for an "RD" unit as the red cap will make your boat go faster. Just sayin.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 1:15pm
Why swap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 2:48pm
Jonny,Jonny,Jonny
Let him in on the rest of the secret, he needs RED wires to go with the cap
RED may be faster than BLUE, but is it as fast as a CLEAR cap ? Just wonderin.............
Post Options Post Options   Thanks (0) Thanks(0)   Quote 99airwarrior Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 2:50pm
Thank You for the help
