  New Posts New Posts RSS Feed - Python 8.1- Exhaust Routing
DHMcFadin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Topic: Python 8.1- Exhaust Routing
    Posted: December-22-2019 at 1:58am
Does anyone know how nautique managed to route the dual exhuast in python boats while still managing to clear the steering arm/ steering cable tube mount?
1999 Longhorn Nautique
1995 Nautique Super Sport
https://www.instagram.com/longhorn_nautique/
Fl Inboards View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2019 at 9:40pm
Yes, I designed it.
Treybizttu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 12:56am
Edit: That’s helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 9:11am
Originally posted by Fl Inboards Fl Inboards wrote:
Yes, I designed it.
And "the rest of the story" is ...........................................?
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 9:29am
Here's how Tim did it by modifying the tiller arm. Regrettably the Photobucket scam got to the pictures.
Got pipes
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 9:41am
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 10:36am
Since I can still see the pictures in the link to TRB's pipe thread Pete, I figure it's time for a Christmas present a couple days early
Click on the link below and download the first fix in the list, it's the Photobucket Hotlink Fix by bridgetroll.io and you should be able to see the Photobucket affected stuff normally again using Google Chrome.
I have the third one down by Grant Gryzcan downloaded also but the first one seems to be the cure right now.
Whenever I have an issue with the pictures, I go shopping at the Chrome Store for the latest fix, download it and try it.
I think you can handle this and you'll be one up on Photobucket once again
Or here's a link to the previous thread about this that was last updated in October with the same fix from bridgetroll.io and it worked for people here on CCF
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 11:02am
I should have stated why I needed to know this info. I have a one off 99 Sport Nautique that I recently inherited. The hull has over 4000 hours. This is the boat I took my first jump set behind, ran a course behind, had my first beer, etc. It's pretty special to me. Being that its 20 years old and sat for the last couple, I made it my mission to restore this boat to better than showroom condition. Not only does it need to look better than the day it left the factory, it needs to perform better. The original numbers matching gt40/block is still with the boat. While she ran great over the summer, it was time for an overhaul or what I like to call the "GT408". The exhaust manifolds are now GLM 4" ford's. To get the flow I want, I am going python style but needed to figure out how to route 2 x 4" exhaust tubing out the transom of the boat. Below is a link to the boat intstagram if you want to see pics. There's also a thread on this forum.
Long winded I know but gotta tell a story lol.
Thanks for all the info in this thread! I really appreciate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 11:10am
THANKS KENO!! It worked!!
Man, those Hi-Tek manifolds are beautiful. Wish I could have justified those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 11:11am
Got pipes
Thank you @8122pbrainard
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 11:17am
The python boats (at least the direct drives with symmetrical exhaust outlets) have them pushed all the way up against both stringers. Neither would line up with the single 4” outlet found on the non-python boats.
Fill one hole and cut 2 new ones if you’re already doing gel work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 4:57pm
Definitely doing some gelcoat work, entire deck and hull are being sanded down re-sprayed with the original oem gelcoat. The interior will be filled, blocked, and sprayed with neutral white gelcoat to prepare for seadek.
Unfortunately, all of links above dont show or state how to modify the rudder arm. Because my exhaust tubing is 4", I need to run my exhaust the Python route up against the stringers. But again, not sure how to clear the rudder arm and steering cable support mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:38pm
I know the pics don’t show the modifications.
You’ll need to relocate the steering cable support bracket. Hose will clear the tiller arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:44pm
Any idea where I can relocate the support bracket?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:52pm
Make a mount to place it on the strut mount,I think that's how American Skier and possibly others did it. I'll look for a picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:54pm
Didn't even think about that! Very clever.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:57pm
Yea it is pretty simple.You might have to make it longer or whatever to fit your boat and change out the mount screws but it should maybe save you some work with fitting that exhaust
Post Options Post Options   Thanks (1) Thanks(1)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 7:58pm
“Possibly others” = correct craft on many (other) models. I’m sure there are some good pics on here if you try searching.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 8:00pm
Just looked at some older picture of the strut on my boat. Plenty of thread to build a plate and get that mount out of the way. Thanks for the suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DHMcFadin Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2019 at 8:01pm
Yea it is pretty simple.You might have to make it longer or however to fit your boat and change out the mount screws but it should maybe save you some work with fitting that exhaust
Thank you, the light-bulb went off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 1:46pm
Where did the second guy go that invented the internet??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 2:28pm
That's Jody of Florida Inboards He worked/consulted at CC for some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Treybizttu Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 3:54pm
Just put them straight up through the dog house zoomie style. Your back seat passengers will love it.
I never considered dual outlets on my Pro Air but I did have a Y-pipe welded up since the stock muffler was junk.
