Phyton GURUs??? |
Post Reply | Page <12 |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Online Points: 6157 |
This is a copy from PCM Mark Snider sent me back in the day. Just a word document of the file when they outfitted the Pythons.
Python 502 Parts List RP030003-Spark Plugs RP061017-Impeller Kit RP173081-Cap/Rotor Kit R026002-Thermostat (use RP026002 Kit) RM0121 Gskt. for R026002 R077001-Ford oil filter (remote mount) R077002-Gm Oil Filter (on block) RK120011-454 Plug wire set RK120011A-Python plug wire set (Purple) RA122015-Starter INJECTORS, SENDERS SO ON R020002-Water temp sender R020014A-Water temp switch R020015-Oil pressure switch R130012 Relay-Fuel Pump RN0172 Fuel Injector R047222 Injector o-rings |
Treybizttu
Gold Member Joined: October-02-2014 Location: Grapevine, TX Status: Offline Points: 534 |
Awesome thank you man.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3750 |
The GM 8.1L and GM 8.2L are the 496 and 502 engines., they are not the same although many external parts might interchange.
C_Heath
Senior Member Joined: January-21-2020 Location: NC Status: Offline Points: 207 |
Thanks for the info guys. I’m going to look at a python In the morning and the only worry is finding parts. This will help ease my mind.
Pretty much the concern whether you own a Interceptor,Gray, Holman Moody or even a PCM |
