  New Posts New Posts RSS Feed - Chucky’s 1966 Mustang rebuild
 Post Reply Post Reply Page    <1 34567 11>
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2019 at 1:37pm
Pete, I am not sure anyone knows what we are talking about anymore.   The seal post has sure taken up some ink. Going to be a long winter by the looks of it. Enjoy your Holiday.
Duane
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-28-2019 at 9:56pm
Originally posted by Chucky Chucky wrote:
I came across this chart. I find it very interesting and very related to our rear main seal conundrum. Happy Thanksgiving all!
Are you thinking because of the engine angle the oil capacity should be less? If so, you also need to factor in many marine engines have specifically designed oil pans. So, in most cases, oil capacity is the same for auto and marine for the same engine.
I have to admit Duane, I read it and thought the same thing Pete did
I think Chucky should post a picture of either his carburetor or his distributor or both next, for some what should we call it? CCF scrutiny
For some reason I'm sensing a Holley that looks a little different than the typical marine Holley for a 302. But it could be marine
Chucky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2019 at 8:18am
Thanks for setting me straight, but... here’s a page out of a genuine marine maintenance manual. Must be some special? pan that holds...wait a minute...only 4 quarts? That can’t be right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2019 at 8:23am
Maybe the Chevy guys had a special ($$$$) pan...? Or, maybe not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2019 at 8:57am
So...........why not just tilt your oil pan at a 15 degree angle with it off the engine and pour in some oil and see how much it takes to get the level where you want it?
Then you can redo the dipstick marks if you need to
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2019 at 9:56pm
Trailer mods mostly complete / painting it black by the end of the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2019 at 11:13pm
Winch / roller modification done (moved winch location) and in primer, along with a couple other tidbits. Paint coming soon, then it’s back to the boat. It was -8 degrees here this morning. The lake I plan to initially test the boat on, McMahon, is frozen enough to drive a pickup truck across.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2019 at 11:44pm
So here's the flaw in your plan ..... you could be initially testing the trailer on the lake, not the boat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2019 at 8:28pm
About...1/2 way there...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 4:27pm
I “serviced” the axle bearings and replaced the leaf spring attaching hardware. The trailer came with bearing buddies. Having never owned them in the past, I went through my own process of deciding if they are a good product. Long story short - I tossed them in the garbage can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 5:12pm
Bearing Buddies...
IMO, the Bearing Buddies work OK if you do the following:
- Quality grease seal
- Use cover (Bearing Buddy Bra or something similar)
- Don't pump too much grease into the axle and blow-out the grease seal
- Check regularly to ensure that grease level is appropriate
- Use quality marine grease
They are not a "set-it-and-forget-it" item, but I've put many, many miles on my trailers without a bearing failure to date.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 5:15pm
Why?? What's you "own process"? Here's what happens: After a trailers been on the road the bearing area heats up. Then when the trailer goes into the cooler water a vacuum is formed sucking water into the bearings. The spring loaded bearing buddy prevents this from happening. I'd suggest getting them out of the garbage before your next garbage pickup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2019 at 7:42pm
Chucky,
It's Mom,...........you've been a baaad boy
It's not nice to get old Mr Brainard all worked up on Christmas Eve, so nothing will be in your stocking
Then again, it's your trailer and you should be able to do whatever you want whether it bothers him or not
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2019 at 4:26pm
The lake we frequent has about a 3 mile steep downhill on a one lane road to reach the launch. The brakes are hot at the bottom of that hill. I have bearing buddies on all 4 axles and I have water in the brake hubs every year when I take them apart.   I have started using Low Range in the truck with my boat brakes disconnected while I go down this hill. The Low Range keeps my speed down below 15 MPH and works well. Truck and boat brakes stay cool, I don't get water in my hubs anymore. I like bearing buddies but in my application the heat was pulling in water.
I see you plan to paint the trailer black, Black does look very good when clean. I went back to a White Trailer.   Our summer heat can be 100* often and the black trailer would be so hot I could not touch it with bare hands or feet. White stays nice and cool so for me it was good change.
Merry Christmas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-28-2019 at 6:46pm
Fenders and wheels not done, but I’m getting real close now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: December-28-2019 at 6:53pm
Mini-bunks are canted at 10 degrees to match the boat. They’re also adjustable (in and out). The main bunks are also able to change angle front to back, after I modified the rear mounts. They should contour to the bottom of the boat, once the boat is back on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2020 at 6:23pm
So close to switching back to the boat. Trailer is about 98% new. Wheels / tires yet to be determined.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2020 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2020 at 1:25pm
Boat officially sitting on trailer now. Although it’s not the factory trailer, I’m liking it.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2020 at 6:27am
81nautique View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2020 at 9:52am
Not factory but it does have a good look. As long as the boat sits down between the fenders it works for me. Great job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2020 at 10:45pm
Although the fluid was clean, I simply don’t know the history. Might as well start at zero.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2020 at 10:30am
Yep. That is same kit I was going to get, thanks for confirming
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chucky Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2020 at 2:48pm
Preparing for kit to arrive...
Post Options Post Options   Thanks (1) Thanks(1)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2020 at 4:34pm
Your shop is way too clean. I don't trust you ......
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2020 at 11:55pm
Please let me know if all parts are used in kit , number plates and stuff
Looks like a tv sit com garage All props
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2020 at 9:27am
The kit has enough parts like clutch plates to do a 72C/10-18 transmission so you (and Chucky) will have parts left over.
You can try to cram them all in, but you won't succeed even with a big hammer
If you post a picture of your ID tag on the transmission, that'll be a good start to figuring out what's inside it before you start tearing into it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2020 at 10:45am
My tag is hard to read but I believe it says 10-17. 71c
I remember talk about extra plates so curious what chunky finds
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2020 at 11:36am
I believe that what you believe needs to get looked at again
In 1967 the terminology As 10-17 hadn't come about yet.
It'll probably say AS1-71C unless a much newer transmission was put in at some time
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2020 at 11:55am
Yes good idea,
