Filing the rudder |
aupatking ![]() Senior Member ![]() ![]() Joined: October-03-2013 Location: Alabama Status: Offline Points: 139 |
![]() ![]() ![]() ![]() ![]() Posted: March-28-2020 at 2:56am |
I’ve never heard of filing to make it neutral, but I understand why you’d want to. For river cruising, that constant fight is annoying. There is an argument that it increases safety, but I don’t know how much I agree. That said, It is very common to add load, for skiing the slalom course. Constant load means very slight movements are all that is necessary, as any movement effects boat path. Neutral gives you free-play, and makes it harder to keep a straight path.
That’s why the tunable rudder started in 99. It made the Ski Nautique easier to handle, not that the TSC hull was at all hard to drive. I’m going to get my 4th TSC hulled 196 tomorrow, so it’s my favorite of all time. A lot more of skiers with the pre 99 196’s have ground the rudder to get that loaded feeling. |
02 SN 196 TSC2 ZO
01 SN 196 TSC1 98 SN 196 TSC1 97 SN 196 TSC1 93 SN 196 NWZ |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13521 |
If you tune to neutral with skier the boat will constantly drift side to side and when unloaded you’ll get vibration up the steering system to the helm. Both cases are quite annoying. I far prefer a slightly loaded steering system.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Online Points: 11191 |
Good update to the other thread
![]() Maybe the reading in the link told you something in one thread or another about rudder tuning. If not...........ask away Turning hard to the right and a lot easier to the left comes with having a RH rotation prop and you'll probably never tune that out with rudder filing. It's mostly for affecting the effort required to keep the boat going in a straight line |
schultz227 ![]() Groupie ![]() Joined: August-20-2019 Location: Indiana Status: Offline Points: 49 |
Yeah sorry, I’m terrible at finding information by searching the forums. I put in key words or whatever and it just gives me random posts
Here's some reading in the link below
link By the way, it would be nice to update your vibration/flywheel issue from last year Here's a link to make it easy to update ![]() link to old thread |
If the boat is set up with the steering stiff to the right and I want to be able to turn the wheel freely. Which sided the rudder and, top or bottom ? Should I “tune”
