  New Posts New Posts RSS Feed - New Ground to Bus
New Ground to Bus
td_in_nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Topic: New Ground to Bus
    Posted: April-11-2020 at 9:55pm
Trying to deal with a some Perfectpass issues and one of the things recommended is a good ground. If a ran a new ground from the bus to the motor with 6 gauge wire would that be acceptable? I saw some post which said run a new ground from bus to battery, but I think running directly from bus to engine ground would be better, am I missing something?
Thanks
Far north downunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Far north downunder Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2020 at 10:17pm
Most people are running the new ground to the engine, not sure what is better. If the issue is not fixed you may need to upgrade the positive feed from the engine to the dash. I just upgraded the feeds from the ignition breakers to the key, and ground to the engine and it fixed my PP issues.
6 gauge should be fine, most people are using 8 gauge for the ground upgrade.
1994 SNOB
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 8:19am
Seems to me that it doesn't make any difference whether you go to the engine or the battery with your new ground wire.
One way might use a longer wire than the other
One way might be easier to run the wire and attach it.
Sounds like a personal preference type of thing.
Why do you think it's better going to the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 9:55am
Very good question. Is closer to the alternator better or closer to the battery. Cast iron isn't the best conductor of electricity. As a compromise, I'd go to the same spot on the engine block where the negative battery cable is connected.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 10:28am
I think I answered my own question
Here's a semi long read in the link below that would suggest the block is best
And...........the original ground point for the dash is the block when you follow that black wire backwards from the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 10:49am
Thanks everyone - I ran it back to block where the ground for the battery was connected - I figured it was less connections to the place the battery grounds, It may be bad logic but it is done now. I will check out the link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 11:01am
After reading the article, I now have another question, should I remove the original ground from the busfuse bar, All I did was add in the new ground, now I am wondering if I should have removed the original ground wires which were there, before adding the new ground.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 11:25am
Tom,
You are fine as is. The extra wire doesn't create a ground loop. (see the article). In wiring, it's very common to run multiple conductors when amps are high and it's not feasible to run one large conductor. Many times it's even easier to run multiple.
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 11:28am
Thanks Pete - You nailed my concern about the ground loop.
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 1:13pm
And I thought a ground loop was bad tail dragger landing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 1:33pm
A ground loop on landing is an ugly thing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote td_in_nc Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 5:43pm
Okay I looked it up and I cannot find out what ground loop means related to skiing. Someone has to explain....
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2020 at 5:58pm
In case of sarcasm, my apologies. A ground loop as it relates to flying a plane is essentially wipe out when you swap ends with a tail wheel airplane when landing. It can be a minor embarrassment all the way to a nasty crash.
I flew a Turbo Beaver floatplane that subsequently (a few years later) was water-looped but fortunately the engine did not ingest water. It was much cheaper to repair as a result. That was a very cool plane. It still is.
