  New Posts New Posts RSS Feed - 85 nautique floor boards
mlegassey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlegassey Quote  Post ReplyReply Direct Link To This Post Topic: 85 nautique floor boards
    Posted: April-28-2020 at 9:57am
What thickness plywood do I use on the floors. It looks like the plywood between the dog house and the stern is thicker than the plywood used up front ?
Barefoot maniac
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:16am
Matt,
Are you just replacing the ply or doing a complete stringer job?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:21am
There was no plywood in the floor from the factory as you are describing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlegassey Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:30am
Just Looking to replace plywood. There’s got to be plywood? What would give it structural integrity otherwise ?
Barefoot maniac
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:31am
Matt,
Pictures sure would help so we could understand what you're doing. I know you only have a phone so you could PM or email pictures to one of us so we could post them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:36am
Has the foam been removed from the hull?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 10:37am
The original floor was fiberglass over foam with the exception of the front seat/bilge area (where there’s a section of wood under the glass) and the removable panel behind the engine.
You’ll want to take a look at the number of 2001 stringer threads to get an idea of how the boat was put together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlegassey Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 11:04am
Yes I’m talking about the front seat bilge area. What thickness or plywood was used ?
Barefoot maniac
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 11:36am
Matt,
The section of wood forward of the dog house is there to hold the screws for the seats. I'd say 3/4" if that's not to thick to be level with the foam/glass aft. I know that some earlier boats had 1x (3/4").
Also, if that section of wood is bad/rotten, you may want to dig a little deeper. Have you checked your stringers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlegassey Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2020 at 1:10pm
Not yet, I have tightened all the lag bolts for the motor mount and those are solid tight.
Barefoot maniac
