Timing |
Post Reply | Page <12 |
Bri892001
Bud, I found this old thread which explains the distributor issue a little more but still not fully. The original poster was able to temporarily change the behavior by putting a little side pressure on the distributor, which was a clue. Before you go too far I'd take a close look at the cap as well, maybe try swapping the old one back in.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=27135 |
cboland
Senior Member Joined: July-15-2004 Location: Atlanta, GA Status: Offline Points: 185 |
Thanks for posting the thread, Brian. I had the boat out today and all in all I don't think I can complain too much. Idle was very low when i put the boat in gear cold or after it had sat for any extended length of time, but after I went for a ride to warm up and then came back down, she idled at 600. After a while, it might settle down to 550 which is a little low, but it wasn't a problem. Holeshot was fine and running at speed were great.
So, at this point I'm just not sure what to do next, if anything. All told she runs pretty good, yet I still know in the back of my head that if I pull the wire off #5 and #8 nothing happens which bugs me. I've changed out plugs, wires, cap, condensor with no luck. Since she's running pretty good, I'm tempted to let it be and just enjoy the rest of the summer. |
Bud
1999 Sport Nautique |
Bud,
Is there any radial play in the distributor shaft? This may take using a dial indicator but for $10 at HF, they are worth getting since you can use it for other measurements. |
wiscofoot
Senior Member Joined: February-16-2018 Location: Neenah, Wi Status: Offline Points: 124 |
The good old cam-phased 3 valve triton-stroke. Mine did the same, and died shortly after. Now i have a 6L that makes that noise and it is supposed to. |
1976 Martinique
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11061 |
6 and a half years later this thread awakens from the dead for some reason
Orlando76
I just can’t believe Pete says something is worth buying at Harbor Freight. Before you know it he’ll be shopping at Autozone and Home Depot.
And to think it was just two short days ago he was giving me a hard time about HF.......
