  New Posts New Posts RSS Feed - 1990 Ski nautique problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 3:43pm
Well that’s not a big t, not is it the same helm as my 91.
Wondering if Z has come across this oddball.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 4:30pm
I’ve seen some no/name rotary helms in mid/late 90s Malibus. Easily replaced with modern Sea Star rotary helm & cables. I believe Sea Star bought out Teleflex.
Andrewkelly1983 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 4:34pm
Brian on here recommended that I contact nautique parts and discuss just converting the helm and steering system to a rack and pinion..they sell conversion kits apparently it would seem to make the most sense. Has anyone else tried this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 7:05pm
Looked again and the pic fooled me... i think it’s a big-t after all. I have a spare in the basement. If you end up needing one, pm me.
I’ve heard that the r&p may not fit in the 90-93 dash, but I haven’t confirmed that myself. Fitting ram end of the cable down the conduit sure isn’t fun (the rotary helm end is much easier). I would also ask about steering wheel interchangeability (yours takes a 3/4” taper).
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 7:20pm
I’ve heard that the r&p may not fit in the 90-93 dash, but I haven’t confirmed that myself. .
I put the newer R&P for ~2007 era SN in my 93 with no problems at all. I had the older style R& P.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 7:47pm
Wow this is really getting complicated.... would
I be best served by used looking for the direct replacement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 9:07pm
Have you called?
Cyclone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyclone Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 9:31am
I tried to search but couldn't find out why the years 82 to 90 need a special longer cable than other years. Is the arm on the rudder different or is the helmdifferent or is there some other reason
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 10:30am
Thanks
hadn’t worked on those years yet but I’m guessing it’s a longer cable since the boat is longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 10:32am
Longer throw increases steering travel and therefore maneuverability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyclone Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 1:46pm
So if I take the complete steering system out of a 70's Southwind with a normal throw cable and it's associated steering tube or clamp block tube or whatever it's called and want to use it in an 86 SN project boat, it should steer like a 70's setup? A 70's setup seems to have a good turning radius to me.
This is all free stuff and the cable is practically new so it's a lot cheaper than a CC long throw cable is why I am asking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 1:57pm
This plan will be a waste of time, IMO.
The correct cable is expensive but you won't have to replace it twice.
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 3:18pm
I agree. Sort of like putting used tires on a car to save money. Steering is a vital part of boating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 3:25pm
I’m still waiting on nautique parts to get back to me.. wondering if I should just order the steering cable and the helm and just take care of both in one shot.. I’m not sure which helm part I need ... I don’t think the steering wheel tilts on my boat../
And just to be sure.. the steering wheel should have a hard “stop” at the end range of motion for the rudder both to the right and left?
Currently mine only has a stop when turned to the left..
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 4:05pm
Option A:) Get TRBENJ's used Helm and by a brand new corresponding cable. Someone would have to confirm that the used helm bolts up where your old one goes, and tell you which cable to buy to go with it.
B:) Seemingly large money, but buy a brand new Teleflex helm and a brand new cable to go with it. This is expensive because the brand new Telefax helm is expensive.
C:) Go with a new non-tilting, rack and pinion helm, and the cable that goes with that. Just have to confirm with someone that the new pinion helm will bolt up where your rotary helm was. It looks like Nautiqueparts is saying it does, but I don't personally know if modifications would be needed.
D.) The possibility that your existing helm is not broken. You keep your helm and just buy the cable for that helm. You'll have to take the helm apart and see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 4:31pm
My thought as well. Plus 1 From the description of what's going on, I have a feeling the helm end of the cable is chewed up but disassembly will tell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2020 at 4:36pm
E) cable is fine, helm is not. Replace helm.
Let’s see what’s broken first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2020 at 2:13am
Thanks all.. i got called back to work this week so my mission tomorrow afternoon or saturday is to take it apart .. I’ll take some pics and report back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2020 at 3:17am
My previous boat was a 1994 Ski Nautique. I did a helm and steering cable upgrade as others have mentioned. The process was not difficult and the results were great. Steering was outstanding. Don’t be too daunted with the scope of the project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2020 at 10:36am
Cyclone
You should probably start your own separate thread on this and you might get all kinds of opinions.
I figure if you use the short throw cable and the short tube, you'll have decent steering like a 70's boat, as you mentioned but won't have quite the sharpness of the original 86 setup.
Probably only noticeable at slow speeds like docking etc
If you use the short throw cable and the longer tube like in the 86, then you drastically affect the throw of the rudder. That's what many people have done and had problems with and then bought the expensive cable.
If it's all free especially with a practically new cable and it''s a project, you could install it and see how far the rudder turns in each direction as compared to what's there now and decide for yourself.
Kinda makes you wonder why they felt the need to make the rudder turn sharper in the 80's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2020 at 3:24pm
Keno Did you ever watch a ski show at Sea World in Orlando? The driver would come into the view area at full tilt and do a bat turn! Pretty eye opening experience for all the spectators. Most had never seen how quickly a ski boat can turn. That’s my guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyclone Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2020 at 10:39pm
Keno I don't think I need to start a new thread, I did a test fit today and it looks like it will work for me. There seems to be plenty of rudder movement. It will be a while till it's water ready but I'll be aware and cautious when first giving it test runs. Like I said the steering cable is practically new and I didn't have the original parts anyways in this project boat.
Thanks for the helpful input about tube sizes to go with cable. The cable and tube worked good in the previous boat so I think I'm OK here with the same setup in this boat.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2020 at 8:38am
Since you asked................yes I did, but it must have been Glastron day or year or whatever at the show.
Not a CC to be seen, it was 1979 or 1980
A 70's SN would do a pretty good "bat turn" though
Maybe somebody can post a photo of the somewhat camera shy dual steering cable setup people talk about on the sea world SN's.
I've seen just as many photos of Bigfoot as I have the dual cable setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2020 at 8:50am
Thanks
Good luck with it, I don't think you'll have a problem, other than slightly less rudder travel.
Somebody here on CCF has a 79 BFN that he put the longer cable in with the longer tube
He ran into problems with a short original tube and the new longer cable and had to find the longer tube to match the cable.
Maybe he can tell you how much difference he saw.
I think his initials are TRB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2020 at 9:26am
My guess is it had to be done to meet AWSA or whatever the hell the governing body initials are of skiing guidelines to do a 360 inside the turn buoys on a course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2020 at 1:10pm
Planet nautique got back to me and thought it was my steering cable not the helm based off a detailed description. They have not got back to me about the potential to convert to a different type of steering system.
A closer look under the dash showed that the steering cable did not move through the travel tube at all as I turned the wheel. Also, the rudder will turn fully when I turn the wheel to the left. Turning the wheel right the rudder stops moving at about half as far as it goes when turned left..
I’m pretty sure this confirms the break is in the cable so I’m going to order a new one today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyclone Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2020 at 12:56pm
Keno I just wanted to say thank you about the cable and tube info. The boat steers well on the water with the older short throw cable setup. Like you said it may have less angle than the longer setup but it works for me. I still havemany things to finish but it runs and steers good on its first run on the lake. I'm happy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2020 at 1:18pm
It takes like 10 minutes to spin the cable out of the helm and you’ll know if it’s broken or not. It’s literally 1 nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrewkelly1983 Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2020 at 6:37pm
My project is on hold
Because no one has any steering cables in stock right now.. nautique parts, Miami nautique, my local dealer in northern wi. If anyone knows of any places that may have them in stock and can ship let me know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2020 at 6:41pm
Glad it worked out for you nice and cheaply, now back to Andrew's problem
