1990 Ski nautique problem |
Page <123> |
DVskier ![]() Senior Member ![]() Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
Keno Did you ever watch a ski show at Sea World in Orlando? The driver would come into the view area at full tilt and do a bat turn! Pretty eye opening experience for all the spectators. Most had never seen how quickly a ski boat can turn. That’s my guess.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11186 |
Cyclone You should probably start your own separate thread on this and you might get all kinds of opinions. I figure if you use the short throw cable and the short tube, you'll have decent steering like a 70's boat, as you mentioned but won't have quite the sharpness of the original 86 setup. Probably only noticeable at slow speeds like docking etc If you use the short throw cable and the longer tube like in the 86, then you drastically affect the throw of the rudder. That's what many people have done and had problems with and then bought the expensive cable. If it's all free especially with a practically new cable and it''s a project, you could install it and see how far the rudder turns in each direction as compared to what's there now and decide for yourself. Kinda makes you wonder why they felt the need to make the rudder turn sharper in the 80's ![]() |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
My previous boat was a 1994 Ski Nautique. I did a helm and steering cable upgrade as others have mentioned. The process was not difficult and the results were great. Steering was outstanding. Don’t be too daunted with the scope of the project.
JQ |
Andrewkelly1983 ![]() Newbie ![]() Joined: May-24-2020 Location: Wisconsin Status: Offline Points: 30 |
Thanks all.. i got called back to work this week so my mission tomorrow afternoon or saturday is to take it apart .. I’ll take some pics and report back.
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13521 |
E) cable is fine, helm is not. Replace helm.
Let’s see what’s broken first. |
My thought as well. Plus 1 From the description of what's going on, I have a feeling the helm end of the cable is chewed up but disassembly will tell. |
Option A:) Get TRBENJ's used Helm and by a brand new corresponding cable. Someone would have to confirm that the used helm bolts up where your old one goes, and tell you which cable to buy to go with it. B:) Seemingly large money, but buy a brand new Teleflex helm and a brand new cable to go with it. This is expensive because the brand new Telefax helm is expensive. C:) Go with a new non-tilting, rack and pinion helm, and the cable that goes with that. Just have to confirm with someone that the new pinion helm will bolt up where your rotary helm was. It looks like Nautiqueparts is saying it does, but I don't personally know if modifications would be needed. D.) The possibility that your existing helm is not broken. You keep your helm and just buy the cable for that helm. You'll have to take the helm apart and see. |
I’m still waiting on nautique parts to get back to me.. wondering if I should just order the steering cable and the helm and just take care of both in one shot.. I’m not sure which helm part I need ... I don’t think the steering wheel tilts on my boat../
And just to be sure.. the steering wheel should have a hard “stop” at the end range of motion for the rudder both to the right and left? Currently mine only has a stop when turned to the left.. |
I agree. Sort of like putting used tires on a car to save money. Steering is a vital part of boating.
This plan will be a waste of time, IMO.
The correct cable is expensive but you won't have to replace it twice. |
Cyclone ![]() Newbie ![]() Joined: March-29-2018 Location: Usa Status: Offline Points: 32 |
So if I take the complete steering system out of a 70's Southwind with a normal throw cable and it's associated steering tube or clamp block tube or whatever it's called and want to use it in an 86 SN project boat, it should steer like a 70's setup? A 70's setup seems to have a good turning radius to me.
This is all free stuff and the cable is practically new so it's a lot cheaper than a CC long throw cable is why I am asking. |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21198 |
Longer throw increases steering travel and therefore maneuverability.
I tried to search but couldn't find out why the years 82 to 90 need a special longer cable than other years. Is the arm on the rudder different or is the helmdifferent or is there some other reason
Thanks |
Have you called?
Wow this is really getting complicated.... would
I be best served by used looking for the direct replacement? |
I put the newer R&P for ~2007 era SN in my 93 with no problems at all. I had the older style R& P. |
Looked again and the pic fooled me... i think it’s a big-t after all. I have a spare in the basement. If you end up needing one, pm me.
I’ve heard that the r&p may not fit in the 90-93 dash, but I haven’t confirmed that myself. Fitting ram end of the cable down the conduit sure isn’t fun (the rotary helm end is much easier). I would also ask about steering wheel interchangeability (yours takes a 3/4” taper). |
Brian on here recommended that I contact nautique parts and discuss just converting the helm and steering system to a rack and pinion..they sell conversion kits apparently it would seem to make the most sense. Has anyone else tried this?
I’ve seen some no/name rotary helms in mid/late 90s Malibus. Easily replaced with modern Sea Star rotary helm & cables. I believe Sea Star bought out Teleflex.
Well that’s not a big t, not is it the same helm as my 91.
Wondering if Z has come across this oddball. |
Hope that view is ok to help determine what cable that might be
http://www.correctcraftfan.com/forum/uploads/19740/D07CC90A-7A20-4252-8A4A-CCA243160F8D.jpeg
Are you uploading it with an iPhone? Sometimes an iPad will work (oddly) but you often need a regular computer.
Anyway, the picture may be uploaded but lost in the abyss. To find the file location 1.) Click on Member control, with the little gear on the upper left of this page 2.)Click on file manager 3.)See if you can find your pic, if so, right click it and open it in a new tab. 4.)Grab the pics url from the top of the new tab 5.)post it here Otherwise PM me, and you can send it to me over email. |
Im
Not sure how to post a pic.. I tried the tree with the arrow up but it didn’t work.. I can send an email photo to someone if they feel comfortable .... or maybe I need to do something else for getting the photo on here.. |
Maybe... but not 100% true. Most 90 should have the big-T, but some late 90 and then 91-92 had some different rotary systems (not big-T). My 91 had such a set up. Pics would be best to confirm. ![]() |
If it looks like a rotary, it's the Big T Teleflex. |
Thanks for the responses.. I’m going to try and post a pic of what it looks like under the steering console .. I don’t think it’s a rack and pinion.. it resembles more of a rotary system I believe ...
Martin, I don't think Andrew has the rack and pinion. Chances are higher that it's the Big T Teleflex. |
Page <123> |
