  New Posts New Posts RSS Feed - 1970 trailer vin number
moker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moker Quote  Post ReplyReply Direct Link To This Post Topic: 1970 trailer vin number
    Posted: August-06-2020 at 2:36pm
Any idea what an original 1970 trailer VIN would look like or be located? I just restored the trailer and never found one. The DMV thinks it was never registered. It came from Cypress Gardens and only 1 other owner that never registered it. I am planning to have it weighed and create a home made trailer registration worst case but i can still create a VIN
Thanks
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2020 at 4:17pm
My '69 trailer has it just a foot or so down from the hitch- it's an aluminum tag mounted with 4 pop rivets. The first digit tells you what model trailer it is then a space then in my case a 4 digit serial number. Does not look like we can add pictures yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote moker Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2020 at 4:49pm
WoW, You are correct. I cleaned the paint off it didn't realize there were stamped digits on it.   I can barley read the stamped ones on the bottom.   On top, I can see 7 71 which looks to be the manufacturer date. So the vin must be 3H 831.   That short? Sound about Correct?
Thanks
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2020 at 4:54pm
Marc,
As Gary mentioned, I'd say what you found is a serial number and not a VIN. The "3H" would be the trailer size and then the serial number. That should work for the DMV. Also, you may find a number stamped into the steel on the bottom near the tongue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote moker Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2020 at 5:09pm
Great thanks, Sometimes i miss the oblivious and need a pointer. Ill look under the tongue. I spent 2 weeks grinding and welding to bring it back to life. Wish I could post a picture of it b and a. Its amazing transformation.
Thanks
Marc
